RE: KMP F-7F Tigercat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP F-7F Tigercat
Page: <<   < prev  76 77 78 79 80 81 [82] 83 84 85   next >   >>
Login
RE: KMP F-7F Tigercat - 8/9/2012 11:43 PM
stoat
Score: 105
Last Login: 1/21/2013
Status: offline
A couple of the guys here have done elec versions. Nice but you dont get that great twin sound! Weight seems to be around the 30lb mark too.
_____________________________
CORSAIR Brotherhood # 76 - Also known as Toast in other forums...
Hide Signatures
(in reply to sabrejet)
       Post #: 2026
RE: KMP F-7F Tigercat - 8/9/2012 11:44 PM
ysolomon
Score: 100
Last Login: 5/18/2013
Status: offline
I'm making it electric, but have been working on it on-and-off for a while now, so it will likely still be a while before I'm done.
Hide Signatures
       Post #: 2027
RE: KMP F-7F Tigercat - 8/14/2012 10:34 AM
dgiatr
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: dgiatr
7 times so far and tigercat flies really well..... so well that i nearly crashed it one week ago! i was at last turn before landing and i said to myself '' this plane flies really nice almost like a single engine plane!'' at that time i was having a really steep low speed right turn!, and i suddenly decided to fully open throttles from idle! ( i know all mistakes at the same time!!)...tigercat suddenly had that famous ''spiral death'' and it went down while spinning for about 4 or 5 turns ( i dont remember!!...its like a bad dream!), at about 3 metres from the ground i managed to stop it from spinning ( i cut throttles to idle and put down elevator, nothing else) and plane started flying level! but with the same direction to the wind, i didnt realised what really happened and i thought that i had lost one engine so i let it flying with zero throttles until it stalled at about one metre from the ground causing one leg and a small part of centre wing panel broken! i have twinsync on it and i am very happy with it but the conclusions is that you have to respect twin engine planes they are not single engine planes and you have to : open throttles really softly, take wide preferably left turns and pay attention to keep speed up specially while turning especially i would say that when plane speed is low (while turning or landing ) you have to be very carefull to sofly open throttles because every difference in engines rpm at that time can cause plane instability.
ok! after some wing and landing gear repairing tigercat is ready to fly again, with cowls on it that time, i will wait for a little because temp here is really high , i am thinking of flying it at the beginning of september.
Hide Signatures
(in reply to dgiatr)
       Post #: 2028
RE: KMP F-7F Tigercat - 8/29/2012 9:16 AM
dgiatr
Score: 100
Status: offline
a question for nitro or gas tigercat owners :
whats the maximun possible difference in r.p.m. between the two engines that you let your model fly;...say 500 rpm difference at 15-20%% throttlle travel is that acceptable or not;...i know that everything is relevant to speed that your models would have at that time so lets say that 500 rpm difference happens when model speed is low or while landing with full flaps at about ,say 1 metre from the ground
Hide Signatures
       Post #: 2029
RE: KMP F-7F Tigercat - 8/29/2012 4:40 PM
rcnut101
Score: 100
Last Login: 5/15/2013
Status: offline
No More than 200 rpm!
Hide Signatures
       Post #: 2030
RE: KMP F-7F Tigercat - 8/30/2012 12:45 AM
stoat
Score: 105
Status: offline
Better still, nothing. More critical to have them matched at low rpm.
Hide Signatures
(in reply to rcnut101)
       Post #: 2031
RE: KMP F-7F Tigercat - 9/2/2012 11:05 AM
cordline
Score: 100
Last Login: 5/20/2013
Status: offline
I have 20cc Zenoahs in mine and initialy tried a Twin Sync but i could not isolate RF problems so i gave up on it.
I put a Rate Gyro on the Rudder and any difference in RPM is not such an issue.
Cheers
Wayne
Hide Signatures
(in reply to stoat)
       Post #: 2032
RE: KMP F-7F Tigercat - 9/3/2012 1:50 PM
dgiatr
Score: 100
Status: offline
Thanks for the info!
i would like to ask those of you using twinsync ,whats the lower limit that you have set twinsync to engage , say from about 2700 rpm is that very low or not; if yes then whats the possibe problems that might have such a low setting; ( i mean to set twinsync to work from 2700 rpm and above), manual says something about that but to be honest i dont get it!...in my tx and with my own settings i get 2700 rpm after two clicks above idle ( i have high idle in case.....)
Thanks!
Hide Signatures
(in reply to cordline)
       Post #: 2033
RE: KMP F-7F Tigercat - 10/1/2012 6:42 PM
Ratus
Score: 100
Last Login: 5/19/2013
Status: offline
Hello all,
First fly of my tigercat and 2 vidéo's.
Alain
Hide Signatures
       Post #: 2034
RE: KMP F-7F Tigercat - 10/3/2012 4:54 AM
Ron McGrath
Score: 100
Last Login: 5/7/2013
Status: offline
What engines do you have in your TC?
RON McGRATH
Hide Signatures
(in reply to Ratus)
       Post #: 2035
RE: KMP F-7F Tigercat - 10/3/2012 7:32 AM
Ratus
Score: 100
Status: offline
Hello Ron,
it's 2 91 4 stroke (P.H.) copy of OS. and 2 master airscrew propeller 13X8
Alain
Hide Signatures
(in reply to Ron McGrath)
       Post #: 2036
RE: KMP F-7F Tigercat - 10/4/2012 9:07 AM
Ratus
Score: 100
Status: offline
Hide Signatures
(in reply to Ratus)
       Post #: 2037
RE: KMP F-7F Tigercat - 12/9/2012 2:43 AM
pfifft6
Score: 100
Last Login: 2/14/2013
Status: offline
Just received my f7f Tigercat,Fuselage has damage ,so I need to get that fixed.Will do electric,Im thinking 60 mtrs,2-80 amp ESC ,26s 5000 batts ,Let me know what you are doing.This big twin is going to be different than my other twins.
Hide Signatures
       Post #: 2038
RE: KMP F-7F Tigercat - 1/4/2013 8:51 PM
donddsms
Score: 100
Status: online
Hello Airraptor,
I am doing this backwards! I received my Tigercat three weeks ago, along with ESM electric retracts, and NOW I just completed reading this thread that started years ago! I am truly greatful to all the hard work and documentation presented in this thread, and I can see this is going to be the longest and most difficult build I have ever attempted. I am wondering, are you satisfied with the retracts? I notice a lot of pilots seem to eventually switch to the Sierra retracts. Thanks. I will be checking back here frequently. This thread would make an excellent hard-bound edition!
Don
Hide Signatures
(in reply to airraptor)
       Post #: 2039
RE: KMP F-7F Tigercat - 1/4/2013 8:54 PM
donddsms
Score: 100
Status: online
I also understand there is a parallel tigercat build thread, but I have been unable to locate it. Can anyone give me a link to it?
Thanks.
Don
Hide Signatures
(in reply to donddsms)
       Post #: 2040
RE: KMP F-7F Tigercat - 1/4/2013 10:01 PM
rlinus
Score: 100
Status: offline
I am in the same boat as you. I just got the plane about a month ago, didn't get the retracts yet. I haven't started building anything yet. Still deciding on which engine to use and how I'm going to do the retract doors, removable outer wing panels etc.. Think I'm going to go with an OS 120 4 stroke. I agree this one is going to take awhile. Keep posting!
Hide Signatures
       Post #: 2041
RE: KMP F-7F Tigercat - 1/4/2013 11:53 PM
Rocketman_
Score: 110
Status: offline
quote:
ORIGINAL: donddsms
Thanks.
Don
Are you referring to the ASM F-7F Tigercat thread?
http://www.rcuniverse.com/forum/m_9096477/anchors_9096477/mpage_1/key_/anchor/tm.htm#9096477
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
       Post #: 2042
RE: KMP F-7F Tigercat - 1/5/2013 4:59 AM
Ron McGrath
Score: 100
Status: offline
I have a set of OS 120 sp (super charged) 4 cycles that I was thinking if I got sick of the E setup I could put in my Tigercat but it would be a minimum of 3 less HP and that would make me sad.
RON McGRATH
Hide Signatures
(in reply to Rocketman_)
       Post #: 2043
RE: KMP F-7F Tigercat - 1/5/2013 5:14 AM
Thomas Pham
Score: 100
Status: offline
quote:
ORIGINAL: rlinus
Call or email Lenny at Lenny@shindinmachine.com for the retracts, he custom made for my tigercat way better than Sierra retracts. You can see my photo in his website http://www.shindinmachine.com/pilotprojects2010.html.
and this one for 3 pieces wing http://www.rcuniverse.com/forum/m_8655593/anchors_8655593/mpage_1/key_/anchor/tm.htm#8655593
Sig Kadet Brotherhood #28
Cub Brotherhood #159
Hide Signatures
(in reply to rlinus)
       Post #: 2044
RE: KMP F-7F Tigercat - 1/5/2013 12:27 PM
Sundownee
Score: 100
Status: offline
Hi guys, I myself have been watching this thread for awhile also. I picked up a full composite kit last month from here NIB with full Sierra retract gear, wheels and struts. Going to use Saito 200R3 radials, already picked one from here the other day NIB.
RCU always has been a great place to shop to find things and save some money.
I believe this project is going to be a longer build myself. Still looking for other parts needed as servos and etc.
Might start a new thread on this build.
Keep the posts coming guys, lots of great ideas.
Paul Sousa
Hide Signatures
(in reply to Thomas Pham)
       Post #: 2045
RE: KMP F-7F Tigercat - 1/6/2013 4:22 PM
donddsms
Score: 100
Status: online
Thanks all for the information. At the moment pondering engine choice. I wanted to emulate Col. Winter's efforts with Fuji 24's, but they have been out of production for awhile. CRJDriver (Chris) I think used Zenoah G20's and loved them? Pylon2 also used G20's with no nose weight. Grossy2 are you happy with the GR26i's? I have noticed positive references to DLE 20ei's also. At the moment I'm leaning towards the G20's, but thinking hard on the DLE 20s.
I am very much open to suggestions/advice. Thanks.
Don
Hide Signatures
(in reply to Sundownee)
       Post #: 2046
RE: KMP F-7F Tigercat - 1/6/2013 4:32 PM
rcnut101
Score: 100
Status: offline
quote:
ORIGINAL: donddsms
Don
Either engine choice will be fine, My first one had G-20's and pulled good. I'm finishing my second one with G-26's. If I had it to do all over, I would have used big 4 stroke glow due to being a lighter setup. Keep the model as light as you can.
Hide Signatures
       Post #: 2047
RE: KMP F-7F Tigercat - 1/6/2013 4:59 PM
rc4j
Score: 100
Status: offline
I've got an all composite ARF that I've yet to start, and I'm also undecided about which power plants to use. I've got a pair of laser 150's which I know will do fine, however I'm not too sure I want to go glow. I have one 3W-24 but the fit isn't the greatest, as it would need a custom prop drive extension made, to put the cylinder head cutout at a reasonable location behind the curve of the cowl. I've also considered a pair of Zenoah 20's, as a lot of folks have used with good results, and also pondered the 26's for a little more oomph.
Here is a video on youtube, that you may have seen, where 3 TC's are flying together. Engines are O.S. 1.20 , Laser 1.50 , and Zenoah G20.
http://youtu.be/0fEgjyFcRjs
< Message edited by Jai Williams -- 1/10/2013 7:28 PM >
Hide Signatures
       Post #: 2048
RE: KMP F-7F Tigercat - 1/6/2013 5:54 PM
donddsms
Score: 100
Status: online
Thanks RCnut101. Now I will go back through the thread and see which 4 stroke glow has worked well. I was thinking about fuel costs, but considering the $ I will have in this plane, that seems kind of insignificant. My biggest concern is reliability. I've flown glow twins before, but never gas, and my impression from reading threads here, and at my flying field, seem to suggest gas might be better in this regard? Whatever I go with, I plan to fly it on another plane as a single until I really get to know it.
Don
Hide Signatures
(in reply to rc4j)
       Post #: 2049
RE: KMP F-7F Tigercat - 1/6/2013 6:04 PM
donddsms
Score: 100
Status: online
Hey, I already have two MOKI 2.10 two strokes. I wonder if anyone has tried those? Talk about burning up glow fuel! They run and sound great but are very thirsty.
Hide Signatures
       Post #: 2050
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
