Mike Pastro's CT-114 or F-18
Tower Hobbies
Logged in as Guest
Users viewing this topic: Jim_Purcha
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Mike Pastro's CT-114 or F-18 Page: [1] 2 3 4   next >   >>
Login
Mike Pastro's CT-114 or F-18 - 9/18/2006 9:02:36 PM
Jim_Purcha
Status: online
Has anyone built and flown these two 0.40 pusher prop designs by Mike Pastro in RCM magazine? One was the CT-114 Tutor Snowbird and the other F/A-18 fighter jet.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by jpurcha -- 9/20/2006 12:55:01 AM >
       Post #: 1
RE: Mike Pastro's CT-114 or F-18 - 9/22/2006 12:10:40 AM
Jim_Purcha
Status: online
No one has built these models?
(in reply to Jim_Purcha)
       Post #: 2
RE: Mike Pastro's CT-114 or F-18 - 9/23/2006 7:40:38 PM
arp67
Status: offline
If you haven't already, you may want to post this question in a different forum, such as the scale one or even at rcgroups.com in order to reach a broader audience. I own a set of these plans, but haven't built yet.
Andrew
       Post #: 3
RE: Mike Pastro's CT-114 or F-18 - 9/24/2006 12:51:23 AM
Jim_Purcha
Status: online
Thanks Andrew I already posted this to the scale forum, but not rcgroups.com
(in reply to arp67)
       Post #: 4
RE: Mike Pastro's CT-114 or F-18 - 9/25/2006 6:00:44 PM
jimm
Status: online
I built and flew the 40 size F-18. It was a great model, it flew great. The take offs were a bit trickey though with the narrow stance of the main gear as I made mine retractable. Looked great in the air.
Mine crashed due to radio problems of some sort. Started rolling and could not stop it, finally went in.
May build another one sometime.
Jim
       Post #: 5
RE: Mike Pastro's CT-114 or F-18 - 9/26/2006 3:47:50 AM
T45WingNut
Status: offline
my dad build the CT-114 Tutor Snowbird years ago was a good flyer.. i got a set of plans and wing core and stuff to build another one is i get around to it..
(in reply to jimm)
       Post #: 6
RE: Mike Pastro's CT-114 or F-18 - 10/27/2006 9:33:50 PM
MadScientist
Status: offline
I built and flew his A 10. I also saw the article fo the Snowbird, and it looked very similar in construction. My A 10 flew very well and I had a great time building it. Hope that helps
_____________________________
If you didn't build it, it's not really yours
(in reply to T45WingNut)
       Post #: 7
RE: Mike Pastro's CT-114 or F-18 - 10/28/2006 3:21:43 AM
Props4ever
Status: offline
Jim,
I sold one of these F18s many many years ago, i was nice Hornet, since then i have been looking for one but nothing popped up yet.
Ask John in your club, he and few of his friends built pusher Tutors with .45 engines on the tail, it flew awsome at Leamington jet rally earlier in the year....I want one of those too but he dosen't have plans or left over projects that i would tackle on .
Cheers,
Sammy
(in reply to MadScientist)
       Post #: 8
RE: Mike Pastro's CT-114 or F-18 - 11/1/2006 11:58:23 PM
Javier-RCU
Status: offline
Jim
I built and flew the 60 F-18, mine is with a 91VR-DF and 11x7 pusher. Fast and meneuverable. Construction is a lot easy and cheap. Scale looks are fine.
Javier
Click for fullsize
(in reply to Props4ever)
       Post #: 9
RE: Mike Pastro's CT-114 or F-18 - 11/2/2006 1:15:31 AM
CoosBayLumber
Status: offline
Had some problems with the plans on the F/A-18 recently obtained from RCM. Seems they sort of altered the scale factor from sheet to sheet. 'least on the ones I had.
Parts for this A/C are available via Alex.
Wm.
www.mybloo.com/coosbay/laser/laser.html
Thousands of Laser Cut parts, thousands
(in reply to Javier-RCU)
       Post #: 10
RE: Mike Pastro's CT-114 or F-18 - 11/2/2006 1:17:42 AM
Jim_Purcha
Status: online
I recall a couple of months ago on Ebay or was it the Edmonton Radio Control Club site, a F-18 was being sold.
       Post #: 11
RE: Mike Pastro's CT-114 or F-18 - 1/10/2007 6:05:29 AM
Jim_Purcha
Status: online
Does anyone have a copy of the instructions for the F-18?
       Post #: 12
RE: Mike Pastro's CT-114 or F-18 - 1/10/2007 3:33:35 PM
TOMMYSTA
Status: offline
Mike Pastro's .60 size F18 was the prototype for the G&P Sales F18 pusher. Bill Price manufactures these in Washington or Oregon I believe......His is a fiberglass fuse with foam core wings and flies great also.....There was a build thread in the Extreme Speed Prop planes forum.....
Tom
       Post #: 13
RE: Mike Pastro's CT-114 or F-18 - 1/25/2007 3:47:31 AM
Jim_Purcha
Status: online
Making some changes to the design in solidworks. The original design did not have a removable wing. Discussed it with the local club members at the last meeting, pretty much in agreement a bolt on wing would be a simplier design change than a wing tubes. Also less expensive. Still deciding on retracts or not. Only have the sides, top and bottom partially modeled. Need the vertical fins and stab next.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Jim_Purcha -- 1/25/2007 12:56:21 PM >
(in reply to TOMMYSTA)
       Post #: 14
RE: Mike Pastro's CT-114 or F-18 - 12/5/2007 4:47:46 AM
Jim_Purcha
Status: online
December 3,2007
Well, I've decided to build the 0.40 version of the F-18 Hornet. Already have a fuel pump, and a super tigre 0.40 or 0.51 waiting on the shelf. I've built smaller planes from plans before but nothing in the 0.40 size range. This will be fun. Like the others say, start off by creating yourself a kit.
Stay tuned.
       Post #: 15
RE: Mike Pastro's CT-114 or F-18 - 12/10/2007 12:42:32 AM
Jim_Purcha
Status: online
