mgmoore7
Joined: 7/29/2002 From: Tampa, FL, USA Status: offline
I have a AT 250watt 9amp power supply. I have sucessfully got it "working" by puting 1 or 2 10ohm/10watt resistors on one of the 5+volt red lines. I have two problems. 1. I have read many times that on the AT PSU, a 5volt line needs to be connected to the "power good" line. Most PSU's power good line is orange. I do not have a orange line and do not know how to determine which line the power good is. I have red, yellow, black, 1 white, 1 brown, 1 blue 2. I am only getting 4.5volts on the 5volt lines (red) and 11.4volts on the 12 volt line (yellow). What do I need to do to get the voltage up to 5 and 12 respectively? Thanks for your help Matt
