RE: KMP F-7F Tigercat
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld Focke Wulf FW 190 1/4 scale
Seller:  BAGOSTIX
Details:   $5,500.00   |  7/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP F-7F Tigercat
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: KMP F-7F Tigercat - 2/7/2007 8:16:21 PM
n9331v
Status: offline
The real F7F did not have bomb doors it had 2× 1,000 lb (450 kg) bombs under wings or
1× torpedo under fuselage, I think I will do the drop bombs from under the wings, anyway I think I am going to order and extra set of wings and do this
Click to see fullsize image.
Click for fullsize
< Message edited by n9331v -- 2/8/2007 1:58:27 PM >
_____________________________
Mooney N9331V
(in reply to chasrb)
       Post #: 51
RE: KMP F-7F Tigercat - 2/7/2007 8:28:04 PM
chasrb
Status: offline
Okay, another powerplant question. I found the RCS50VT a smaller 4stoke gasser, they also have a 140 (22cc) 2 stroke.
Details
Displacement 50cc
RPM Range 1200-7000
Horsepower 3.5hp
Weight 3 lbs 7oz - (with ignition)
Fuel/Ratio Premium Gas mixed 30:1 synthetic only
Ignition 4.8v-6.7v Electronic
Prop Size 2 blade 22x10-12 = 4900rpm, 20x10 = 6000rpm
Probably rip the wings off, but this is more a "are these relaible engines" question. It is a littl more than a pound heavier than the Zenoah 20ei.
Click for fullsize
Chasman
(in reply to n9331v)
       Post #: 52
RE: KMP F-7F Tigercat - 2/8/2007 9:33:22 AM
fgpierce
Status: offline
chasrb
That closeup of the cockpit shows some nice quality. I wonder if the all composit reffers to the wings being made of glass as well. I'm putting a trubine jet trainer togehter now and I can't wait for the F4F to get here! GADS I love them twins !!! I'm on the second list
       Post #: 53
RE: KMP F-7F Tigercat - 2/8/2007 9:48:11 AM
fgpierce
Status: offline
chasrb
RCS makes a good product. I have their RCS 180se and it's super reliable. I have no issues when I'm flying it's going to "crap out"
As far as the ripping wings go I'm afraid you'll need to learn" throttle managment" and you'll be just fine. Just as a warning, If you should see white fog billowing off your wings them maybe you shold back out of the throttle a bit
Later and remember " rubber side down"
       Post #: 54
RE: KMP F-7F Tigercat - 2/8/2007 10:00:22 AM
fgpierce
Status: offline
N9331V
The folding wings would be too cool! Great for transporting as well. If you have the notion and time please post the project with pics and maybe patterns of parts you'll need to make
Thanks for the bomb bay info. 1000 pounders and centerline tank under the wings and belly WoW
       Post #: 55
RE: KMP F-7F Tigercat - 2/8/2007 10:48:55 AM
chasrb
Status: offline
Throttle? What Throttle? Old Chineese proverb: "It is better to have to much throttle, than to realise you need more when ground get close!"
Since we don't have all the specs yet on the plane I am not sure adding a little over 6 + lbs of engines is sustainable on the airframe. If it is then I'd like to try the RCS50VT's...just think twin 4 stoke gassers.....with a custom exhaust header...
Btw anyone have the nacel detal? I am looking for pics that show the positions of the exhaust and the locations.
I am in the first wave.....
Chasman
(in reply to fgpierce)
       Post #: 56
RE: KMP F-7F Tigercat - 2/8/2007 2:06:13 PM
n9331v
Status: offline
Chasrb
Can you give me the web site to the engine RCS 50 VT you listed above
Mooney N9331V
       Post #: 57
RE: KMP F-7F Tigercat - 2/8/2007 5:35:23 PM
chasrb
Status: offline
n9331v, here is the link
http://www.rcshowcase.com/html/RCS/rcs50vt.html
I have looked for bad press on the RCS engines and turned up little if any.
This really would power the plane well and sound good at the same time while being more relaible than glow...
Here is the spec url for this engine.
http://www.rcshowcase.com/images/engines/rcs/dimensions/rcs45vt.jpg
It aparently the same size as was the 45 version, just bored out.
Click for fullsize
< Message edited by chasrb -- 2/8/2007 5:38:15 PM >
Chasman
       Post #: 58
RE: KMP F-7F Tigercat - 2/8/2007 9:50:45 PM
n9331v
Status: offline
Thanks for the link
Here is another to look at not as overpowered but does come in at 4.9lb = 78oz
Four Stroke Gas Fuji imvac BF-34EI. Tower sells them
Height: Oil Pan to Rocker Cover 8" (203mm)
Width: 6-3/4" (171mm)
Weight: 4.9lbs (2.0kg)
Distance from firewall to prop rotor: 6" (152mm)
Muffler exhaust outlet diameter: 9mm inner, 11mm outer
Distance across mounting screws on motor mount: 95mm
Distance top and bottom mounting screws: 75mm
Displacement: 2.1 cu in (34.cc)
Bore/Stroke: 39x28mm
Spinner Bolt: 3/8-16 threaded 13mm hex
Practical RPM: 1000-7500
Brake Horsepower: 2.0 hp @ 7500 RPM
Peak Torque: .20kgm @ 5,000 RPM
Default carb settings: High Speed 1-3/4 to 2 turns OUT
Low Speed 1-1/3 turns OUT
Recommended Propeller: 22 x 6-10 (TOPQ5241
< Message edited by n9331v -- 2/8/2007 9:53:05 PM >
Mooney N9331V
       Post #: 59
RE: KMP F-7F Tigercat - 2/8/2007 11:27:48 PM
jrf
Status: offline
Does it bother anyone here that this Tigercat sells in Australia for $655US? http://www.modelflight.com.au/esm/f7_tigercat_esm.htm
I know you have to pay what you have to pay to get what you want, but gee, for $900 you should a least get kissed.
If anyone is interested, KMPs $770 OV10 sells there for $327 and they will ship that one to the US.
Jim
< Message edited by jrf -- 2/8/2007 11:28:46 PM >
       Post #: 60
RE: KMP F-7F Tigercat - 2/8/2007 11:48:42 PM
chasrb
Status: offline
Right, I saw that it would be lower if they were to sell to US residents. As of now the web site does not offer a "sell to the US".
BTW on a differnt note... in another twin forum an individual was caling into question the flight characterists of this f7f from KMP in comparison to a Cessna 310 and the single engine handeling of said airplanes. I for one will admint I started out in that fourm when I learned of that twin, then I read about this Tigercat and without question came here, read all I could and now I am in the first wave of getting the Tigercat.
A couple of things made my decision, one is wing loading on the other being close to or over 50oz per sq ft, and the next was I LOVE WARBIRDS and this plane will fly great Plus using a gasser at least will buffer the chances of a flame out to a degree.
my .02
Chasman
(in reply to jrf)
       Post #: 61
RE: KMP F-7F Tigercat - 2/9/2007 8:12:38 AM
robert waldo
Status: offline
The amount of lift a wing produces is not determined by wing area alone, the airfoil, fues and nacelle profiles also ad to lift as is the case with a scale 310
       Post #: 62
RE: KMP F-7F Tigercat - 2/9/2007 11:27:30 AM
chasrb
Status: offline
You are correct in saying all components create the lifting body. Don't get me wrong, I like the 310 and TF does make a good product. I am sure they have done a lot of testing in the development of the 310 before rolling it out to certify that it will perform as best it can. I may even pick one up as well just to have a civ and a mil twin.
Chasman
(in reply to robert waldo)
       Post #: 63
RE: KMP F-7F Tigercat - 2/9/2007 12:32:03 PM
AKondor
Status: offline
Hi Everyone:
First let me start by saying thanking everybody who has been so patient in the release of the F7F. It will be well worth the wait! As you can see pictures are circulating freely of the production version and the model truly flies, and builds as good as it looks. To the best of my knowledge the models are complete at the factory and will be shipping very shortly to the USA. I am doing my very best to have them on the water before the start of Chinese New Year. The worse case scenario is that they will depart at the end of February and arrive in March. :-(
Regarding the post mentioned above about the pricing overseas, I do hope people realize that pricing is a very complex issue made up of a delicate balance of several variables. I don't feel the need to justify our prices, however the cost to maintain our advsertising, our ability to showcase our products at major tradeshows, magazine advertising, legal and other professional fees, travel to the factory in China several times /yr, warehouses in Canada and the USA all combine to add to operating costs which may or may not be equal to those necessary to operate in Australia and offer the prices in the same capacity.
Regarding the shipping cost of models from overseas, the price per box for shipping such models as the OV-10 or B-25 which both come in two boxes would be approximately $300-$400 per box by air. In most cases the box sizes are too large for the postal system to accept so there would be no savings using that service either. At the "end of the day" Its still much cheaper to support your local Hobby Shop and get the service that goes along with that.
Should anyone have any questions about our pricing or distribution feel free to call me anytime toll free 888-968-7251 and I would gladly answer any questions you may have.
Sincerely,
Andrew Kondor
President - KMP
< Message edited by AKondor -- 2/9/2007 12:42:07 PM >
Andrew Kondor
KMP Models
       Post #: 64
