RE: KMP F-7F Tigercat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP F-7F Tigercat
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: KMP F-7F Tigercat - 8/5/2007 6:22:51 PM
chasrb
Status: offline
quote:
ORIGINAL: N215PB
WHat about this rudder set up..........kinda vauge on instructions.....anyone have photos on where they exited fuselage with the cables? I don't know about this kit...it sure like nice but they really stopped short on the whole thing.
Yep, I feel the same.. I went back and looked at the pics of the work others have done to see the rudder exits, they are not cut in for us, like the elev halves. I guess when they got around to that they took a break in mfg'ing....
_____________________________
Chasman
(in reply to N215PB)
       Post #: 251
RE: KMP F-7F Tigercat - 8/5/2007 6:31:01 PM
N215PB
Status: offline
What about air lines..........without re reading the 13 pages on 2 seperate posts.......did i see something about lines not staying on. I don't see any of these for sale yet on RC Universe.
"My wife says if I buy one more airplane she's gonna leave me, Gee I'm gonna miss her"
(in reply to chasrb)
       Post #: 252
RE: KMP F-7F Tigercat - 8/6/2007 9:48:42 PM
VKerster
Status: offline
N215, I WENT WITH 4-40 RODS ON A PULL PULL ARANGEMENT AND SHELVED THE WIRE. WORKS EXCELLENT. WILL POST PICS SOON...
VKerster
       Post #: 253
RE: KMP F-7F Tigercat - 8/7/2007 1:05:27 AM
chasrb
Status: offline
Woks progresses... I have all the little blocks set in with Epoxy, ca'd for strenght and painted to be hidden. now to the servo mounts and the nacelles and getting the 170's installed.
Doesn't someone offer a prebuilt servo mount?
Chasman
(in reply to VKerster)
       Post #: 254
RE: KMP F-7F Tigercat - 8/8/2007 7:43:19 PM
VKerster
Status: offline
HAS ANYONE BESIDES THE GENTS IN THE UK AND CHINA FLOWN THEIR T-CAT YET?
VKerster
       Post #: 255
RE: KMP F-7F Tigercat - 8/8/2007 8:17:11 PM
chasrb
Status: offline
quote:
ORIGINAL: VKerster
Arn't you close to that stage?
Chasman
       Post #: 256
RE: KMP F-7F Tigercat - 8/9/2007 2:54:17 AM
VKerster
Status: offline
CASRB, MOUNTING COWLS, AND STRUNG THE STEERING CABLES FOR THE NOSE GEAR. DID A CG CHECK, STILL TAIL HEAVY WITH A PAIR OF G-26'S....
VKerster
       Post #: 257
RE: KMP F-7F Tigercat - 8/9/2007 9:44:17 AM
chasrb
Status: offline
quote:
ORIGINAL: VKerster
That seems hard to believe!
I have a "what if" here, What if for rudder control a CF arrow shaft with 4-40 rod was used instead of pull-pull? Do you think that a push-pull would work well with this plane?
Chasman
       Post #: 258
RE: KMP F-7F Tigercat - 8/9/2007 1:54:18 PM
THERCAV8R
Status: offline
Hi All,
I have a question about the center section of the wing. The metal joining tubes for the wings do not have a connection at the center for strength. In other words they only go through the wing ribs and not in a tube and do not connect to each other. The problem/question is what structure is there for a dihedral brace. I don't or can't see any main spar or plywood plate for a diehedral brace. The entire structure is fiberglass over a composite foam structure and several ribs. This wing supports a great deal of weight not to mention the aerodinamic loads it is going to be stressed with during flight. I intend to glue the entire wing structure together into a one piece wing but I would like to be sure of the wings internal structure at the center section. I am trying to get in touch with Andrew but we are playing phone tag at the moment. My kit is from the second shipment.
< Message edited by THERCAV8R -- 8/9/2007 2:01:23 PM >
       Post #: 259
RE: KMP F-7F Tigercat - 8/9/2007 6:36:51 PM
chasrb
Status: offline
quote:
ORIGINAL: THERCAV8R
Hi All,
I had wondered about that too. Kinda hard to go back in and laminate a brace.
Chasman
(in reply to THERCAV8R)
       Post #: 260
RE: KMP F-7F Tigercat - 8/9/2007 7:44:38 PM
VKerster
Status: offline
csarb, i'm using a pair of 4-40 rods in a pull pull arrangement. it is super strong, will post pics soon.......
VKerster
       Post #: 261
RE: KMP F-7F Tigercat - 8/10/2007 3:01:41 AM
n9331v
Status: offline
charsb
Did you have to modify the firewall and or cowl to install the radials and if so to what extent ?
Mooney N9331V
       Post #: 262
RE: KMP F-7F Tigercat - 8/10/2007 5:07:27 PM
fgpierce
Status: offline
skypilotp38e
Sorry to be so long in getting back to you! I've been fairly busy and under the weather to boot.
As far as the actuation goes I feel it needs to be sequencial. The spacing is way too close to be any other way. As yet, besides an $80 sequencer, I haven't found a method.
Now if I could find a way to double my ambition and add 12 or so more hours to a day...........
(in reply to skypilotp38e)
       Post #: 263
RE: KMP F-7F Tigercat - 8/10/2007 7:42:06 PM
VKerster
Status: offline
T-CAT CROWD, HERE'S THE FINISHED ENGINE AND COWL MOUNTING OF THE G-26........ THE COWL COMES RIGHT OFF WITH ONLY HAVING TO REMOVE THE SPARK PLUG. BELIEVE IT OR NOT, THE PLANE IS STILL TAIL HEAVY WITH ALL THIS UP FRONT, A 3000MAH BATTERY FORWARD OF THE FRONT WING BULKHEAD, AND RADIO GEAR...EVERYONE... DON'T FORGET TO LOCKTITE EVERY NUT AND BOLT ON THE LANDING GEAR, AND RETRACT MECHINSIMS, INCLUDING THE SCREWS IN THE WHEELS.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by VKerster -- 8/10/2007 11:23:48 PM >
VKerster
       Post #: 264
RE: KMP F-7F Tigercat - 8/10/2007 8:25:44 PM
chasrb
Status: offline
