supertib
quote:
ORIGINAL: SAVAGEJIM After reading many magazines and HP and torque outputs, the only outputs I trust are those printed in X-treme RC. They fctor in just about everything to give you real world HP and torque numbers. The beautiful thing about them is they do not use the exagerated oupt numbers, they use SAE corrected outputs! XRC is in my opinion reliable becuse they print as many conditional factors as possible. Even though SAE correction does not factor in the fuel, pipe, or plug used, XRC does list these things also. Nitro engine advertisers do not advertise BHP (brake HP), which includes internal friction (or brake HP loses from the friction of the parts inside the engine). They do not even dare to use SAE correction since an engine advertised at 3HP in reality would make about 1.4 or 1.5 BHP. I'm not sure, but I think they might even exagerate their ideal HP and torque numbers even more all for the purpose of sales. Anyways, without any further delay, XRC tested the D30M and its peak output is 1.58BHP @ 25000RPM and 67.99oz-in @ 21750RPM (of course, SAE corrected!). They used 30% nitro fuel with 12% oil content. They used a BK test pipe. They used a standard STS plug (I didnt know STS also made glow plugs!). Though these numbers are no where near advertised outputs of other engines, but if we convert these numbers into advertised HP, I bet the D30M is good for at least 3.5 advertised HP. Jim the whole XRC test was useless.......... as they tested with all 4 head shims and a clearance of 1.1 MM.............. so in the test the motor was makingnowhere near its real power.
_____________________________
seeing is believing !
