opjose
MD, USA Status: offline
My take: That's a classic case of flutter. A simple aileron failure would have rippd up the aileron at one originating point... e.g. the horn would have been pulled out, or one side would be fractured with a corresponding break in the covering. Usually with the balsa shearing along the stress point. In your case ( from your pictures ) the entire aileron is somewhat uniformly fragmented as if excessive vibrations pulled the trailing edge off or up/down. Unless the surface was vibrating excessively, you really don't see the type of fracture your wing shows... That the horn held up, tends to indicate the control surface was somewhat free to move, too. So either the linkage gave, a servo gear stripped, or the servo was unable to handle the high loads. I fly mine with cheap 130oz/in servos ( 9.00 each ), and ( knocks on wood ) the extra torque has prevented this. The plane flies fast so even in a slight power on dive, with a powerful engine, flutter can be a real problem if something is amiss. Since you know what you are doing, I'd put my money on the servo gear stripping under load.
_____________________________
- Build em'', fly em'', crash em'' and build more.
