RE: Attaching antenna to plane
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Attaching antenna to plane
Page: <<   < prev  1 [2]
Login
RE: Attaching antenna to plane - 10/25/2006 1:37 PM
ramcfarland
Score: 105
Last Login: 3/4/2010
Status: offline
The DC-3 looks great as to the antenna placement thing:with a aluminum covered R/C aircraft running the antenna on the out side fuselage is a safe bet and or doing a range check first with the antenna routed in the fuselage and then checking to see if there is a change in range with the antenna exiting the fuselage. *
Receiver batteries replaced every 2 seasons works for me as stated further along in this thread. I just replaced my 2700 Ma NM 6v pack even though both fully charged packs register the same under load but again its a safety thing. I have been flying R/C over 3 decades now and have experienced a glitch or radio failure only a couple times.If ever I get the new P.C. up I have a video of a flight where I got several glitches and proceeded to land safely I replaced the radio with a PCM system the problem went away or was it masked..
< Message edited by ramcfarland -- 11/2/2006 1:20 AM >
_____________________________
Fast Richard
Hide Signatures
(in reply to jaka)
       Post #: 26
RE: Attaching antenna to plane - 10/25/2006 1:44 PM
ramcfarland
Score: 105
Status: offline
woops
< Message edited by ramcfarland -- 11/2/2006 1:00 AM >
Fast Richard
Hide Signatures
(in reply to MinnFlyer)
       Post #: 27
RE: Attaching antenna to plane - 10/25/2006 2:49 PM
BillS
Score: 100
Last Login: 2/16/2010
Status: offline
I avoid rubber bands because they end up on the shop floor. “Now where did that come from?” Instead I use elastic from the sewing section at Wal-Mart. It comes in black or white and does not self-destruct like rubber bands.
Bill
Hide Signatures
(in reply to Wblakeney)
       Post #: 28
RE: Attaching antenna to plane - 10/25/2006 4:45 PM
rclement
Score: 100
Last Login: 3/16/2010
Status: offline
quote:
ORIGINAL: buzzingb
There is much more radio interference noise inside the fuse with all the servos (noisy servos)and battery and not to mention all the servo leads and control rods and connectors. No it much better outside. If you ever crash a few you will know what I mean, oh haven't crashed one yet, well just keep flying and your number will come up.
I've had radio interference problems with the ant. being inside the plane. It was on a Twist. There is a tube in the fuse to run the wire through and I couldn't seem to keep the tail servos from glitching untill I removed the ant. from the tube and monokoted it to the bottom of the fuse. It worked fine there. You can get interference inside the fuse, you just have to range check it and make sure it's going to work in there.
The hardest part of this hobby?......waiting for the UPS truck.
Hide Signatures
(in reply to buzzingb)
       Post #: 29
RE: Attaching antenna to plane - 10/26/2006 3:13 AM
FliteMetal
Score: 100
Last Login: 3/18/2010
Status: offline
Something that one should consider is frequency alignment accuracy after X number of years. The radios we use are
acceptable and do a good job, however, they are subjected to a lot of vibration, extreme temperatures, and what a
typical professional industrial radio would consider "neglect". Ever have your system checked out at a manufacturer's
or their authorized service agent's facility? In the vein of power management I chuck my entire set of batteries every
other year...without question regardless of the battery conditioner's latest readout. Crashed receivers need to be
professionally looked at before a life threatening takeoff occurs...;^) Think about that last high G abrupt stop your
onboard flight system encountered. Just a thought, before you find yourself wishing you had your's checked.
< Message edited by FliteMetal -- 10/26/2006 3:15 AM >
Ed Clayman
FliteMetal.com
Hide Signatures
(in reply to rclement)
       Post #: 30
RE: Attaching antenna to plane - 11/1/2006 11:19 PM
allena99
Score: 100
Last Login: 3/14/2010
Status: offline
In recent years, I have run all my antennas inside the fuselage, allowing the excess to trail. But, recently we had a problem with the new Twist 60 with short range check and servo twitching. We traced the problem to the antenna being routed through the fuselage in close proximity to the very long servo extensions needed to reach the rear-mounted rudder and elevator servos. Pulling the antenna out and routing it outside solved the problem.
Hide Signatures
(in reply to FliteMetal)
       Post #: 31
RE: Attaching antenna to plane - 11/2/2006 1:39 AM
FliteMetal
Score: 100
Status: offline
quote:
ORIGINAL: allena99 In recent years, I have run all my antennas inside the fuselage, allowing the excess to trail. But, recently we had a problem with the new Twist 60 with short range check and servo twitching. We traced the problem to the antenna being routed through the fuselage in close proximity to the very long servo extensions needed to reach the rear-mounted rudder and elevator servos. Pulling the antenna out and routing it outside solved the problem.
One thing I want to remind everyone of with respect to long servo leads is to twist the bundle along its length as many times as you can. This creates a magnetic helix "shield" around the wiring which not only keeps emi, it keeps emi within the bundle "field". The standard wire antenna should be fine if it is kept away from the spiral bundle and any down stream battery packs you might have placed into the system in parallel. Always range check on the ground before you start your flying day...assume nothing from the day before.
< Message edited by FliteMetal -- 11/2/2006 1:41 AM >
Ed Clayman
FliteMetal.com
Hide Signatures
(in reply to allena99)
       Post #: 32
RE: Attaching antenna to plane - 8/7/2009 3:26 AM
edmoor
Score: 100
Last Login: 3/17/2010
Status: offline
some people say this is a no no.....but i use antenna bobbins.....keep my antenna inside the fuse......it uses up 18 inches of the length....i havent had any problems.....
if it aint broke...ya aint flyin low enough
Hide Signatures
       Post #: 33
RE: Attaching antenna to plane - 8/11/2009 5:51 AM
Murphey
Score: 100
Status: offline
I keep the antenna neatly rolled up and secured with a twist tie…just like it comes in the box. I have always done it this way and have built MANY planes.
Murphy
Hide Signatures
(in reply to edmoor)
       Post #: 34
RE: Attaching antenna to plane - 8/11/2009 5:51 PM
Tx_RcFlyer
Score: 100
Status: offline
Move over to 2.4GHz radios and this is a non issue.. Now to keep the approx. 90 degree antenna orientation recommended with a 2.4 receiver, I use either small pieces of nyrod or fuel tubing CA'd to the inside of the fuse in the proper orientation...
Cheers,
Ted
Hide Signatures
(in reply to Murphey)
       Post #: 35
RE: Attaching antenna to plane - 8/12/2009 7:40 AM
jimmyjames213
Score: 145
Status: online
for profiles and some kits i run the antenna wire out the wing. on other planes i glue a small, 2-3in long, piece of nyrod/small tube/ect to the bottom of the fuse. then run the antenna along the bottom of the fuse then through the tube. you could also glue it to the top of the tail and run it through that way.
Anything worth doing.............is worth overdoing
Hide Signatures
(in reply to Tx_RcFlyer)
       Post #: 36
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
