Wheelnut
VA, USA Status: offline
Ok. I am making some progress. I tried switching from a normal frame rate to a Fast frame rate and I got it to program but it would was WOT in neutral and when I put the brake on it would stop. So I was going through my manual, which I rarely have to do, and I found that grip lever A is the brake End Point Adjustemets. I adjusted this to Zero and the esc wouldn't program at all. Then I adjusted it to 100 and now it is programming pretty much correctly, but I am not 100% sure because it is not programing exactly the same way the stock radio did. I have been using JR since I first got in this hobby and I have found on a couple of occasions that it is not like the other radios, but then again, airtronics is not like Futaba either. I will continue to experiment, but for now it seems to be fine. I am going to try adjusting the brake end point to 125% to see how that affects it. Hope this helps you shanep. blackjack52, what is a xmtr?
< Message edited by grk65 -- 9/21/2006 8:01:17 PM >
_____________________________
Ride the edge between fast and disaster!
