chuck l
FL, USA Status: offline
quote:
ORIGINAL: chuck l I have a checking question on balancing the 232g. I've been flying the plane with the cg set at the middle of the recommended range, and she is just too squirely. I'm moving the cg to the front of the recommended range as suggested in early posts and the review. It needs 7oz of weight on the engine box to balance and I'm wondering if anyone else has needed that much weight. DL50 with a Bison wrap around muffler, one A123 battery for ignition/Rx mounted on the firewall, and nothing else different. Ok, I was wrong! I made a 7oz weight and went to attach it to the motor box. Turns out the ignition/Rx battery is mounted to the back side of the wing tube, not on the firewall as stated earlier. Anyway, I decided to go ahead and mount the 7oz weight and if the handling is better, I'll move the ignition/Rx battery on to the firewall and shed most of the 7oz.
