RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Cap 232G - 27
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> 3D Flying! >> RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!!
    Page: <<   < prev  4 5 6 7 8 [9] 10 11 12 13   next >   >>
    Login
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/7/2007 4:58:48 AM
    OzStriker
    Status: offline
    Instructions say the servo arm on the aileron servos should face the wing root.
    This would make a rather strange angle for the pushrod from servo to control surface, it looks to line up much more square if I use the servo arm towards the wing tip.
    Has anybody else come across this?
    (in reply to apj04)
           Post #: 201
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/7/2007 1:43:32 PM
    FlyguyXII
    Status: offline
    yes put the servo arm toward the wing tip.
    I plan on starting construction on Cap #2 in a week or so ill try to post some pics of things i changed on this one as i go. Cap #1 unfortunatly went in a week ago.
    (in reply to OzStriker)
           Post #: 202
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/8/2007 5:58:16 PM
    smokedat
    Status: offline
    sorry for the loss. What happened was it mechanical failure, radio glitch ???
    (in reply to FlyguyXII)
           Post #: 203
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/9/2007 2:22:50 AM
    telejojo
    Status: offline
    Just bought one and think I'm going to put an OS 160 in it and go fly...........
    (in reply to smokedat)
           Post #: 204
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/9/2007 9:14:09 PM
    FlyguyXII
    Status: offline
    Nope it was dumb thumb its all repairable. A friend of mine was flying it and did a high rate spin low to the ground and got it into a snapping situation when he came out of it and ended up snapping it into the ground. Luckily it landed in a level attitude and all it broke was one elevator half the motor box and ripped the landing gear off of it and put two holes in the bottom of the wing and broke a couple ribs as well as a couple of glue joints in the fuse. All in all its repairable. but my friend felt bad and replaced the airframe for me. I have less then a month to get this thing back in the air and trimmed out for IMAC. Problem is im in the middle of a move. The engine is at DA right now getting checked out hopefully it will get a clean bill of health.
    (in reply to telejojo)
           Post #: 205
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/16/2007 10:26:07 AM
    OzStriker
    Status: offline
    Maidened my Cap 232G today.
    It is my first large scale aeroplane, specs as follows:
    DA-50R
    Slimline Pitts-style muffler
    Truturn spinner, non-drilled out backplate
    Bolly wood 22x8
    HS-5985MG x4
    HS-5055TG x1
    HS-225MG x1
    Fromeco 2600 + 5200mAh LiIon's through Regulators at 6V.
    I set up rates as per instructions, CG towards fwd part of recommended range, total weight 7.7kg, I did not add any additional weight, my LiIons sit inside motor mount box.
    The engine ran beautifully and has a lovely sound, on low rates I found the ailerons very sensitive, with 25% expo on all channels.
    It flew very nicely with plenty of power, ground handling excellent as expected for a larger aircraft, big prop provides excellent drag making landings way easier than a standard glow 2-stroke model.
    The CG could move aft but I will not rush into moving it.
    I like this aeroplane, if anyone wants any pics I will take some but it just looks like everybody elses
           Post #: 206
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/17/2007 2:08:30 AM
    smokedat
    Status: offline
    good to hear on ur maiden ozstriker. Im still to maiden mine im waiting on the 2.4 gig. stuff.
    Can u post a video??
           Post #: 207
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/17/2007 7:12:00 AM
    OzStriker
    Status: offline
    I will see if I can get some video.
    I have gone Spektrum, so far no problems whatsoever in this thing or my Raptor 90SE heli.
           Post #: 208
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/17/2007 5:46:46 PM
    jzinckgra
    Status: offline
    Did you guys get a stick on instrument panel with your Caps? I didn't.
    _____________________________
    http://www.rcflyr.com
           Post #: 209
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/17/2007 9:44:06 PM
    OzStriker
    Status: offline
    Nope no instrument panel, only fly in daylight
    (in reply to jzinckgra)
           Post #: 210
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/18/2007 12:44:45 AM
    FlyguyXII
    Status: offline
    I didnt but i can tell you where to get a really nice one!!! SAC midwest made me a custom panel call them and ask for the new H9 cap 232 panel it looks really good ill post pics as soon as i can
    http://www.sacmidwest.com/
    < Message edited by FlyguyXII -- 5/18/2007 12:45:48 AM >
           Post #: 211
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/18/2007 12:56:27 AM
    exeter_acres
    Status: online
    I'll admit it... I was the plane wrecker.... the plane REALLY flew nicely... but I just got it in a weird spot...inverted harrier.. a bit too low...pulled too hard and smack......
    This thing is nice.. very stable.. draws nice lines for IMAC, and super stable in high alpha stuff.....
    Flyguy, hope the "re"build is going OK...
    You shooting for Jackson?
    I would like to earn your vote for IMAC Southeast Regional Director
           Post #: 212
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/18/2007 9:59:37 AM
    OzStriker
    Status: offline
    Guys there isn't a great choice of pilots in Australia, can I please have some help choosing a pilot for my Cap
    I think this guy is too big, and my partner thinks he is a bit nerdie:
    http://cgi.ebay.com.au/Great-Planes-Pilot-Civilian-1-3-scale_W0QQitemZ300111673275QQihZ020QQcategoryZ34056QQrdZ1QQcmdZViewItem
    Is this cool dude too small at 3 1/4"?
    http://cgi.ebay.com.au/Slimline-Pilot-Xtreme-Curt_W0QQitemZ300111667305QQihZ020QQcategoryZ34056QQrdZ1QQcmdZViewItem
    Finally there are these two which look like close to the right size, around 100mm / 4inches high though my partner dislikes the sunnies on green shirt man:
    http://cgi.ebay.com.au/Pilot-Head-Mr-Red_W0QQitemZ300110775945QQihZ020QQcategoryZ84444QQrdZ1QQcmdZViewItem
    http://cgi.ebay.com.au/Pilot-Head-1-4-scale-with-green-shirt_W0QQitemZ300110776234QQihZ020QQcategoryZ84444QQrdZ1QQcmdZViewItem
    Thanks for helping me shop for pilots
    P.S. If it is a nice day tomorrow I will get some video.
    < Message edited by OzStriker -- 5/18/2007 10:01:12 AM >
    (in reply to exeter_acres)
           Post #: 213
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/18/2007 11:28:20 PM
    gnirwin
    Status: offline
    that second guy is a maniac, he wrecked a really nice plane of mine last summer.
    even a nut can find a blind squirrel every now and then
           Post #: 214
    RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!! - 5/19/2007 12:44:03 AM
    zenairplane
    Status: offline
    Here is the instrument panel I am using in my new CAP 232g. I made it from a photo of an actual CAP cockpit. The first one is generic and the second one has some decals on it. I just printed it out on heavy photo paper and glued it on. It looks great with the Canopy on.
    I just need two more servos and it will be ready to go.
    Have fun.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    (in reply to gnirwin)
