fizzwater2
KS, USA Status: online
are the plugs coming out dry and sort of burned looking, or are they slightly oily and just distorted? Take a good look at the plugs, see what they're telling you. I think High Plains had a post a while back about reading plugs, a skill learned in Formula 1 racing where it was normal to burn a plug a flight.. you could read the plugs and get clues about your compression, needle setting, etc. You might search a little for that, see if it helps any. Have you swapped engines on this plane, using the same tank and fuel line setup? If the other engines run fine, that might help rule out fuel tank problems. Maybe there's an air leak under your carb on this engine?
_____________________________
no matter where you go, there you are..
