MVVS 45 RPM #'s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 45 RPM #'s
Page: [1]
Login
MVVS 45 RPM #'s - 9/15/2006 3:32 PM
Greg Cothern
Score: 100
Last Login: 4/30/2013
Status: offline
I ran the motor in some yesterday and adjusted the carb and she seems to be a good strong pulling motor. Ran a tank through on the ground with the cowling off, by the end of the tank it had a very consistent idle of about 1800 and would hold that for days I believe. Never got hot! Towards the end of the tank I tweaked the high needle, turning a strong 6000 with a NX 23-8 on a Bisson Wrap around Pitts. I believe this to be respectable for the first tank reading???
I know the canister setups would work much better and may move to one at a later date but for the current bird I believe this setup will prove more than adequate. Wild Hare Extra 300 16 1/2 lbs.
_____________________________
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
Hide Signatures
       Post #: 1
RE: MVVS 45 RPM #'s - 9/15/2006 6:27 PM
pe reivers
Score: 646
Last Login: 5/21/2013
Status: offline
Thanks Greg,
Look at my support forum for the tests with MTW canisters if you need to compare.
I like the performance of a 20x10 3 blade mejzlik prop on this engine.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Greg Cothern)
       Post #: 2
RE: MVVS 45 RPM #'s - 9/15/2006 7:53 PM
BaldEagel
Score: 118
Status: offline
Pe
What revs are you pulling with the 3 blade 20x10?
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to pe reivers)
       Post #: 3
RE: MVVS 45 RPM #'s - 9/15/2006 8:40 PM
pe reivers
Score: 646
Status: offline
I copy from the link:
Prop;muffler;rpm;header length cm; header diameter mm
3W21x11;TD75K;6300;30;25;
3W21x10;TD75K;6650;30;25;
3W21x11;TD75K;6500;25;25;
3W21x10;TD75K;6900;25;25;
Mej 20x10x3;TD75K;6850;25;25;
Hide Signatures
(in reply to BaldEagel)
       Post #: 4
RE: MVVS 45 RPM #'s - 10/9/2006 12:03 PM
Greg Cothern
Score: 100
Status: offline
Changed to a 22 X 8 NX prop, did not touch the needles, still no time on engine and tached at 6500. Put the 16 lb 6 oz bird in the air and the MVVS 45 pulls quite strong, multiple vertical snaps and climbs out of sight.
Pe' or anyone else who can answer this, with a inverted engine install what header will put a TDH 75 midline for a Wild Hare Extra? Thanks.
Hide Signatures
       Post #: 5
RE: MVVS 45 RPM #'s - 10/9/2006 12:05 PM
Greg Cothern
Score: 100
Status: offline
Any place I can get a good size MVVS engine decal for the cowling on my Extra? I want to display my engine choice, I am tired of being asked if it is a EVO, arrrg.
< Message edited by Greg Cothern -- 10/9/2006 12:07 PM >
Hide Signatures
       Post #: 6
RE: MVVS 45 RPM #'s - 10/9/2006 3:13 PM
pe reivers
Score: 646
Status: offline
The VA -DB series has been adapted by MTW to include the MVVS range lately.
see http://www.mvvs.nl/MTW/Headers.htm , way down the page for the VA -DB 2
MVVS has new decals available with a large 4" multicolor logo.
Hide Signatures
       Post #: 7
RE: MVVS 45 RPM #'s - 10/14/2006 8:48 PM
Greg Cothern
Score: 100
Status: offline
Pe' were can one obtain some of the MVVS logo decals??? The one's that came with my 45 were a bit oil soaked.
Hide Signatures
       Post #: 8
RE: MVVS 45 RPM #'s - 10/16/2006 1:10 AM
pe reivers
Score: 646
Status: offline
I have the Blue decals in stock. Recently, MVVS ships their eingines with new larger, and colorful decals. I will see that I get some.
Hide Signatures
       Post #: 9
RE: MVVS 45 RPM #'s - 2/2/2007 8:04 PM
Greg Cothern
Score: 100
Status: offline
I have a question, I have run about 1.5-2 gallons through my MVVS 45, I cannot get the idle down low enough to keep the model from pulling away...If I trim it down anymore she dies, yet after flying it will idle down. My question is this, is the motor still too tight to idle down and take more run time to achieve this?? Or do I need to tweak the low needle more??
It has great throttle response and pulls great, no hesitation, every other aspect it great!!!
Hide Signatures
       Post #: 10
RE: MVVS 45 RPM #'s - 2/3/2007 1:46 AM
pe reivers
Score: 646
Status: offline
What is the idle rpm? Prop size? Pitch?
If the idle mixture is rich enough, you can go as low as 1200 rpm, though I like my engines around 1500 rpm.
Just adjust lower and lower, and adjust the idle needle for stable operation and acceleration at the lower rpm.
A higher idle is safer though, so do not strive for solutions that may bring more woe than joy.
Hide Signatures
       Post #: 11
RE: MVVS 45 RPM #'s - 2/3/2007 2:04 AM
Greg Cothern
Score: 100
Status: offline
Pe' I am using a 22X8 NX wood prop, turning in the mid to upper 6K range, and idle right 2000. Yeah it has performed great so I have not bothered witih it, but would like to get the idle down enough that the model is not trying to run away on its own hehehe.
I need to put a longer arm at the throttle to get better resolution, this would probably help a lot, I am still running the stock arm..
Hide Signatures
       Post #: 12
RE: MVVS 45 RPM #'s - 2/3/2007 3:19 PM
pe reivers
Score: 646
Status: offline
All the small things together help a lot.
I have my servo arm nearly aligned with the servo bottom in order to get best resolution. I also lengthen the carb lever, and unhook the return spring (but leave it in place)
With this setup, I have a large servo displacement around idle, and short displacements near full throttle. The power curve thus is more linear. I do not fly 3D, but still want to have stick response linear.
Hide Signatures
       Post #: 13
RE: MVVS 45 RPM #'s - 2/22/2007 6:24 PM
Greg Cothern
Score: 100
Status: offline
I traded a overweight underpowered ZDZ 60 for another MVVS 45, this one has a bit of time on it, spins a 22 X 10 Bolly CF prop with a BCM wrap around pitts muffler at 7300.
< Message edited by Greg Cothern -- 3/26/2007 9:55 AM >
Hide Signatures
       Post #: 14
RE: MVVS 45 RPM #'s - 3/26/2007 9:59 AM
Greg Cothern
Score: 100
Status: offline
My 45 is running great, 7300 with BCM wrap around pitts muffler, 22 X 10 CF Bolly. I am happy with how she runs..
Need to tweak the needles a bit... Seems I have the low speed a bit too rich, she burbles a tad bit on the low end.. I have noticed I can adjust the needles without the cowling and it is obviously a bit different than what she runs like with the cowling on.
Hide Signatures
       Post #: 15
RE: MVVS 45 RPM #'s - 3/27/2007 12:05 AM
pe reivers
Score: 646
Status: offline
burbling near idle (the lower 1/3rd throttle part) is normal for two strokes. If you go leaner on the idle you will run into lean high speed issues.
Hide Signatures
       Post #: 16
RE: MVVS 45 RPM #'s - 4/19/2007 4:33 PM
Greg Cothern
Score: 100
Status: offline
Thanks Pe!
< Message edited by Greg Cothern -- 4/19/2007 4:46 PM >
Hide Signatures
       Post #: 17
RE: MVVS 45 RPM #'s - 7/15/2007 5:49 AM
Greg Cothern
Score: 100
Status: offline
Just got home from first flight using a MTW 75 (short fat) canister muffler on my MVVS 45 installed in a WH Yak. 3 words, HOLY SMOKES BATMAN!!!! This engine came ALIVE! Ripping a 22X8 Bolly wood prop on straight passes... Big improvement over the BCM wrap around pitts muffler. On ground turned 7350, same prop on my other MVVS 45 with a BCM wrap around pitts was turning 6700.. And did I mention this is a brand new engine out of the box with the canister on it and the other has 2-3 gallons?!!
Quiet as a church mouse too.
Hide Signatures
       Post #: 18
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 45 RPM #'s
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
