Flabum
Land and Sea made a blower for 2 cycle outboards for years, and it worked very well. Doing it on such a small scale would be difficult because fuel metering would have to be quite precise to keep from burning up a motor. If it did come about, you would prob spend half a day getting everything set before you could get a good reliable run, then you need to hope the atmospheric pressure or ambiant temp doesn't change much, not to mention regulating the cooling system, keeping clean, dry air supplied and maintaing a proper boost.
_____________________________
" I meant to do that"
