RE: Seagull Models EP Extra 300
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Seagull Models EP Extra 300
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Seagull Models EP Extra 300 - 10/2/2006 1:36:53 AM
aflipz
Status: offline
For those who would like to see what mine flies like with my unorthodox power system here is a video
kontronik maxi dancer 1200kv
apc 10x5E
castle creations phoenix 25
electric power 1700mah 3 cell 12/18c
I'm only full throttle for short and rare bursts in the vid but it gives you an idea. Please excuse my less than spectacular flying abilities.
(in reply to bdavison)
       Post #: 51
RE: Seagull Models EP Extra 300 - 10/2/2006 4:04:26 PM
bdavison
Status: offline
looks good to me.
Im still working on another video...its taking a while because there is alot of editing. Im trying some new things, and getting it on video is proving difficult.
_____________________________
teamflyingcircus.com
(in reply to aflipz)
       Post #: 52
RE: Seagull Models EP Extra 300 - 10/3/2006 2:37:23 AM
aflipz
Status: offline
i'm sure it'll be worth the wait. I could have shaved a lot of fluff out of my videos but it would have been tedious work cutting out all the little repetitive stuff.
I need to experiment with various props on my motor, i'm sure there are more efficient options out there.
       Post #: 53
RE: Seagull Models EP Extra 300 - 10/3/2006 2:55:03 AM
bdavison
Status: offline
I tried the APC 12x6E on my 480(910kv) and it made a big difference. Much better vertical performance.
This video will be recorded in THX surround sound..Its a first for me. Im also video'ing it in HD format, but unfortunatly, compressed to web viewing size, it loses the HD aspect, but the surround sound is still there. Ive still got a lot of work to do, but I hope to have one sweet video when Im finished.
       Post #: 54
RE: Seagull Models EP Extra 300 - 10/3/2006 5:46:14 AM
x388s
Status: offline
Hello,
New to this forum and newish to electric powered flight. ( I have been building and flying fuel powered planes for 16 yrs) I just bought a Seagull EP extra 300. My question is can I put a AXI 2808/16 in the extra 300? If so, what are my prop options. Any and all suggestions on building this plane welcome
       Post #: 55
RE: Seagull Models EP Extra 300 - 10/3/2006 7:08:48 AM
BadBoy__MadMikey
Status: offline
hey guys,
i picked up a seasgull extra ep 300 saturday at my lhs. well after reading the weight on the box side i couldn't beleive what it said 20 to 21 ounces??? well i went with it and got a 450 e flite outrunner. well i just finished her about 2 hours ago and ran the motor. took 3/4 to hover it in my hand!!!! and i'm kind of a power guy with my electrics. i weighed her with out battery and it was like 25 to 26 ounces!!! big diffrence from what the box says!!! go figure!!!!! welll i kind of stole the radio gear from my brio to get it goin. well i used a power 10 in the brio. so i managed to mount the 10 on the extra. WOW will hover at half throttle. plus on the 450 it was real tail heavy!!! now i think it will balance out great. i weighed her with a 1320 pack cause i let a buddy use my 2100's this weekend. but even with the 1320 weight was about 28 ounces!!! my brio with the 2100's weighed 32 ounces and had unlimited vertical!!!! i figure the extra will come out at 30 to 31 ounces with a 2100. i'm using 3 hitec 55's and one eflite s75 servos. jr 6 channel micro receiver. eflite power 10 outrunner, cc 35 esc. have you guys had the same problem with the weigh being alot more than the 20 to 21 written on the box???? if so whats yours weigh???? what you guys think about me using the power 10???? sick huh????? lol lol did any of you have a problem balancing it or is the 480 i see many if u are using is heavier than the 450???
Mikey
< Message edited by BadBoy__MadMikey -- 10/3/2006 7:20:00 AM >
(in reply to x388s)
       Post #: 56
RE: Seagull Models EP Extra 300 - 10/3/2006 8:35:51 AM
Get Real
Status: offline
there was probally some mix up before release. it was corrected online but is still on the box. auw is suggested at 28-32 oz. most that have used the suggested set ups have come in between the suggested weight(weights have been a little over when using larger motors). mine was just under 32 oz. the last time i weighed it.. including some added stuff like tail wheel/covering on gear legs/spinner/painted canopy/reinforced elevator and/solid stab.. using hs 65s all around 480 1020kv and tp 2100 prolite. it flys very well/and has very good 3D capability in my opinion as well as others. power 10 should do well for 3D.. i find the 480 marginal for hovering with mine near 32 ounces. the 480 flys it well for aerobatics which its marketed for/for hardcore 3D guys you probally want the power 10 or more power. the 480 3.1 oz weighs more than the 450 2.5 oz you shouldnt have a problem balancing.. remember manual says wing tip for cg not wing root.. at root its roughly an inch further back to get cg.
< Message edited by Get Real -- 10/3/2006 8:41:03 AM >
3DHobbyShop Rocks!
(in reply to BadBoy__MadMikey)
       Post #: 57
RE: Seagull Models EP Extra 300 - 10/3/2006 3:12:05 PM
aflipz
Status: offline
quote:
ORIGINAL: x388s
Hello,
Yes and no,
it is in the right power class to get you around that's for sure but it will be less than ideal;
if the data i found on the web is right this motor is relatively high kv and loads up fast on small diameter props. it is built for speed on aerodynamic aircraft not thrust on slow aerobatic planes. It will pull it around but you may find torque rolling allmost impossible.
i wouldn't go any higher than a 9x5E on 3 cells and would expect the loads to be above 25A wot be carefull! You are looking for something in the same weight and watt class that has more torque and less rpm's in order to swing larger diameter props.
(in reply to x388s)
       Post #: 58
RE: Seagull Models EP Extra 300 - 10/3/2006 9:27:05 PM
x388s
Status: offline
aflipz,
You are rite on the money. I bought the AXI to use in a hotliner. Would you suggest trading/selling the AXI to get the correct setup. I am at best an average 3d pilot and just bought this plane to have fun. If you think this motor will get me by I will just try it and see what happens. The speed controler I have is a Jeti 40-3p. Thanks for the help
quote:
ORIGINAL: aflipz
quote:
ORIGINAL: x388s
Hello,
Yes and no,
       Post #: 59
RE: Seagull Models EP Extra 300 - 10/4/2006 4:46:32 AM
Rush7
Status: offline
I had my first flight on my Segull Extra today. It flies great and performes a great knife edge. I think that my cg is a little off because it was a handfull from a wall to a hover. It seems to fly great and seems to fly very light.
My setup:
Extreme Flight Torgue 2818T/900 motor
Extreme Flight Air Boss 35A ESC
Hitec 65HB's on ailerons, elevator and Hitec 65MG on the rudder
Hitec 555 receiver
Thunder Power 3s1p 2100mah
12x6e APC prop
The plane has unlimited vertical and will hover at about 1/2 throttle. I think that I finally got this motor/esc thing figured out. I beleive that I chose the right setup for my plane.
With all of this being said.........And I do not want to start a fuss but I said previously that I would give my honest opinion about this plane versus the Extreme Flight Extra. I do own and have over 200 flight on the EF Extra.
Value - The Seagull Extra wins hands down
Areobatics - EF Extra
3D - EF Extra
Fun to fly - EF Extra for performance Seagull is a great bang for your buck flyer
With that being said, here are the reasons.
Value - This is a no brainer. The Seagull is half the price of the EF.
Areobatics - The EF just seems to be much more resposive and flys like it is on rails
3D - The EF is much more stable in 3D manuvers
Fun to fly - EF Extra if you want the top of the line plane(and money is no option)......If you want a great plane at a great price that seems to be top of the line for the money, go with the Seagull Extra.
With some more fligths on the Seagull I think that I can get the plane to perform better. I dont really check cg on my planes. I usually use my fingers and eyeball it to see if I am close to the factory settings are, after the first flight I will change it to make the plane perform the way I want it to. This has seemed to work for me better than putting it on the cg stand and moving stuff around to get it perfect. I have found that if it close you can usually get it back on the ground in one piece. I hope that everyone will have as much fun with this plane as I did today. This is a good plane at a great price.
http://www.crccflyers.org
Huckin' til it hurts
(in reply to x388s)
       Post #: 60
RE: Seagull Models EP Extra 300 - 10/4/2006 6:31:25 AM
BadBoy__MadMikey
Status: offline
i test flew mine also this evening. and all i can say is WOW!!! i'm glad i put the Power 10 on it cause it has unlimited vertical. and the power 10 only cost $69.99. what a great price for a little power house. i'm using a cc 35 esc on it with prolite 2100's. i was really nose heavt though. it took about 3/4 of down to hold level inverted flight. so i used the removable battery tray to create a long solid battery tray. i can now mount the battery all the way back to the wing tube. and i didn't have to add any extra weight. the 1st flight myself and my buddy loved the way it tracked, but was just too nose heavy to tell somethings. the second flight i moved the pack back as far as i could and it felt alot better but still nose heavy. i won't be able to fly it again til next week but after ll the changes i made to get the cg better i should have a better 3-d report. but i also have the brio 10. and i fly imac contest and i use to use the brio to prctice my manuvers, but i think this extra will be a much better practice ad for my imac flying!!! this plane is just too cool!!!!!
Mikey
(in reply to Rush7)
       Post #: 61
RE: Seagull Models EP Extra 300 - 10/4/2006 3:33:54 PM
billz
Status: offline
Just got my Seagull Extra 300 yesterday. I was looking at this and the Extreme Flight 300 but price won out. The Seagull Extra 300 looks like a great plane. Started building it but couldn't help but wonder why the hinges don't come pre-glued in place? Seems like it would save some time. I'm new to balsa models and CA glue (been flying foamies and using epoxy) and I guess I'm just nervous about gluing the hinges. Any pointers?
I've got the motor, cowl, and landing gear installed just fine. I can't wait to finish it and give it a try.
My setup:
Motor - Eflite Park 480 (taken from my PZ Typhoon...following in the footsteps of Get Real)
ESC - CC Phoenix 35
Prop - APC 12x6E
Battery - TP 2100 3S Prolite
Servos - Hitec HB65
       Post #: 62
RE: Seagull Models EP Extra 300 - 10/4/2006 5:05:18 PM
aflipz
Status: offline
yeah follow the instructions and hurry up to take out the centering t pins and push the aileron closer to the trailing edge of the wing, ca tends to set real quick and you don't want to have to cut mis-aligned hinges and re-slot the wing and ailerons.
make sure you have some debonder to remove the excess ca.
(in reply to billz)
       Post #: 63
RE: Seagull Models EP Extra 300 - 10/4/2006 8:17:28 PM
bdavison
Status: offline
Here's the easy no fuss way.
Just insert a t-pin into the center of each hinge, slide em all into the control surface.
Now take the control surface with all the hinges in place, and slide them into the (wing/stab/etc) so that the T-pins form a little gap.
Remove the first T-pin. Wick some thin CA into the hinge. Remove the next t-pin and repeat.
After you've hit them all with CA, flex the hinge back and forth about 10 times to make sure its free.
Tug on it to make sure its glued good.
And your good to go.
Its not complicated, the problem most newbies have is that they try to get the hinge too tight. Use the T-pins...it will make the gap correct, and the surfaces will move freely. Its ok to have a little gap in there. You can always seal it with hinge tape later. Better to have freedom of movement, than a super tight hinge.
Use THIN CA...not thick, not medium...THIN! You want the CA to wick up inside and firmly attach everything. You can use one of those fine CA bottle nozzles if you want. It makes it easier to get it into the hinge.
Dont put so much on there that it drips down underneath, or you will glue the wing to the table, and make a huge mess. You'll be able to see the CA flow into the hinge if you do it right.
