RE: KATANA XL - new release
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: KATANA XL - new release Page: <<   < prev  9 10 11 [12] 13 14 15 16 17 18   next >   >>
Login
RE: KATANA XL - new release - 10/25/2007 1:13:42 PM
skiman762
Status: offline
quote:
ORIGINAL: Rocketman_
quote:
ORIGINAL: JoeyCoates
Yep, so did I. I am still trying to decide on an engine though, even after reading through all 148 pages of the Giles thread!
For me, the Katana weighing a little under 10 pounds with an OS 1.60FX and Perry VP-30 pump make a lively and nearly ideal 3D combination. I use that same pumped OS 1.60FX setup in the Giles and the Katana. The Katana weighs about 3/4 pound less.
Rocketman how old is your Giles I was reading a review and they said the one they where testing was the newest version with bigger flight control is was covered differently also they said one had sheeted foam wings the review was from 2006 but I see at ultra-rc and OMP they show the giles in the same pattern as your picture
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=720
< Message edited by skiman762 -- 10/25/2007 1:14:32 PM >
_____________________________
land of the FREE: you're free to get a JOB not a handout.
home of the BRAVE: they paid for it and you're enjoying it
(in reply to Rocketman_)
       Post #: 276
RE: KATANA XL - new release - 10/25/2007 1:31:22 PM
G.P.
Status: offline
You will find one version of the giles now, if you can even find one. OMP had a few about a month ago and was looking to get rid of them fast. I posted the sheeted wing/larger control surface question in the giles thread and Ultra RC replied that there was never a different version with small flight controls, so I'm not sure where that came from. There are two color schemes though, which both have the same airframe. -Greg
(in reply to skiman762)
       Post #: 277
RE: KATANA XL - new release - 10/25/2007 1:48:08 PM
skiman762
Status: offline
I know there are 2 versions they show both on Ultra RC's website
http://www.ultra-rc.com/products/glow/index.htm
http://www.ultra-rc.com/products/giles/index.htm
http://www.ultra-rc.com/products/gilesNS/index.htm
one say new scheme if you look you can see the new version has bigger flight controls but they list both as built up balsa wings
< Message edited by skiman762 -- 10/25/2007 1:58:12 PM >
(in reply to G.P.)
       Post #: 278
RE: KATANA XL - new release - 10/25/2007 2:01:40 PM
skiman762
Status: offline
I see what your talking about both on Ultra's website are the same airfrmane.
But I was just looking at the review again it appears the there were two verison with the wavey cover scheme if you look at the wavey one in the review you can see the ailerons are about 2'' shorter then the wavey scheme on Ultra's website now. That must be where the confusion is it appears the the latest large flight control plane came in two cover schemes and the older smaller flight control came in the wavey cover scheme
remember the review is in 2006
< Message edited by skiman762 -- 10/25/2007 2:19:12 PM >
       Post #: 279
RE: KATANA XL - new release - 10/25/2007 2:38:24 PM
reefHawg
Status: offline
Without getting tonnes of other engine options since I am aware of the weight difference,... it's not much. I was wondering what the groups thoughts where for using a Fuji 43EI. I have this engine available on the bench. It has good power and weighs 3.6 pounds with muffler and Ignition. Remember this is then newest version of the engine. It pulls at least 20 pounds of thrust. I get about 7400 with a 20x8 prop. The overall airframe weight will be low.
Assuming it fits in the cowl (length to the prop nut,..)
I wouldn't be a 3D nut but would try a few tricks here and there.
I was pricing out an OS 1.6 but I may need to reuse some equipment here. If the Fuji does not fit in the cowl the only option would be to cut the engine box. Doable but not my first choice. In that case I will spend the extra for another engine.
And on that note,... for an OS 1.6. Is it a fuel hawg? My Saito 82A, although great power goes through so much glow that I swore I would not get a bigger glow engine.
Anyone run a 26 gas with this.
geoff
       Post #: 280
RE: KATANA XL - new release - 10/25/2007 3:27:03 PM
G.P.
Status: offline
quote:
ORIGINAL: reefHawg
geoff
My two 1.60's actually started using LESS fuel when I pumped them. It has happened to others as well, but I find it strange because I pumped the engines so that I could get them to run richer with pitts pipes!?!?! I estimate that they now use about 1oz per minute.
(in reply to reefHawg)
       Post #: 281
RE: KATANA XL - new release - 10/25/2007 3:34:27 PM
G.P.
Status: offline
quote:
ORIGINAL: skiman762
I found the post by Ultra RC to the question when I asked it (no small feat since the search engine on here sucks ). Two color schemes, same airframe. The RCU review is the only place that I have seen a sheeted wing version with smaller control surfaces, so I don't know what is up with that. My Katana has 2KRC.com written on the wing bags and they have a picture of the giles on their website. Maybe they used to make that version for Creek Hobbies.
http://www.rcuniverse.com/forum/fb.asp?m=4740867
< Message edited by G.P. -- 10/27/2007 3:21:44 PM >
       Post #: 282
RE: KATANA XL - new release - 10/25/2007 7:02:10 PM
Rocky V.
Status: offline
quote:
ORIGINAL: ULTRA-SALES
To all it may concern:
I will post this information once. Ultra-RC is being controlled by a new company.
We are selling the remaining Ultra inventory via eBay. We are not going to produce any new products. We do have, and will continue to have, replacement parts for all the recent Ultra planes, while supplies last.
Last, we will not be monitoring posts here on RCU for information pertaining to orders or stock status, etc. If you would like to receive this information, please email us at the above email. You questions will be answered within 24 hours.
Ultra-Sales
[/quote
Ultra Sales:
In regards to the "new company", are you a clearance house that is just liquidating the inventory of a bankrupt company ? Or will Ultra be re-emerging as a new company ? If there are quality issues with the current batch of planes being sent, can we expect this to be made right by you ? Please forgive all the questions, I'd still like to have a Katana, but I'm just a little nervous after my last experience.
Victim of Gravity...
(in reply to ULTRA-SALES)
       Post #: 283
RE: KATANA XL - new release - 10/26/2007 4:53:14 AM
skiman762
Status: offline
Well my son-in-law went for the Katana he had emailed them and they said you can just email a order without trying to get one off ebay
he's got a 46 gas he's going to use
I went with the Giles 202 from OMP should be here in the morning on the the big brown truck
going to put my ys140 on it should fly it ok
(in reply to Rocky V.)
       Post #: 284
RE: KATANA XL - new release - 10/26/2007 11:31:35 AM
closetguy
Status: offline
skiman, that giles is that the same one that ultra rc sold.
       Post #: 285
RE: KATANA XL - new release - 10/26/2007 1:21:08 PM
skiman762
Status: offline
Sure is
I'm hoping to keep it around 10lbs with the wing loading between 22-23 oz shiold fly great
(in reply to closetguy)
       Post #: 286
RE: KATANA XL - new release - 10/26/2007 1:35:46 PM
droosta
Status: offline
Has anyone seen any footage of the KATANA other than the "No fear" vid? Got one coming on the 30th and curious to see more of the flight characteristics.
       Post #: 287
RE: KATANA XL - new release - 10/26/2007 4:12:00 PM
skiman762
Status: offline
there the Unlimited RC video on the website
(in reply to droosta)
       Post #: 288
RE: KATANA XL - new release - 10/26/2007 4:13:00 PM
skiman762
Status: offline
never mind I guess thats the one your talking about
       Post #: 289
RE: KATANA XL - new release - 10/27/2007 3:04:33 PM
skiman762
Status: offline
There's a new
