RE: YT KMP Hawker Typhoon
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: YT KMP Hawker Typhoon
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: YT KMP Hawker Typhoon - 4/20/2007 4:44:54 AM
nemesis4u
Status: offline
OK THEN.... a few more....
CENTER SECTION TOP VIEW,,,,, and CENTER SECTION SPLIT FLAPS...
WHODAMAN "DAVE" I will approximate the wing without the joiners and get us a measurement!
Standby!!!
-TOMAS
www.vqwarbirds.com
VQ/ KMP/ RCV DEALER
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by nemesis4u -- 4/20/2007 4:45:45 AM >
_____________________________
R/C WARBIRDS / RC TANKS ENTHUSIAST
VQ WARBIRDS, KMP, & RCV
(in reply to xtraflyr)
       Post #: 51
RE: YT KMP Hawker Typhoon - 4/20/2007 5:17:45 AM
nemesis4u
Status: offline
WhoDaMan, XTRAFLYER, Et al..... Audience will grow very soon!!! I can feel it!!
I measured the wing and YES SIR!! IT IS 72.5- 73" ... I did not install the wing joiners... BUT I held the wing together and shot a photo after showing a tape measure..
I HAVE TONS OF REAL KMP TYPHOON PRODUCTION PHOTOS coming TONIGHT!!!!!!! GET SOME CAFFIENE!! THEY ARE COMING in the next 1/2 hour...to hour.....
I NEED TO SHOOT THE FUSE and some other small MISC parts... MY wife is going to kill me for keeping us up late .... I will have to make it up to her hehehe
-TOMAS
VQ / KMP / RCV DEALER
www.vqwarbirds.com
info@vqwarbirds.com
< Message edited by nemesis4u -- 4/20/2007 5:18:26 AM >
(in reply to nemesis4u)
       Post #: 52
RE: YT KMP Hawker Typhoon - 4/20/2007 6:15:27 AM
nemesis4u
Status: offline
OK..... Here comes the PHOTO FUN !!!!!!!!!!!!
FIRST PHOTS SHows THE "CASE" the KMP HURRICANE COMES PACKED IN!! IT IS A REALLY STRONG HARD CARD STOCK BOX!! A CASE THAT I WILL USE OVER AND OVER until it goes bad.... tough finding such a nice box!!!
Next... LID COMES RIGHT OFF TO REVEAL some goodies... WHEELS, RETRACTS, STRUTS are all packed in a separate box and then glued into a corner of the CASE..
3rd through 5th PHOTOs... WING... out on the blue sheet..... It is 72.5- 73" wingpspan... I checked the tape measure thrice!!!
6th through photos Show all the fine details molded into the Composite fiberglass, wood , ply structure.... CHECK out the hinging method, and trailing edge cover, fairing for the ailerons, 4 section split-flaps etc.... ALL MARKINGS ARE PAINTED ON!! or are wet transfers!!!
The composite structure is great!!! Very Impressive Workmanship!!
MORE COMING keep drinking your caffiene!!!
-TOMAS
VQ WARBIRDS / KMP / RCV ENGINE DEALER
www.vqwarbirds.com info@vqwarbirds.com
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 53
RE: YT KMP Hawker Typhoon - 4/20/2007 6:20:17 AM
nemesis4u
Status: offline
OK... More...
So besides the retracts, oleo struts, aluminum hub wheels/tail wheel You even get aluminum landing gear door/strut mounts!!!! HOW COOL!!!!!!!!! no tinkering around here... you get all the goods!!!!
STILL MORE COMING stay up with us!!!
-TOMAS
Click for fullsize
Click for fullsize
       Post #: 54
RE: YT KMP Hawker Typhoon - 4/20/2007 6:22:21 AM
nemesis4u
Status: offline
Canopy... OK here are a few canopy shots for ya!!
Note the rudder and details molded into the Rudder..... trim tab, ribs etc....
-TOMAS
Click for fullsize
Click for fullsize
       Post #: 55
RE: YT KMP Hawker Typhoon - 4/20/2007 6:26:46 AM
nemesis4u
Status: offline
More of those RUDDER DETAILS...
Now more fun in the detail dept.....
ARE YOU GUYS HAVING FUN???????????? I AM!!!!!!!!!!!
Here are the horizontal stabs... they use the aluminum tube center spar design for attachment to the fiberglass/composite FUSE..
Again ,,,panel lines and good pin hinges used throughout!!!
-TOMAS
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 56
RE: YT KMP Hawker Typhoon - 4/20/2007 6:31:17 AM
nemesis4u
Status: offline
EXHAUST Pipe/ STACK GOODIES!!!!!!!!!!! THEY mount to a piece of light ply (unpainted...no complaints about this unpainted wood piece that is inside the cowling here!! THE KMP ELVES had to leave somethings to us modelers!!!!!!!)
Again my lovely wife took the photo while she had me "hold" the cowling to show a great angle of where those exhaust pipes will exit!! hahahahaahha!!! The Cowling fits me quite well!!!!!!!!!!!! I think it is quite becoming of me!!!
-TOMAS
Click for fullsize
Click for fullsize
       Post #: 57
RE: YT KMP Hawker Typhoon - 4/20/2007 6:37:23 AM
nemesis4u
Status: offline
OK... NOW ... . DRUM ROLL Maestro!!!!!!!!!!!!!!
HERE IS THE FUSELAGE...... Lots of room... PUSHRODS ALREADY INSTALLED.... THIS IS EXACTLY HOW IT LOOKS OUT OF THE WRAPPER!!!!!!!!!!!!!
LOADS of panel lines, rivets, curves, buldges etc.... nice fillets.... They are using a strong adhesive for the formers...NO HOT GLUE!!!
This adhesive reminds me of a 2 part epoxy used on my Y/A P-47 ... I forget the name of the German Adhesive... It is strong!!!!
Note the "cooling ducts" prototypical of the TYPHOONS!!! I like the nose art.....
-TOMAS
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 58
RE: YT KMP Hawker Typhoon - 4/20/2007 6:45:37 AM
nemesis4u
Status: offline
Some shots of the detailed markings.... Hope they come out clear.... Getting a little too excited ...hands were shaking!!!!!!
ALSO shots of the Fuselage from the vertical stab area... and with the cowling just barely set in approximation for good dreaming!!!!
I will be flying this one on missions tonight!!!!! Going to bust up some AXIS Panzers, and King TIGERS!!! Watch out Richard L.... Hide your AXIS TANKS!! THIS TYPHOON is coming after them!!!!! RAT a TAT..... Firing Rockets!! BOOM!!!!!!!!!!!!!!!
TOMAS
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by nemesis4u -- 4/20/2007 6:47:53 AM >
       Post #: 59
RE: YT KMP Hawker Typhoon - 4/20/2007 6:54:24 AM
nemesis4u
Status: offline
OK .... LAST PHOTOS FOR TONIGHT.... I mean this MORNING... IT is early morning here in Texas....
should be flying with Snoopy right now....
THESE photos show the interior formers for mounting your radio gear, as well as a shot down the inside of the fuse.... shows pre-installed pushrods.. and also shown is the interior firewall/fuel tank area.... sorry about the side shot.... I will correct it tomorrow night...
If you guys and gals need anything let me know!! I will be happy to assist you!!!
http://www.vqwarbirds.com/aircraft.html
=CHEERS!!
TOMAS
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by nemesis4u -- 4/20/2007 6:59:26 AM >
