RE: When will we see the Losi 8ight???
Tower Hobbies
Logged in as Guest
  Printable Version
Wheely King 14mm Hex Wheel Extensions - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: When will we see the Losi 8ight???
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: When will we see the Losi 8ight??? - 9/23/2006 5:21:12 AM
SManMTB
Status: offline
quote:
ORIGINAL: Griptape
so is it worth it? or.. should i go cheap route and buy the rtr, and replace the engine, pipe, chasis, towers, and steering servo? :P
That's a waste of money for sure. The RTR looks cheap too.
(in reply to A.B.U)
       Post #: 51
RE: When will we see the Losi 8ight??? - 9/23/2006 5:35:22 AM
Super_Dave
Status: offline
quote:
ORIGINAL: MugenSickly
Mines together. Pretty straightforward.
More observations:
Not only is there a clunker in the tank, but ther elooks to be a piece of plastic that screws out or something, inside. I assume you take it out and it now holds more fuel.
I was pretty curious about that screw in the fuel tank and it doesn't say anything about it in the manual. I'm not sure if i'm going to like this clunker much. Even when the tank just gets low it might keep jumping out of the fuel and sucking in air. This of course isn't an airplane and by no means a smooth ride.
I would have liked some of the tolerances to be a little better but I like things being perfect. The shock pistons had a bit of play inside the cylinder. The pin on the rear diff that one of the bevel gears goes to was a tiny bit to small for the hole in the output shaft but it wont be hurting anything.
(in reply to MugenSickly)
       Post #: 52
RE: When will we see the Losi 8ight??? - 9/23/2006 8:17:01 AM
All The Way
Status: offline
its a fuel block like the AD2 has
_____________________________
RC Pro Series Northeast 94m
Sponsors: Eclipse RC, Glenwood RC
(in reply to Super_Dave)
       Post #: 53
RE: When will we see the Losi 8ight??? - 9/23/2006 1:31:38 PM
A.B.U
Status: offline
quote:
ORIGINAL: SManMTB
quote:
ORIGINAL: Griptape
ahh ok, thanks man.
EDIT:// yea on a second thought, it does look cheap... reminds me of a turmoil..
plus if i get the kit ill be busy building it :P
< Message edited by Griptape -- 9/23/2006 1:32:28 PM >
is this needed?
(in reply to SManMTB)
       Post #: 54
RE: When will we see the Losi 8ight??? - 9/23/2006 6:20:14 PM
kx250ryder
Status: offline
Maybe I missed something, but the RTR looks like it has different towers, and a different radio tray. I can't see if the chassis is different or not, but if the RTR gets the same chassis (doubtful) I would rather buy the RTR just to avoid threading screws into new plastic components.
One could pick up a set of towers from E-bay, and sell off the engine, radio, servos and hand starter, to get some scratch for better gear. Its alot more work, but that is how much I hate tapping plastic. Dissasembly and re-build is easy after it has been put together the first time.
My decision on which to buy hinges on whether the chassis is different, and what (if any) other parts are downgraded.
". . . the same thing we do every night Pinky, try and take over the world." -- Brain
(in reply to A.B.U)
       Post #: 55
RE: When will we see the Losi 8ight??? - 9/23/2006 6:25:36 PM
A.B.U
Status: offline
The chasis on the kit is milled, same with the towers, and has tini hinges, and chances are, the plastics are a BIT stiffer...
is this needed?
(in reply to kx250ryder)
       Post #: 56
RE: When will we see the Losi 8ight??? - 9/23/2006 6:54:23 PM
1CE
Status: offline
i just bought an 8ight about 45 minutes ago from RCBoca Hobbies.... the thing is great! Chassis on this thing is VERY think! i have the steering assembly together and it all fit perfect. The only thing that bugs me so far is how small the hex screw heads are (the actual hole in the screw not the screw itself) They might tend to strip easily. Everything looks great.
(in reply to A.B.U)
       Post #: 57
RE: When will we see the Losi 8ight??? - 9/23/2006 7:06:49 PM
A.B.U
Status: offline
pix plz ppl
is this needed?
(in reply to 1CE)
       Post #: 58
RE: When will we see the Losi 8ight??? - 9/23/2006 8:26:45 PM
1CE
Status: offline
i just built the arms and carriers... went together very smoothly accept for one of the grooves in one of the cvds is a little too tight... this makes it so that the cvd doesnt spin freely in all directions. I think that it will wear and it wont matter however i am going to e-mail losi and see what they say. Ill be shure to let you all know what their reply is.
(in reply to A.B.U)
       Post #: 59
RE: When will we see the Losi 8ight??? - 9/23/2006 9:42:59 PM
Super_Dave
Status: offline
A few of my CVDs were like that too Ice. Some of the tolerance on the parts isn't all that great. The diffs are kind of weird (atlease mine seem to be). After you build them and they sit for a little while they tighten up for no reason at all. Nothings binding and they are built correctly but I guess this is why Losi tells you to break in the diffs.
I love the servo tray! Its only held in with 4 bolts on the bottom of the chassis. There are no posts or anything and its all one piece but you still have easy access to anywhere on the tray and you can keep the wires hidden. I still need to finish this point series that I'm in but after that I'll have the engine and electronics fom my Kyosho in this Losi.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 1CE)
       Post #: 60
RE: When will we see the Losi 8ight??? - 9/23/2006 10:26:02 PM
SManMTB
Status: offline
It looks good Dave!
I just need to prepare for tomorrow and then I'll start tooling around with the kit. Very nice that it comes with extra springs and swaybars. I hope I have SAE tools......
       Post #: 61
RE: When will we see the Losi 8ight??? - 9/24/2006 12:09:05 AM
JoeGibbs
Status: offline
Looking good Dave! Bring it out tomorrow and race it. With no engine or electronics, I'm almost certain to beat you!
       Post #: 62
RE: When will we see the Losi 8ight??? - 9/24/2006 1:21:45 AM
1CE
Status: offline
super dave i have to agree: the parts finish isnt great, its good. Its nothing major...just a little extra flashing here and there. my diffs are very nice and smooth but i havent had them sitting that long eather. im happy with it so far. i love the build... god that chassis is thick
(in reply to JoeGibbs)
