smokinT
ID, USA Status: offline
Update... Took it to the field today. Read the instructions (again) and found out that from the factory the idle screw was out 2 turns, not the 1 turn per instructions. Put it at 1 turn out and fired it up. At 2 1/2 turns out with heat on APC 13 x 6 ~ 7,500 rpm. 2 turns out ~ 8,000, 1 1/2 turns ~ 9,000, 1 1/4 turn ~ 10,000. Any further and no rpm gain. OK transition, improved after went in another 1/8 turn on the low speed needle. Flew twice with cowl off. Visible smoke trail and decent throttle response but not unlimited vertical. Will pull this 6.5# Cap about 200 feet up and then poops out. Going to fly this setting for a while then maybe lean it out some more.
