flyscbs
IN, USA Status: offline
Col. Winter Sir, May I suggest the OS 120 AX. , I plan to use for my F-7F, the exhaust is an issue though, Bisson muffler's invert mount style, close fit on the cowls, may need the alter the size of the units, that means back to Bisson, as for retract controls & doors, using an UP-3 brand valve unit www.up-1.com ( doors stay open on gear down ) and has varible speed on both circuits, from 3 to 10 seconds, and short throw cylenders for the doors with linkage setup as in a earilier forum, that were servo driven, very cool, but I will need more than a smaller pressure vessel. I want to use Robart F-7F units when available. The 120 AX turn's 15x7 Master airscrew 3 blade at 8800 rpm. 16x8 3 blade at 7800 rpm. with the included muffler, that you can't use on the F-7F. OS has 9500rpm. as max recomended, with 3.1 HP. at 9000 rpm. ( my Saito 180 turns the 16x8 3 blade at 8000 rpm. with it's output in the 9000rpm. range at 2.9 HP.) As for my selection I wanted a scale sized & type props for the model with engines that con turn the props. With the number of servos needed on the F-7F, I will use a" Smart-fly" power expander pro, along with heaver gauge servo lead extentions for wing, with the only Y- harness for the flap servos( 3 drive outputs on the expander per Ch. and 4 flap servos ) Heavy gauge type switch & leads to battery, with Deans Ultra connectors , 6.0V at 4000mah or better. and a on board glow driver unit, McDaniel brand, twin engine type, servos and hardware are next on the list. I'll start assembly of the model when have all the parts, retracts & servos to go yet as the BIGGIES... I enjoy all that I read and see on this forum and has impressed and helped me. ps. I always thought the F-106 SEXY... Thanks for reading, Craig Beaven
