RE: 50cc QB 260 build thread
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: 50cc QB 260 build thread
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: 50cc QB 260 build thread - 1/7/2007 3:18 AM
mikec3d
Score: 100
Last Login: 5/14/2009
Status: offline
I apologize about the mis print @ the stock versus CF LG. My readings were stock- 9oz, CF- 6.5oz, for a diff of 2.5oz ..... I used JR 8611A's all @ , Futaba 3150 on THR. Big tank, 2400mah, 4800 mah Fromeco w/ regs, ALL STOCK HARDWARE. You can deffinitly use lighter servos, batt's and reg's, smaller tank, plus all the other stuff I mentioned, plus remove some excess material from the airframe, I beleive it would be scary close to breaking the 15.00 mark... JMO.
Hide Signatures
(in reply to bodywerks)
       Post #: 251
RE: 50cc QB 260 build thread - 1/10/2007 2:33 AM
Grelker
Score: 100
Last Login: 3/21/2010
Status: offline
Just a note, guys. If you purchase the GraphTech CF gear, you will not be able to reinstall the gear cover.
_____________________________
Jon N.
Hide Signatures
(in reply to mikec3d)
       Post #: 252
RE: 50cc QB 260 build thread - 1/11/2007 6:19 PM
SuddenSam
Score: 100
Last Login: 3/8/2010
Status: offline
I got the 50cc Extra 260 for Christmas and was really impressed with the quality of the plane. This is what I plan to use for hardware:
4 SWB 1.25” Half Arms for Elevators and Ailerons
1 Smart Fly 10 Channel Power Expander
1 Smart Fly Ignition Cutoff
3 Fromeco Peerless 2400 mah batteries
4 Hitec 5245s for Elevators and Ailerons – do these servos have enough torque at 6 volts for this plane?
1 Hitec 5955 for Rudder
Carbon fiber spinner, landing and tail gear
I have an Evolution 58GX2 which I had planned to use but I am not sure if this is a good choice. In order to mount the engine so the prop back plate is at the correct distance I have to enlarge the hole in the firewall to 3”. The actual mounting bolts are just a little outside of where the DA50 would mount but I am taking quite a bit of firewall away. The other thing is that the high and low needles for the carb end of right at where the card goes through the firewall so adjusting the needles will be problematic.
I don’t have the funds right now to purchase a DA50 and don’t think I will for the start of the flying season but I hate to chop up the firewall and find out the Evolution is more engine than the plane needs plus I fear there may be a balancing issue.
Any thoughts?
Hide Signatures
(in reply to Grelker)
       Post #: 253
RE: 50cc QB 260 build thread - 1/11/2007 7:29 PM
sp2pilot
Score: 100
Last Login: 1/10/2008
Status: offline
My QB 50cc 260 is powered with a BCMA G62 that is quite a bit more powerfull then the Evo or the DA 50 and the plane loves power.
You will ove this plane
Hide Signatures
(in reply to SuddenSam)
       Post #: 254
zope_pope
Score: 105
Last Login: 3/9/2010
Status: offline
Hey man,
You'll love the plane, however, DO NOT USE the 5245's. They are mini servos and not only will they not fit into the stock locations, they don't have near the torque required. You want around 180 oz in on all surfaces. Let us know how she turns out. See ya.
If you choose not to make a decision, you have still made a decision.
Hide Signatures
       Post #: 255
RE: 50cc QB 260 build thread - 1/11/2007 7:43 PM
reyn3545
Score: 100
Status: online
A lot of folks (including me) have used the 5245's for the throttle, to minimize weight, and a lot of people (including me) have had problems with these servos. It seems that some of them fail very early in life (the first minute or so). If they don't fail then, they seem to work fine, but zope pope is right... don't use them on the control surfaces. They won't fit the mounts and they don't have enough torque.
Waco Brotherhood # 153
Hide Signatures
(in reply to zope_pope)
       Post #: 256
RE: 50cc QB 260 build thread - 1/11/2007 7:44 PM
SuddenSam
Score: 100
Status: offline
quote:
ORIGINAL: zope_pope
Hey man,
Missed type - the servos are actually 5645's but they are only rated at 168oz at 6volts so I guess I will need to go to the 5985s. I have 3 more 5955s that if I bought 1 more I could use but that seems like overkill.
Hide Signatures
       Post #: 257
RE: 50cc QB 260 build thread - 1/11/2007 7:46 PM
xed
Score: 100
Last Login: 8/19/2009
Status: offline
The 5645s will be just fine for the Ailerons and Elevators if you aren't going to be doing any crazy walls or bledners and stuff like that..
Hide Signatures
       Post #: 258
RE: 50cc QB 260 build thread - 1/11/2007 7:50 PM
SuddenSam
Score: 100
Status: offline
quote:
ORIGINAL: xed
I have a long way to go before I will feel comfortable enough to do those maneuvers on anything other than my simulator
Hide Signatures
(in reply to xed)
       Post #: 259
RE: 50cc QB 260 build thread - 1/11/2007 7:54 PM
zope_pope
Score: 105
Status: offline
This airplane walls so nicely though. Really, walls are easy maneuvers with the right setup. I am using 5985's and loving it. Now if the snow would just melt....
Hide Signatures
       Post #: 260
RE: 50cc QB 260 build thread - 1/16/2007 1:49 PM
SuddenSam
Score: 100
Status: offline
quote:
ORIGINAL: zope_pope
I decided to go with 5985's and I ordered a DA-50 to power the plane. I didn't like the fact that I couldn't get to the high speed needle on the Evolution 58 when it was mounted to the firewall with the prop back plate at the correct distance from the firewall. I would have had to move the motor forward or backwards almost 1/2 inch to be able to get to both needles. Niether option was desirable.
I went with CF landing gear, wing and stab tubes, plus a CF spinner so the plane will come out on the light side and the extra power the 58 provides just wouldn't be necessary.
The motor and servos will be here on Thursday so I will be able to finish the plane this weekend although the forcast is for snow and temps in the teens so I don't think I will be doing the maiden anytime soon.
Hide Signatures
       Post #: 261
RE: 50cc QB 260 build thread - 1/16/2007 2:34 PM
bodywerks
Score: 100
Last Login: 2/5/2010
Status: offline
quote:
ORIGINAL: Grelker
Not without modifying it, but you most definitely can reinstall it after modification.
STRAIGHTEN UP AND FLY LIGHT!!!
Hide Signatures
       Post #: 262
RE: 50cc QB 260 build thread - 1/16/2007 3:05 PM
SuddenSam
Score: 100
Status: offline
quote:
ORIGINAL: bodywerks
quote:
ORIGINAL: Grelker
I jsut took a block of scrap balsa that was just about the right thickness, drilled lightening holes in it, shimmied it, and convered it wih some of the spare covering provided. It only took me about 15 mintues to do and it looks good. I thought about modifying the one that came with the plane but it looked like it would take me a lot longer to modify than to build a new one.
Hide Signatures
       Post #: 263
RE: 50cc QB 260 build thread - 1/17/2007 7:19 PM
M64
Score: 110
Last Login: 11/17/2009
Status: offline
Hey guys
Is the rudder servo a 5kg servo? does the antenna run through the fuse?
M64
You can't change what you don't acknowledge.
Hide Signatures
       Post #: 264
RE: 50cc QB 260 build thread - 1/18/2007 12:32 AM
zope_pope
Score: 105
Status: offline
24kg cm torque on the rudder servo. The antenna does run through the fuse, but not easily. I spent 2 hours with baby powder and my antenna trying to get that through.
Hide Signatures
(in reply to M64)
       Post #: 265
RE: 50cc QB 260 build thread - 1/18/2007 2:29 PM
M64
Score: 110
Status: offline
Does the plane come with the holes in the fire wall and on top of the box thing?
How do you put the 2 tanks in? in otherwords where does the smoke tank go?
M64
Hide Signatures
       Post #: 266
RE: 50cc QB 260 build thread - 1/18/2007 3:11 PM
sp2pilot
Score: 100
Status: offline
Both tanks mount in the same tray just on their sides I Imagine with both tanks full the CG is going to be very nose heavy at take off.
I just did a minor re-kit on my Extra and decided to mount my fuel tank under the wing tube centered below the ballance point. That way the CG will always be nuetral regardless of fuel load. I don't run cans or a tuned pipe so the tunnel was not in use.
Hide Signatures
(in reply to M64)
       Post #: 267
RE: 50cc QB 260 build thread - 1/18/2007 6:47 PM
M64
Score: 110
Status: offline
Sp2pilot can you post some pics of that setup so I can get a better idea of what it looks like?
M64
Hide Signatures
(in reply to sp2pilot)
       Post #: 268
RE: 50cc QB 260 build thread - 1/30/2007 2:55 AM
Grelker
Score: 100
Status: offline
Has anybody had to put downthrust into the plane? I checked yesterday with a 22x8 Xoar prop (10th flight) that I had the symptoms of not enough downthrust.
Jon N.
Hide Signatures
(in reply to M64)
       Post #: 269
RE: 50cc QB 260 build thread - 1/30/2007 3:46 AM
zope_pope
Score: 105
Status: offline
Thats interesting. Mine acts like it has too much downthrust.... QC problem? Too much snow for me to start to fix it, but mine always seems to fly nose high.
Hide Signatures
       Post #: 270
RE: 50cc QB 260 build thread - 1/30/2007 1:31 PM
Grelker
Score: 100
Status: offline
That sounds like you need downthrust too. You can check be either flying along straight and level, then chop the throttle. If it needs downthrust, the plane will rise when it slows down. You'll know if it does, it's quite remarkable. That's the test I did and there was no question. Another check is to pull up vertical in front of you, watch which way the plane pulls as it slows down, if it pulls to the canopy, needs more downthrust.
Jon N.
Hide Signatures
       Post #: 271
RE: 50cc QB 260 build thread - 1/30/2007 7:16 PM
zope_pope
Score: 105
Status: offline
Well mine flies nose high to maintain level flight at all power settings. when the power is killed it will start to climb.
Hide Signatures
       Post #: 272
RE: 50cc QB 260 build thread - 1/31/2007 12:40 AM
Grelker
Score: 100
Status: offline
You need more downthrust too. I'm going to put in a little bit more and I'll let you know what works.
Jon N.
Hide Signatures
       Post #: 273
RE: 50cc QB 260 build thread - 1/31/2007 1:54 AM
SuddenSam
Score: 100
Status: offline
How far back from the prop backplate shoud the front of the cowl be? I have my DA-50 mounted with 2 1/2" standoffs and there is a 3/8" gap which seems like a lot.
Hide Signatures
       Post #: 274
RE: 50cc QB 260 build thread - 1/31/2007 2:03 AM
reyn3545
Score: 100
Status: online
Its really just a matter of taste.. won't have any effect on the plane... but you might think about moving the cowl out or going to 1/4 inch shorter standoff.
Hide Signatures
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
