chasrb
Joined: 1/12/2003 From: Warrenton, VA, USA Status: offline
quote:
ORIGINAL: VKerster CHARLES AND T-CAT BROS, AFTER LOOKING AS CHARLES' PICS, I LOOKED AT MY WING FROM THE CRASH IN UDDER DISBELIEF. NOT ONLY DID MY CENTER SECTION LOOK LIKE CHARLES' PICS, BUT I FOUND THE LEADING EDGE HAS NO SPAR, AND THE TRAILING EDGE HAS ONLY A 1/8" BALSA SPAR!! I'M NOW CONVENCED I WAS RIDING ON BORROWED TIME UNTIL I WOULD HAVE HAD AN IN FLIGHT WING FAILURE. WILL POST PICS SOON. FOR T-CAT #2, I'M GOING TO TRY TO INSERT A SMALLER DIA. TUBE FROM TUBE TO TUBE LIKE CHARLES, EXECPT I'M GOING TO TRY TO DRILL THRU THE RIBS THAT THE TUBES BUTT UP TO AND INSERT IT ONE INTO THE OTHER SINCE THE WING SECTIONS ARE NOT GLUED TOGETHER YET, AND USE J.B. WELD TO GLUE THEM TOGETHER. ALL OTHER IDEAS ARE APPERICATED. I WONDER IF THE FLY RC MAGAZINE ADDRESSES THIS ISSUE IN THEIR ARTICLE. I WISH KMP WOULD CHIME IN AND ENLIGHTEN ALL OF US HOW THEY WOULD FIX THIS MESS ............. TOLEDO IS NEXT WEEKEND. VK where are you in this process? If I understand your post correctly, you seem to be atempting what I have recently thought about, that is to place the smaller tube inside the existing wing tubes, breaking/cutting thru the rib where the tubes butt-up, and then JB Welding the inserted tube in place. Is this correct? I am to the point where I have finishe all that can be done except for joining the wing together. I'd like to perform the centersectionextomy soon and want to see which rouye may end up the less complex. Thanks
_____________________________
Chasman
