RE: Giant Delta...has it's OWN site now...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Giant Delta...has it's OWN site now... Page: <<   < prev  1 2 3 4 5 6 7 [8] 9 10   next >   >>
Login
RE: Giant Delta...has it's OWN site now... - 12/20/2003 6:09:48 PM
Boss248
Status: offline
This is the most amazing thread on RCU...Chip Hyde...eat your heart out Just kidding Chip...
Ha Crazy Herb...you da man...
(in reply to CrazyHerb-RCU-delete)
       Post #: 176
RE: Giant Delta...has it's OWN site now... - 12/23/2003 4:12:32 AM
spa3d
Status: offline
quote:
No need to paint...I love the newspaper look...
especially the large sheet right in the middle like a diamond....cool...effect....reminds me of an "M.C. Escher" drawing...almost mosaic...pattern.....I'm hypnotized....
Now that you brought that up, the idea was to make the wing a little stronger in the middle and tapper out the further away from the middle. No idea if it's a good thing or not!!
Still have to paint it!
Love your web page!!!!!!!!!
Thanks for the Delta 86!!!!!!!!!
Spa3d
(in reply to spa3d)
       Post #: 177
RE: Giant Delta...has it's OWN site now... - 1/2/2004 6:30:02 PM
Love Deltas
Status: offline
Hello All,
Here are a few pics of my 96" span GD. The Silver one was made with white foam, the kind with the plastic covering (very smooth). I installed two wing spars (1/4 X 3/8) into the foam, evenly spaced, on the top of the wing. I also installed two spars, evenly spaced, front to backon the bottom side of the wiing. This made the wing very strong. I covered the wing with clear packing tape and then foam cut two diagonal slots for the vertical stabilizers. I then painted the entire wing wint a silver metallic paint that proved to be not very fuel friendly. The stabilizers are made from 2 (3/16" corrugated plastic pieces that were Super 77 glued together. I used a 4X18X1/4" sheet of ply to make the motor mount and accessory tray. The control surfaces are made from 3 layers of 1/4" foam core board cut to 4X40". I used playing cards for the hinges (I forgot to punch holes in them). HS-700 servos were used for controlling the GD. I used a Magnum .75 for the power plant and hid all of the accessories in a foam core board compartment. The model weighed 12 pounds.
The first flight was from a soy bean stubble field on a calm day. The drag from the bean stubble made the roll out very slow. I started about 70 yards from a fence row and got it air-born about 10 yards from the fence. After becoming air-born the .75 took the GD nearly straight up and over the fence. I was surprised at how easy the GD was to fly. At half throttle the GD was moving at what looked like to be 50-60MPH. At an idle the plane just didn't want to slow down. I made about ten passes before I was able to slow it enough to land it. I guess I was worried about the bean stubble tearing it up. Never-the-less, the first flight was a success.
The next day I took the GD to our soccer playing fields and had a 12 MPH wind. This time I used the asphalt parking lot for the run way. I set the throttle to 75% and began the roll out directly into the wind. This plane came off the ground so smoothly you could swear it was a B2 Bomber. I put it in a bank and started a pattern around the fields. I lapped the fields once and started the second lap at full throttle. With the wind at it's back, it looked like the GD was going at least 90 MPH. Just when I was thinking how cool it was, the hinge, made from the King of Hearts, decided to pull out. The GD made a nice high speed ARC from an altitude of 200 ft to the ground in a matter of seconds. The only damage was the plywood motor mount broke loose about 12" back from the nose. I will repair it in the spring. If you use cards for hinges. be sure to punch holes in them for extra biting power.
Hope you like my story,
Love Deltas
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to spa3d)
       Post #: 178
RE: Giant Delta...has it's OWN site now... - 1/2/2004 6:58:23 PM
Love Deltas
Status: offline
Hello again,
After crashing the Silver GD I went out a bought another sheet of 2" inch foam to repair it. After looking at it I decided not to repair it until spring. Now, I had new sheet of foam just waiting to be an airplane. With winter around the corner, I decided to make a snow scooter GD. This GD was made without spars and tape covering. I did cut a full length
fuselage including the tail section. The receiver, battery and fuel tank all fit under the fuselage. Two yards sticks from ACE hardware were used for motor mounts and were glued to the wing with Elmer's Ultimate Glue( Great Stuff). I brushed the painted surfaces with a clear Minwax Polycrylic (Water Based) paint before spray painting the color, and followed the color with another coat of clear Minwax. The snow runners are also made of white foam, painted blue, but have a white thin plastic strip Super 77 Glued on the bottom. This should allow me to take off and land from the grass without damaging the runners. This GD has a Tower .46 for power and has a rudder for ground steering (hopefully).
I will let you know how the GD fares,
Love Deltas
Click for fullsize
Click for fullsize
(in reply to Love Deltas)
       Post #: 179
RE: Giant Delta...has it's OWN site now... - 1/2/2004 7:55:55 PM
Status: offline
Love Deltas,
Awesome job on the Giant Deltas!! I love the SKI RUNNER idea....I like the profile fuse look on the GD as well!! I've started adding profiles to my designs too like Plank and Plank 40...makes em look a little more plane-like and gives you something to grab...oh ya...and better tracking in flight.
Sounds like you found a good way to paint the foam too.... I'm SO happy people are enjoying this plane as much as I do.
A couple people at the field have told me to kit them...my response is "BUT WHY??" When you can go to local hardware store and have one built by tomorrow for less.
I love all the variations too... this airframe is so "modifyable".
I'm actually going to be working another Giant wing in a couple months based off a large "raptor" style bird (falcon/eagle/hawk/owl) for an experiment with airport bird control.
I've read that many birds have an innate fear of birds of prey. I'll be using design methods I've learned from the Giant Delta....should be a fun project.
Great JOB on the GD's!!
Keep the pics coming!!
CrazyHerb
www.crazyherb.com
< Message edited by CrazyHerb-RCU -- 1/2/2004 4:33:05 PM >
       Post #: 180
RE: Giant Delta...has it's OWN site now... - 1/3/2004 12:00:51 AM
Ensignnolo
Status: offline
Nice Big Pink Video. Is that trapezoidal building on the left end of the runway a phased-array radar? I've got some pink foam that's going to have a second life as an airplane soon!
Ensignnolo
       Post #: 181
RE: Giant Delta...has it's OWN site now... - 2/10/2004 4:04:51 AM
crashawk
Status: offline
has anybody thought about doing a twin with this thing? I got a pair of .40s on the shelf waiting for a home (all that's left of my twinstar after radio interference) and I think it sounds interesting.
Jason
(in reply to Ensignnolo)
       Post #: 182
RE: Giant Delta...has it's OWN site now... - 2/10/2004 10:13:07 PM
Status: offline
Ensignnolo,
Yes, you are correct...that's a big phased radar array...more details here...
http://www.peterson.af.mil/21sw/library/fact_sheets/7sws.htm
CrashHawk, this would make an interesting twin....just get the motors wide enough apart so the props don't hit....
But really....you could fly this with a single .40.... twin would sound COOL though....
Naturally, you may have to adjust the CG a bit to accomidate a wider nose (less sweep overall)....but VERY do-able.
I really appriciate everyone's positive feedback on this airframe, and I think it's AWESOME that others are having as much fun with it as I do.
As time permits, I'll keep refining the drawings and dimensions...so, if I happen (or have in the past) to not reply to e-mails...sorry about that..
Feel free to e-mail if you have any questions...I'll be glad to answer....
You can also post a message on my little foamie forum at www.crazyherb.com
I'll try to get replys on there as well...
I wish there was a way you could EXPORT this thread and paste it there....that would be cool....maybe....I can figure out something.
Thanks again all!!
Keep them Giant Delta's Flying!!!
CrazyHerb
(in reply to crashawk)
       Post #: 183
RE: Giant Delta...has it's OWN site now... - 2/20/2004 8:53:37 PM
goosechaser
Status: offline
I'm hooked!!!! picked up some 2 inch pink foam, cut two airframes, got em glued. I am planning on doing one with single wood spar and glow power, the other with mutiple carbon-fiber spars(arrow shafts) and 45cc gas power, will probably cut the LE/TE's this wekend time permitting.Much thanks to all, especially crazy-herb, for starting the gears turning, will post some pics as construction progresses.
       Post #: 184
RE: Giant Delta...has it's OWN site now... - 3/14/2004 7:28:36 PM
flyingwings
Status: offline
Herb
Attached are photos of my latest project. The trailing edge is folded Bristol Board that is then glued to the foam with Probond. .7 oz fibreglass is applied over the EPP foam wing and fuselage. The glassed Bristol board is then cut on the underside to create the control surfaces. The Bristol Board is also used as the hinge and the rear spar caps. Bristol Board is comparable to a thick playing card.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to goosechaser)
       Post #: 185
RE: Giant Delta...has it's OWN site now... - 3/14/2004 7:36:19 PM
flyingwings
Status: offline
OOPS
I put a Falcon 56 in by mistake and couldn't get it out. That is my grandchildren trainer.
Attached is the photo I was trying to show of the underside of the new wing with the hinge gap and bottom spar cap.
Paul
Click for fullsize
(in reply to flyingwings)
       Post #: 186
RE: Giant Delta...has it's OWN site now... - 5/13/2004 3:23:29 AM
weskel
Status: offline
Herb,
Can you laminate two sheets of pink foam to get a 2 inch thick piece, if so, what glue to use.
3M super 77???
weskel
_____________________________
I can crash any plane out there, Guaranteed!!!
       Post #: 187
RE: Giant Delta...has it's OWN site now... - 5/13/2004 6:58:50 PM
Buzzard Dave
Status: offline
