EpoweredRC
Joined: 3/11/2003 From: PowderSprings, GA, USA Status: offline
quote:
ORIGINAL: choppersrule quote:
ORIGINAL: Night_prowler26 So for the ones who have put the superskids on the Blade CP pro with lipo and everything has it weight it down so much it wouldnt fly good? And do you guys use all of the things it comes with? I was looking on superskids.com and I see they have the fin and the stifers from the gear to the boom (dont know what to call them) and the little ball for the rear tail rod thingie... do you guys add all of this stuff? does it all fit liek it should on the Blade CP pro or do you have to mod anything to make it fit? Thanks for the help Night Prowler, Get the Version 3, super skids, they are so much better than version 2. Plus, it has a bigger opening for the battery tray. Version 2, the biggest battery that would fit was an 860 mAh. With version 3, a 1200 mAh will fit. As far as the weight thing, you really don't know the difference. However, it is tail heavy, just move the battery forward. The battery tray on the super skids is designed for rubber bands to hold the battery in place. Me, I'm a velcro kinda guy, so, instead of using the the battery arms that came with the super skids, I just used the battery tray from the stock CP. No big deal there, just do which ever you are comfortable with. No modifications are necessary, just take off the original skids for the Pro, and the super skids screw into the existing holes, that the originals came out of. Dave / Choppersrule Alright thanks for the info.
_____________________________
Mini Edge 540,BP Edge 540 profle ,MST, E rustler ,With DX2.0. /GF"S-Blade CX,Slow stick. A123 Batts all the way! 5 glow
