can773
AB, CANADA Status: online
quote:
ORIGINAL: papadontscreech What is the claim to fame of these packs, they are heavier than the 5300s , also with the 80% rule then only 4000mah is available to keep the packs happy, I have trouble already in certain copnditions keeping within 80% of the 5300s, so I dont think they will be the best choice for a lot of FAI pilots, I realise they have a higher discharge rate but the 5300s are more than adequate, maybe they will appeal to certain motor setups where they current draw is higher, outside that I do not see the benefit. I am not buying the 80% value....I routinely hit 90+ on my packs (just today was doing 4800-5000 in high winds....and am up to 120 cycles. Personally for the 5300's I think 85% is still a safe number to shoot for. Resting voltage is a better measure of how hard you are pushing things.
_____________________________
Chad Northeast
