electric f3A
Tower Hobbies
Logged in as Guest
  Printable Version
Carden 35% Extra 260 - RTF
Seller:  jmiracle
Details:   $2,950.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> TEAM RCU >> TEAM RCU - Chip Hyde! >> electric f3A
Page: [1]
Login
electric f3A - 9/19/2006 4:45:09 PM
underwood
Status: offline
HI CHIP,
could you please advice what set up you are flying in your electric pattern models,IE:motors speed controlers,batteries,chargers etc.this would be a great help,
regards
underwood
       Post #: 1
RE: electric f3A - 9/30/2006 2:12:20 AM
toddblose
Status: offline
underwood,
Chip is on his way to the Master's so I will let you know the set up I am running.
I am running the same set up as Chip. The motor is the Hacker C50 XL 14 comp.
speed controller is the Master 90-O-Acro, Prop is an APC 20 x 15 E
Batteries are Thunder Power TP5300-5S4PLV and the Thunder Powr 1010
charger and TP-210V balancer
Hope this helps
_____________________________
http://toddblose.homestead.com
Team Futaba,FlightPower,Hacker,CA Models,Hobbico, PowerMaster,HydeMounts,ModelGlasses
(in reply to underwood)
       Post #: 2
RE: electric f3A - 10/2/2006 1:42:24 PM
underwood
Status: offline
todd,
many thanks for your reply,it seams very hard to get a direct answer from any one on this subject,i will go with what you guys are using,what flight time are you getting on these flight packs todd???..
regards
underwood.
(in reply to toddblose)
       Post #: 3
RE: electric f3A - 10/13/2006 7:38:06 AM
Passport1
Status: offline
The flight times are 9 minutes. You can go Ten but it works that batts pretty hard. I also would like to add that we have defiantly decided the 13 XL comp motor will actually be a better choice then the 14XL. When I say better, I mean better for all types of wind conditions, not better mechanically. I have know since I first flew the comp motor, that the motors did not have exactly the same performance as a standard motor, but I have never been able to prove that until now. I had been told such things as the contest motor is really a half wind more and that is why the performance was less, as well as the fan has to drag the motor some, but the bottom line is HEAT is the culprit.
The old motors actually were no where near as consistant as the contest motors, because they were not internally cooled. That makes the operating temps from start to finish vary quite a bit more. The heat in turn causes the motor to draw more amps, which in turn causes the increased power, that we had all been getting used to a couple of minutes in to the flight. Personally I thought it was the batts causing this but infact it was the motor itself.
Anyway i have flown the 13xl in both of my models and it put me back to the awesome power I had in 2005 with a milled down 14xl. . I run the 20x15 and it draws around 60 amps. When the wind really blows like at the nats this year you can easily switch to a 20 x13 to get insane power, and then if thats not enough simply go to timing mode 2. I did that in the finals and never had to go above 2/3's throttle. I was the only one there with the 13XL, and it was definantly the most pwerful system.
If you are told upon placing your order that no one uses the 13XL and that the 14XL is the better choice. Please remember what I said earlier about the halfwind increases. I have communicated all of this with Rainer Hacker himself, and believe me half winds are not the difference.
By the way I also recomend the standard 90 AMP controller and not the contest version. The brake is the difference, that is all. If you have any Q's Todd can explain the differences.
Hope this helps.
Chip
quote:
ORIGINAL: underwood
todd,
regards
underwood.
       Post #: 4
RE: electric f3A - 10/15/2006 8:43:18 PM
underwood1
Status: offline
CHIP,
many thanks you have anawered a great deal of questions,and i thank you for that,i will take your advice and order the13xl,the model they will go in is a oxai beryll,sorry chip could not get hold of one of your great planes over in the uk!!.
do you belive it is the end of the YS in pattern,as they are still a great engine,but i would guess to say you would have more consistenet runs with the electric motors,and that is a bonus for consistent flying!!,many thanks again chip!!
regards
underwood.
(in reply to Passport1)
       Post #: 5
RE: electric f3A - 2/15/2007 3:02:12 AM
Malcolm B
Status: offline
Is that steve Underwood there??? Its Malcolm Balfour here not seen you in ages hows things going?? you been flying much??
Malc
Team JR
macgregor industries
(in reply to underwood1)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.859RCU1
