ton goede
Joined: 8/20/2007 From: Wognum, AB, NETHERLANDS Status: offline
oke Chasman , I can understand that. just was curious, cause I was looking to the same props... and I was wondering if the OS FS 200 can turn a 20 inch 3 bladed prop... & Detlef, thx for the flight info...since our field is not as big as yours..I was wondering how much runway I needed for landing...80 m seems to be ok. nevertheless I hope you can do some take off's with flaps. 10-15 degree must be ok I think. I always say the quicker you are loose from the gound the better...[)] Nice to see that the sierra gear holds on rough landings too..[)] I also planning a smokesystem in the Cat..anybody experience with this? on a big 4 stroke engine... cheers, Ton
