jagnweiner
Joined: 2/18/2003 From: Bloomington, MN, USA Status: offline
Gibbs- I hear you. I didn't think about balancing when I glued my servo tray in either. It's no biggie. I don't remember if you're using a Magnum .91 for this also, but it weighs a little more than the Saito, so that will help some. I didn't add a ton of lead, maybe 2 oz., plus a heavy hub for the spinner. On the floats, I found them to be a bit of a challenge just because the there are a lot of long joints/seams that are difficult to line up 100% perfect. I also glassed mine and it was my first glass project. They leaked through the keel the first time I tried them. I patched the leak, but they look pretty ugly right now. I need to smooth them up, add more resin and repaint. It's a ways off, but when you first try flying with floats, be careful. Do everything much more slowly. Let the plane fly itself up gradually on takeoff, rather than pulling up hard on the elevator. The nice thing about a Cub on floats, though, is no ground loops on takeoff! You'll come to appreciate that. As long as I'm rambling . . . If you haven't flown a Cub, takeoffs are the hardest part. They do want to ground loop. A little toe-in on the gear helps a lot. It is also much easier to take off from grass rather than pavement. Have fun and keep up the good work.
_____________________________
-Scott WACO Brotherhood #61
