RE: KMP F-7F Tigercat
Tower Hobbies
Logged in as Guest
Users viewing this topic: scale9planes, cordline
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP F-7F Tigercat
Page: <<   < prev  39 40 41 [42] 43 44 45 46 47 48   next >   >>
Login
RE: KMP F-7F Tigercat - 7/18/2008 6:11:58 AM
camdyson
Status: offline
quote:
ORIGINAL: Blackwidow
Hmmmmm I'm not sure I understand the opposite aileron potential for the gyro during an engine out condition. Assuming both gyro's are in normal mode and no aileron inputs were given from the tranmistter why wouldn't the aileron gyro give control inputs to try to hold the wings level which is what you want regardless of the movement of the rudder? In full scale twins (aside from the mixture & prop controls) you identify the dead engine. push opposite rudder and raise the wing of the dead engine. Maybe I am missing something and if so I would really like to understand it better but I don't understand how the aileron gyro would drive the wings in the opposite direction. Thoughts?
Tom Rainwater
train@qualcomm.com
Yes, the aileron gyro WOULD attempt to level the wings. Unfortunately that's the problem!
If an aircraft is yawing/rolling to (say) the left, and you apply right aileron to correct, you are risking stalling the low/slow (remember engine out, and rotating around this tip) tip by adding a downward deflection of it's aileron. This just increases the angle-of-attack of the low tip, and can induce a tip stall and possibly the dreaded flick/death spiral.
It's far safer to ONLY use rudder to counter the yaw, and the wings should level themselves - you could dab the ailerons if needed but the gyro will just try to correct all the bank with opposite aileron.
Here's a link to the result of a tip stall on a nice twin:
http://www.youtube.com/watch?v=_T6HnDkigeo
Hope this explains it.
Cam
(in reply to Blackwidow)
       Post #: 1026
RE: KMP F-7F Tigercat - 7/18/2008 5:34:02 PM
VKerster
Status: offline
BLACKWIDOW, HERE'S THE PICS OF THE "COFFINS'..... THEY WORK EXTREMELY WELL. CUSTOM SIZED, BLOWN WITH PACKING FOAM. NOTE THE PVC FIELD STANDS. THE FUSE BOX IS 12"X83", AND THE WING BOX IS 33"X90".
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by VKerster -- 7/18/2008 5:37:28 PM >
_____________________________
VKerster
(in reply to VKerster)
       Post #: 1027
RE: KMP F-7F Tigercat - 7/18/2008 9:12:04 PM
CHARLES WINTER
Status: offline
Hi Jack and Sierra Retract users. The length of my retract strut on my main wheel is 5 1/4 inches from Pivot point to bottom of strut upper casing. (see enclosed picture). Is this the length you all have? Seems too long to me! Jack - You mention a +/- dimension of 3 5/8 in. from top to top. I don't know where you are using that number? As I said in a previous post, I must put a 3/4 in. block under my main gear so during retraction the wheel just touches the nacelle fiberglass. If the strut was shorter, I could reduce the thickness of the 3/4 in. block. Thanks
Col. Chuck Winter
Click for fullsize
Click for fullsize
(in reply to jbwilhelmi)
       Post #: 1028
RE: KMP F-7F Tigercat - 7/18/2008 9:42:14 PM
jbwilhelmi
Status: offline
Chuck
Am out of town until Sunday, will measure and repond then. The 3 5/8" dimension was fom the top of the former (the underside of the fiberglas nacalle) to the top of the 1/4" plate the landing ear spacer would sit on. All KMP parts.
Jack
(in reply to CHARLES WINTER)
       Post #: 1029
RE: KMP F-7F Tigercat - 7/20/2008 3:03:10 PM
cordline
Status: online
Hi further to tip stall,,,
This is a Tip Stall on take off..
The tail wheel is never lifted during the takeoff roll and the angle of attack is too high.
The Aircraft is taken airborne to soon without sufficient airspeed and the left wing is not flying.
www.youtube.com/watch?v=rlVpnCJAIkw&feature=related
       Post #: 1030
RE: KMP F-7F Tigercat - 7/22/2008 10:28:47 AM
cordline
Status: online
And here is another one,, www.youtube.com/watch?v=vfb6aGQJ93o&feature=related
(in reply to cordline)
       Post #: 1031
RE: KMP F-7F Tigercat - 7/22/2008 8:02:48 PM
chasrb
Status: offline
and on a happier note... Just weighed my TC and I was nicely surprised that it came in at 27.2 LBS!! The wing is 18.8 LBS and the fus is 8.4 LBS
This is dry weight. I was really thinking it would tip the scales at over 30 LBS.
The main components:
Twin Saito 170's
Two LiIon 5200's
One 3000 NiCd
Smatyfly power bus
all Hitec digitals...
Chasman
       Post #: 1032
RE: KMP F-7F Tigercat - 7/23/2008 2:21:25 AM
chasrb
Status: offline
Took the Tigercat to the club meeting, and as was said before by Vkerster or Charles Winters It was a big hit! I fired up the 170's did a few taxi passes down the runway with calls of go faster from the other club members - we all know what can happen we too much speed is applied...unscheduled flight!
So anyway I am glad I am alomst done with the build, all I really have left now is the gear doors. I'd like to find some spring open hinges so I can make a reak simple door mechinism.
Later
Chasman
(in reply to chasrb)
       Post #: 1033
RE: KMP F-7F Tigercat - 7/23/2008 3:15:44 AM
jbwilhelmi
Status: offline
Chuck
I have same 5 1/4" dimension. KMP must have framed slightly different. Let me know if there are any other dimensions I can help with.
Jack
       Post #: 1034
RE: KMP F-7F Tigercat - 7/23/2008 4:50:25 PM
P-51B
Status: offline
quote:
ORIGINAL: chasrb
Later
I am pretty sure I was the loudest one calling for more speed, UNFORTUNATELY Chasrb maintained his composure and kept the kitty on the ground. ( )
Here is a video of the taxi test: http://www.rcuvideos.com/item/LTP0M8PLQVXN7JRN
It is my first video upload, and I appologize, but all I had with me was my older digital camera (5mp -low res by today's standards) and it formats to quicktime .
I have another one that is a cloesup of the static engine runnup, but it is over the RCU size limit...
Click for fullsize
< Message edited by P-51B -- 7/23/2008 4:51:06 PM >
In order to think "outside the box", one must first accept there IS a box.
       Post #: 1035
RE: KMP F-7F Tigercat - 7/23/2008 5:16:07 PM
duber3
Status: offline
Hi Charb!!
The sound of your saito is really impressive, nothing to compare of my 2 little G20
nice job
       Post #: 1036
RE: KMP F-7F Tigercat - 7/24/2008 2:11:33 AM
Streetfuz
Status: offline
Hi, I'm new to the forum but I have a question and could really use some suggestions. I have the KMP Tigercat and am about 95% finished with the build. The big problem is how to hinge the "Main" gear doors on the lastest KMP version. The older ones came with a slotted cover that just screwed on and then the main gear just went in and out of it, not too scale! Now the later ones have two gear doors per side. Problem now is the compond curves of the doors make impossible to get a hinge set up that works. I'm trying work with Robart hinges, they seem the best so far but are proving a "Bear" to install. Just using expoxy I don't beleive will stand the air pressure from landing or taking off. Any one out there that has built one of these and solved the proble?
The other problem which has been solved by friend and co-builder is the front nose gear and no way to keep it turning as it goes down it to and comes out of the nose. The factory forget to put a spring set up on it like all the other retrack systems out. What we did was design and duplicate a system very similar to Robart's nose wheel struct. Works just fine but someone that hasn't put too many "War Birds" like the Tri Gear F7F together will have a real problem. Anyone that needs further info on the nose gear, please contact me. This problem seems to be for all KMP Tri-Gear Gen II through Gen V, inculding non War Birds, any tri-gear system, either spring down air up or all air up/down has the same problem.
I understand that Andrew (KMP) is working on getting it solved but as of now it's still a problem. The F7F is a Great looking War Bird but once these problems are over come it should be a much better seller. We all know how money you put into a War Bird like this so I don't want anything to happen that could of/should of been corrected when they were designed. Tom
(in reply to wayneparrish)
       Post #: 1037
RE: KMP F-7F Tigercat - 7/24/2008 4:15:01 AM
bignuts181
Status: offline
nice work chasrb your tiger cat sure sounds nice, whats your final all up weight??
cheers Rossco.
(in reply to Streetfuz)
