spicedcrab
TN, USA Status: offline
ync, i am about to try the hacker a30 16m in mine, my guess is that its going to be perfect, i currently have the 480bl 910 in it and im not happy with vertical. as far as the apogee 2200, i have tried that bat, and also the thunder power 2100, the thunder power is much better in mine, its very noticable. i cant comment on the hs55's because i have not tried them on a plane this size, may be ok though, but IMO i think they are not the best for this plane. i can say however that the hs65-hb are WONDERFUL in mine, that would be my recommended servo, they really are worth the extra $. cc45 is great, im using that one in mine. electon 6 is very good and will be great (im using that in a formosa II) but i just tried the cc berg 7, i have to say this is the best rec. i have ever owned, only one i have ever done a range check with and got to were i could not hear my helper any more and still didnt ever get a glitch during the test. as far as the prop, im running the a30-16m in the formosa II and the absolute biggest prop i could swing without over amping the system was a 11x7E apc. i ended up running an 11x5.5 as my favorite prop for the hacker. john
_____________________________
IF IT AINT BROKE...............BREAK IT!
