JettPilot
Joined: 4/18/2005 From: Paradise, USA Status: offline
quote:
ORIGINAL: DarZeelon Wilson, At least at first glance, it wouldn't work. While glow four-stroke engines use fuel that has 20% oil mixed into it and most (non YS) receive their bottom end lubrication through the huge amounts of oil in the blow-by gasses (YS engines flow all their fuel through the crankcase), all small gas four-stroke engines have an independent lubrication system. It could be with, or without an oil-pump (like a Briggs & Stratton), but it needs the oil 'sump' at a certain location, so oil can be picked up and used for lubrication. Large engines in full-size aerobatic planes, like the Lycoming AE series of engines, use an elaborate lubrication system, to provide the engine with a constant oil supply at all flight attitudes. This would be too expensive to utilize in any affordable, four-stroke, gas model engine. You are wrong on several points. The Honda small 32CC 4 stroke has a very simple oil system that works in any attitude. There are also some cheap 4 storke gas engines out there that did not go to the trouble of putting an oil system in the motor, and they mix the gas and oil just like a 2 stroke JettPilot
_____________________________
THE TRUTH ABOVE ALL ELSE...
