RE: Giant Delta...has it's OWN site now...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Giant Delta...has it's OWN site now... Page: <<   < prev  2 3 4 5 6 7 8 9 10 [11]
Login
RE: Giant Delta...has it's OWN site now... - 4/5/2010 7:33 AM
Wingspam
Score: 100
Last Login: 5/18/2013
Status: offline
What ever happened to Crazy herb? I would like to see this thread revive it's self..
_____________________________
Wingspam
Hide Signatures
(in reply to Wayne H)
       Post #: 251
RE: Giant Delta...has it's OWN site now... - 4/5/2010 8:55 PM
BMatthews
Score: 247
Last Login: 5/14/2013
Status: offline
He must have moved on to other things.
And Wayne, your delta looks great. But definetly nicer than the whole "Slab O' Foam" concept that Herb started with this thread. YOU MADE IT TOO NICE! ! ! !
Sadly CH's website is no more and that's where the "plans", such as they were, were located. If the Giant Delta is to carry on someone will need to parse through all the early posts for hints on the sizes of the parts and redo the plans.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to Wingspam)
       Post #: 252
RE: Giant Delta...has it's OWN site now... - 8/20/2010 7:43 PM
weskel
Score: 100
Last Login: 1/4/2013
Status: offline
Well, I havent been on in a long while, my giant delta is still hanging from the cieling (for the past 4 years) unfinished. I have decided it is time to bring it down and finish it, I may have to pressure wash the dust off first.
I'll let you guys no how it goes.
I need to figure out how to figure the CG on this thing though, I know there was a link on one of the many posts on this forum posting, I will just have to find it.
I can crash any plane out there, Guaranteed!!!
Hide Signatures
(in reply to BMatthews)
       Post #: 253
RE: Giant Delta...has it's OWN site now... - 8/21/2010 1:55 PM
Wayne H
Score: 100
Last Login: 5/17/2013
Status: offline
I've had the best performance with the C/G at 22" from the rear of the Delta wing, not the elevons. The original plans state 20 - 24" from the rear of the wing. The updated plans with the simi airfoil state 20-22" from the rear of the wing.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Wayne H.
Hide Signatures
(in reply to weskel)
       Post #: 254
RE: Giant Delta...has it's OWN site now... - 8/21/2010 2:01 PM
Wayne H
Score: 100
Status: offline
C/G Calculator
Wayne H.
Hide Signatures
       Post #: 255
RE: Giant Delta...has it's OWN site now... - 9/19/2010 9:15 PM
weskel
Score: 100
Status: offline
Well after 6 years of hanging from the cieling inthe garage I finally got some work done to the Delta.
alot of sanding, filling, sanding, priming, sanding, filling, and more sanding I have it primed and ready for paint.
Still some areas that could use more filling and sanding but I am done with that stage.....
Hopefully painting the underside today.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 256
RE: Giant Delta...has it's OWN site now... - 9/20/2010 3:55 AM
Wayne H
Score: 100
Status: offline
Weskel that looks great. What are you planning on powering your Delta with? Keep the pictures coming.....
Wayne H.
Hide Signatures
       Post #: 257
RE: Giant Delta...has it's OWN site now... - 9/20/2010 3:41 PM
weskel
Score: 100
Status: offline
I have an almost new supertiger 90 that I will use.
I painted the bottom yesterday with some left over polyurathane paint I had from a full size aircraft.
I am painting it white on top and bottom and then adding some detailing.
After seeeing how the bottom turned out I will have to do a little more work on the top before I paint it, I want the top to really shine.
Hide Signatures
       Post #: 258
RE: Giant Delta...has it's OWN site now... - 9/21/2010 5:55 AM
Wayne H
Score: 100
Status: offline
Sounds like it will have plenty of power. What size prop will you be using? I power my GD with a Tower Hobbies .75 using a 13X6 APC prop and it scoots pretty good.
Click for fullsize
Click for fullsize
Click for fullsize
Wayne H.
Hide Signatures
       Post #: 259
RE: Giant Delta...has it's OWN site now... - 9/29/2010 5:47 PM
petronio
Score: 100
Last Login: 5/2/2013
Status: offline
Thanks BMatthews, I have opened a new thread in the rc gliders & slopers section, hope thats ok. Tx
the direct link:
http://www.rcuniverse.com/forum/m_10035191/tm.htm
Hide Signatures
       Post #: 260
RE: Giant Delta...has it's OWN site now... - 1/15/2011 1:01 AM
weskel
Score: 100
Status: offline
Hello,
Finally around to finishing it up, it is complete except for balancing and setting control throws.
I am concerened with the weight though and the CG, it weighs 14 Lbs without balancing.
Mine is smaller than the blue prints, mine is 37" long with a WS of 73 inches.
Using the CG calculator from the link above putting in a 29% MAC it shows it should be 19.2 inches from the nose, or to make it easier 17.8 inches from the rear, does this sound about right???
And do you think a 2 stroke 90 will even get this beast off the ground????
I will post pictures in a few....
Hide Signatures
(in reply to petronio)
       Post #: 261
RE: Giant Delta...has it's OWN site now... - 1/15/2011 1:09 AM
weskel
Score: 100
Status: offline
Pics
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 262
RE: Giant Delta...has it's OWN site now... - 3/31/2011 7:53 PM
Wayne H
Score: 100
Status: offline
Weskel,
Have you flown your GD yet? I've been waiting for a flight report.
Wayne H.
Hide Signatures
       Post #: 263
RE: Giant Delta...has it's OWN site now... - 4/2/2011 5:50 AM
91shadowrider
Score: 100
Last Login: 11/7/2011
Status: offline
Any body wana post some step by step build pics?
Remember When Flying low and inverted down is up and up is expensive!
Hide Signatures
       Post #: 264
RE: Giant Delta...has it's OWN site now... - 12/24/2012 9:17 AM
CrazyHerb
Score: 100
Status: offline
Hey guys! Long time no post...sorry!! Revisiting my old Giant Delta thread and I can't believe there's posts from 2011-2012... Get's me in the mood to build another one...
You can always find me at www.herbertson.net or FaceBook...maybe I'll re-upload all the GD pics and info I have on it!!
Keep ROCKING the Monster Deltas!
Steven G. Herbertson
(aka CrazyHerb)
Too much talking and not enough flying!!! Let''s GO!
Hide Signatures
(in reply to 91shadowrider)
       Post #: 265
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.593RCU1
