RE: KMP F-7F Tigercat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP F-7F Tigercat
Page: <<   < prev  52 53 [54] 55 56 57 58 59 60 61   next >   >>
Login
RE: KMP F-7F Tigercat - 3/21/2009 10:51 AM
ghost.fr
Score: 100
Last Login: 7/12/2011
Status: offline
the top of the wing with the air filler so easy access and idden
_____________________________
P51 182cm 150saito
Corsair 192 cm 120OS
Hide Signatures
(in reply to scale9planes)
       Post #: 1326
RE: KMP F-7F Tigercat - 3/21/2009 11:50 AM
Ron McGrath
Score: 100
Last Login: 5/7/2013
Status: offline
It's on the wheels! and one prop 19x10 graphite prop.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
RON McGRATH
Hide Signatures
(in reply to ghost.fr)
       Post #: 1327
RE: KMP F-7F Tigercat - 3/21/2009 12:59 PM
Ron McGrath
Score: 100
Status: offline
A few more pics of the build along the way!
Click for fullsize
< Message edited by Ron McGrath -- 3/21/2009 1:25 PM >
RON McGRATH
Hide Signatures
(in reply to Ron McGrath)
       Post #: 1328
RE: KMP F-7F Tigercat - 3/21/2009 1:26 PM
Ron McGrath
Score: 100
Status: offline
Ok a little smaller.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ron McGrath -- 3/21/2009 1:32 PM >
RON McGRATH
Hide Signatures
       Post #: 1329
RE: KMP F-7F Tigercat - 3/21/2009 8:53 PM
CHARLES WINTER
Score: 105
Last Login: 5/24/2013
Status: offline
Hi Scale 9 (Don't know your first name) Thanks for your response. If your Tigercat weighs-in at the weight many other Tigercat owners have -25 to 30 lbs, I feel you may be VERY low on power with 90 size engines for safe flight and for sure if you loose and engine in flight you will have basically no power for possible flight to a safe landing. The other subject is your control of the elevator with one servo. What many modelers forget, is that one of the Primary reasons for two servos is if you have one servo go BAD you have a back-up servo to get YOU HOME for another day. Another Plus for a second servo is the ability to adjust each elevator so you have similar trim position of each elevator. Have FUN, press-on and keep us up-dated with your project. Col. Chuck Winter
Hide Signatures
       Post #: 1330
RE: KMP F-7F Tigercat - 3/21/2009 9:05 PM
CHARLES WINTER
Score: 105
Status: offline
Ron, Very impressive installation of all components, but my MAIN question is "How do you keep your workshop so NEAT". Col. Chuck Winter
Hide Signatures
       Post #: 1331
RE: KMP F-7F Tigercat - 3/22/2009 6:48 AM
Ron McGrath
Score: 100
Status: offline
You have a neat freak build it in their shop I just pay for it! Lucky for me, A good friend of mine is doing the build. We hope to have it done for the Nall and will finish up the year at the NEAT FAIR (barring any problems)with lots of meets in between. Both of us belong to traveling R/C club named the R/C Gypsies. Here is a link to the meets we attend in the western New York area. Always a Great time camping at the feilds!
http://www.rcgypsies.net/calender.htm
RON McGRATH
Hide Signatures
(in reply to CHARLES WINTER)
       Post #: 1332
RE: KMP F-7F Tigercat - 3/22/2009 7:08 AM
F82FAN
Score: 100
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: CHARLES WINTER
Hi Scale9, What size engines are you using, they look VERY small for this size airplane. I had originally used 2 RCV 90 engines and they were not at all adequate. Also using 1 (one) servo on the elevators and that common wire connecting both elevators may not be a SAFE design. Something to think about. Col. Chuck Winter
Hi Col.,
We used a common wire elevator joiner on mine and it has numerous flights at full tilt with a pair of YS 1.20AC's wailing away on each side. We used a nice thick 5/32" piano wire and it is working fantastically. MUCH safer (IMHO) than the flexible pushrods that were included with the kit...
I'm using a strong digital servo and a carbon fibre rod with 4-40 titanium ends as the pushrod and it is rock solid.
The common joiner assures that both halves stay aligned - so no individual trimming is needed.
The only issue would fall under redundancy, but I can say that, in all my years of doing this, I've not had a quality servo fail on a flight control - ever. Doesn't mean it can't, just that it hasn't. I've had old, cheap servos stop working when used as a gear actuating servo, but never a digital...
I do agree about the power issue. If one of those .90's goes away, I wouldn't want to be at the sticks either!
HANGAR.... YOU KEEP PLANES IN THE HANGAR!!!!
Hide Signatures
       Post #: 1333
RE: KMP F-7F Tigercat - 3/22/2009 7:14 AM
F82FAN
Score: 100
Status: offline
quote:
ORIGINAL: Ron McGrath
Hi Ron,
Good thing you sprung the dough for the Sierras up-front. You will NOT regret it. You also won't ever know HOW much you have missed out on in terms of frustration by doing them from the start!
Looking great.
I would love to hear what a pair of 19" 3-bladed props sounds like up there. WOW!
Keep us "slimer" boys updated. I'd like to know what your all up weight is with batteries when you are ready to fly.
Hide Signatures
       Post #: 1334
RE: KMP F-7F Tigercat - 3/22/2009 7:34 AM
Ron McGrath
Score: 100
Status: offline
With any luck It will be under 30lbs The first setup we were considering would have weighed 2.25lbs less. this is much closer to scale props I think we will end up with 18x10 3 blade Mejzliks that will be in the 6.5 to 7 hp range or 5000 watts/ 166 watts per pound.
I am surprised no one has noticed the wing tubes.
Click for fullsize
< Message edited by Ron McGrath -- 3/22/2009 7:37 AM >
RON McGRATH
Hide Signatures
(in reply to F82FAN)
       Post #: 1335
RE: KMP F-7F Tigercat - 3/22/2009 8:48 AM
F82FAN
Score: 100
Status: offline
That's enough electrons to blow my head off of my shoulders! Woo Hoo, it should go good.....................................
I noticed that it looks like it's from a Hangar 9 Extra 260 ? Why didn't you mount the tube in the outer panel to REALLY shorten the span??? I guess every bit helps... Not being critical - just askin
You've got Watts n Gear Doors - I've only got the Sierras!
Regards,
Wally
Hide Signatures
       Post #: 1336
RE: KMP F-7F Tigercat - 3/22/2009 8:58 AM
Ron McGrath
Score: 100
Status: offline
The wing tube is not attached to the outer or inner wing it just slides out of the center section for easy storage.
RON McGRATH
Hide Signatures
       Post #: 1337
RE: KMP F-7F Tigercat - 3/22/2009 2:17 PM
tongoede
Score: 100
Last Login: 12/28/2009
Status: offline
Hi Foks,
Here some pix of mine F7F tigercat....
It's ready to go...
airframe: KMP
engines: 2 x OS FS 200
prop 16 x 8
Landing gear: Sierra
weight: 12, 5 kg
Soon some pix of the maiden flight will follow...
regards,
Ton
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1338
RE: KMP F-7F Tigercat - 3/22/2009 2:47 PM
tongoede
Score: 100
Status: offline
Hi Cat boys,
here some more detailed pix of the inside.....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tongoede)
       Post #: 1339
RE: KMP F-7F Tigercat - 3/22/2009 9:47 PM
CHARLES WINTER
Score: 105
Status: offline
Hi Ron & Ton, Great pictures from both of you CAT guys. It's always interesting how MANY different approaches are taken to solve a similar problem. I think that is what makes this hobby FUN and at times Very Frustrating. GOOD SHOW guys. Col. Chuck Winter
Hide Signatures
       Post #: 1340
RE: KMP F-7F Tigercat - 3/23/2009 6:12 AM
F82FAN
Score: 100
Status: offline
AAhhhh, good deal!
Hide Signatures
       Post #: 1341
RE: KMP F-7F Tigercat - 3/23/2009 10:01 AM
Ron McGrath
Score: 100
Status: offline
I like the scale art work on the nose gear door. The linkage to the door is very creative. Tongoede, have you flown your Tiger cat yet? Also, did you reinforce the center section of the wing were the wing tubes are I noticed you did cut several holes in the fiberglass sheeting for the equipment installation are you worried about it being weakened ?
RON McGRATH
Hide Signatures
       Post #: 1342
RE: KMP F-7F Tigercat - 3/23/2009 1:57 PM
tongoede
Score: 100
Status: offline
Hello Ron,
No , the bird is still waiting for its first maiden flight.
I need a big enough airstrip for trying out.
Our Clubfield is maybe big enough, but I am not sure.
I think the cat needs a big landingfield because of the wing/ weight ratio.
I don't think T/o will be a problem....Power enough...
I did reeinforce the center wing section, so I am not worry about the strength...
Engines now are running very reliable and smooth.
I am using a twinsync system from rc showcase with the glowsystem together, and its working very nice!!!!
I also made my wingtip sections seperate, for easy storing and easy transport.
I am using the 2 receiver system of ACT, so all servo's are individually programable. together with the power box and 2 x 5 cell 2400 mAh batteries all works very nice!
Now, lets hope it will fly nice too!!!!! You know what they say; when it looks right , it flies right!!!!
Ton
Hide Signatures
       Post #: 1343
RE: KMP F-7F Tigercat - 3/23/2009 6:49 PM
Ron McGrath
Score: 100
Status: offline
Hi Tongeode
How did you reinforce the center section of the wing? and what RPM do you get on the 16x8 3 blade master airscrew prop? I was roing to use 16x10 3 blade master airscrew but decided to go with a 18x10 mejzlik after doing some testing on the ground.
Also.......................I like the white gear!
RON McGRATH
Hide Signatures
       Post #: 1344
RE: KMP F-7F Tigercat - 3/23/2009 8:41 PM
tongoede
Score: 100
Status: offline
Hello Ron,
Yes the gear has been painted white....just as the original...
The center section of the wing is reiinforced with two multiplex spares with carbon strings.It looks a lot like the reinforcement of col. Chuck Winter....
The rpm on the master airscrew 16 x 8 is around 8800 Rpm....
Power enough I would think
He Ron aren't You are going to use the carbon 19 x 10 prop? looks awefully cool on the cat!!!!
What kind of motor are you going to use?
cheers,
Ton
Hide Signatures
       Post #: 1345
RE: KMP F-7F Tigercat - 3/23/2009 9:26 PM
tongoede
Score: 100
Status: offline
He Ron,
Here some more pix of the wing tips ....
the alu. tubes are fixed in the wing tip part, and when mounted they are going through the nacelles to the center wing part, where they are mounted with a nylon M4 bolt.
cheers,
Ton
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1346
RE: KMP F-7F Tigercat - 3/23/2009 11:19 PM
CHARLES WINTER
Score: 105
Status: offline
Hi Ron, Question Did you make the Nose Gear Door stand-off unit (Looks like brass) that engages the TRACKS in the Nose Gear Door. I have my Sierra Retracts working well and holding 100 PSI for many hours in the UP and Down position. Hope to get another flight in tomorrow. If all goes well I want to re-attach all my doors but have to make a Nose Gear door Pulling Unit. Thanks Col. Chuck Winter
Hide Signatures
       Post #: 1347
RE: KMP F-7F Tigercat - 3/24/2009 8:47 AM
Ron McGrath
Score: 100
Status: offline
Hi Charles
A friend Of mine is doing the build, I have seen it but could not tell you exactly How its made. I do know it took a long time.
RON McGRATH
Hide Signatures
       Post #: 1348
RE: KMP F-7F Tigercat - 3/24/2009 7:04 PM
Capt G
Score: 100
Status: offline
I made my wings removable too. Now that the other cat is done , i am starting on the T-cat in earnest.
Hide Signatures
       Post #: 1349
RE: KMP F-7F Tigercat - 3/24/2009 10:46 PM
Capt G
Score: 100
Status: offline
Main wing mounted. I used 1/4 x20s - 3" steel in the front and 2" aluminum in the back. Better than the Chinametal and plastic i think. Also 1/4 x20 outer wing mounting bolt. Secures and locates in one.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Capt G)
       Post #: 1350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.140RCU1
