ADChobbystore
CA, USA Status: offline
I agree to a point. But you really can't compare the AeroAce to any of the Hobby company "real planes". The AeroAces are built to be bulletproof so 6 year old kids can beat the hell outta them and they just keep right on flying. They are more of a toy than a hobby. And there is much less material and actual moving parts and electronics, so they may have the extra 5 minutes to check out each plane because their profit margins are likely higher, and based on shear quantity. Now, yes, the HobbyZone or whatever people are most likely base on quantity as well, but the plane you get from them is much more complicated, many more moving parts and electronics and therefore more room for problems. Plus, you now have a plane that is an actual "hobby" and not a toy. So you have to expect things are not always going to be peachy. I had similar things happen with my first plane. Waited forever to finally get into the hobby, and the thing lasted about 10 feet in the air, them plummeted to the ground. It too was an RTF kit. and the electronics just gave out, no control what so ever. I was determined to stick with the hobby, so I figured I would cut my losses and get all Futaba radio equip. The plane flies fantastic now. Unfortunately you kinda get what you pay for with the RTF stuff. For an extra $100-$120 or so you can get the aftermarket radio, battery and motor. But still, this is a hobby and things are going to happen. How is your antenna wire routed? And the antenna on the TX is completely up when you are testing correct? Do you still have the stock battery connectors on everything? Those Tamiya connectors are worthless in my opinion and could be forming a bad connection. You may need to try and switch those out to Deans Ultra.
_____________________________
"All About The WATTS!!!" adchobbystore.com
