opjose
MD, USA Status: offline
quote:
ORIGINAL: paul49 Hi Steve and opjose, I eventually gave up on the single pushrod as I couldn't find a way to fit the two wires down the fuselage and out through the slots. I've done this with many planes so I found it somewhat easy. You bend the wires out slightly and insert the rod 90 degrees to it's eventual orientation. Sometimes I put a piece of wire or string on each side to act as a leader... inserting the string all the way back and out first. I then get the rod all the way down the fuse, and work it almost into position, then pull the string to get the rods to slip out of the slots. quote:
ORIGINAL: paul49 My trainer uses single pushrods for the rudder and elevator and, if you grab one of the surfaces and try to move it, the pushrod bangs around inside the fuselage. But it doesn't seem to affect the way the plane flies. I still haven't quite finished the Giles so I don't know how it will fly. Should I be thinking of restricting the sideways movement of the pushrods in the Giles? Cheers, Paul. As ysteve1 said, normally this is of big concern, as any time there is lateral movement you have the opportunity for flutter. However that said, with the arrangement in the Giles I haven't had any problems. The "three point" positioning seems to prevent lateral movement.... and I've pushed this plane quite hard.
_____________________________
- Build em'', fly em'', crash em'' and build more.
