VoughtF4U
Crazy Herb, I started mine last night. I have been looking for simple foam designs to build. I have to keep up my reputation at the field for bringing crazy but cheap airplane designs to the spring funfly. I am using half the 4x8 sheet for this delta and the other half will be used for a 4x4 semi-scale Vought V-173. It is basically a big flying pancake with two big props. The foam I bought at Home Depot was 2 inch thick, but it was pink and cost about $22 a sheet. Not as cheap as your but it will still work. I also noticed on my foam sheet, it was pre-scored so that you could break it into strips. The scores run spanwise on mine so they really shouldn't be a problem. I will be using a zig zag pattern of fiberglass reinforced tape similar to that used on a Zagi flying wing. I plan on using an old Saito .65 four stroke that looks like it is on its last legs. For the V-173, I plan on breaking the foam into strips at the score marks, gluing it all back together with luan ribs inbetween the strips, sanding it all down to shape and then fiberglassing the whole thing, latex paint for color. It will be a little heavier, but not much. Thanks for the idea...
_____________________________
"Mix ignorance with arrogance at low altitude and the results are almost guaranteed to be spectacular"
