Hello82
MA, USA Status: offline
Hi That 3 piece wing assembly looks great Capt G! Hey talking about wire, plywood types and stuff you are using for strength...what is the difference between Music Wire and Stainless Steel... I found some good stainless steel 3/16 with threads on one end, but not music wire. Also, I know you are usually supposed to use 1/4 "Aircraft Ply" I believe for the retract mounts...is aircraft ply just "Birch" with a smooth finish and regular craft ply and is a cheaper wood with a rough finish, or is there more to it with the ply making process , glues etc. that it actually has to say "Aircraft" on it. Hey what is that yellow seperation stripe on the cockpit panel I see a lot...usually see it only on the actual origianal wartime P-51's. Matt
