RE: KMP F-7F Tigercat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Ziroli SBD Dauntless - RTF
Seller:  misfit
Details:   $3,000.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP F-7F Tigercat
Page: <<   < prev  76 77 78 79 80 81 82 83 84 [85]
Login
RE: KMP F-7F Tigercat - 1/30/2013 5:06 PM
ramboman
Score: 100
Last Login: 5/21/2013
Status: offline
This the log for a short fly of my TC. You may need to extrapolate data...
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Ron McGrath)
       Post #: 2101
RE: KMP F-7F Tigercat - 1/30/2013 5:11 PM
Ron McGrath
Score: 100
Last Login: 5/27/2013
Status: offline
I also have a Stinson 108 27lbs 10 ah battery the same as in the Tigercat and only one motor. I can fly the Stinson for 25 min. it is just not the same. With the tigercat I am going to guess that you will be at a minimum of 48% less flight time because a 7s a123 setup has 60% of the voltage a 10s Lipo setup has then you are only 92% of the battery over all capacity so even if the packs are the same c rating maximum discharge currents are lower and results in higher voltage drop and less watts.
_____________________________
RON McGRATH
Hide Signatures
(in reply to ramboman)
       Post #: 2102
RE: KMP F-7F Tigercat - 1/30/2013 5:38 PM
ramboman
Score: 100
Status: offline
@ron... you are right, but you have got my real life figures...
Another graph shows voltage drop under maximum power... it's relatively high but you have to know that between the battery and the controller, I have also a SPS main switch and a Jeti MUI for telemetry.
a123 cells are design for 70A each (120A peak). Current is not critical.
Click for fullsize
Hide Signatures
       Post #: 2103
RE: KMP F-7F Tigercat - 1/30/2013 5:53 PM
Dangaras
Score: 255
Last Login: 6/1/2013
Status: offline
I will be generating almost 4000W for the Tigercat.. Now it is supposed to be 30lbs AUW. My 92" A-26 weighs about 16.5lbs and max power is about 2300W on 5 cells. I went from Turnigy SK42-50-650Kv to Aolean 42-60-600Kv and saw an amazing change in power and performance.
Detect language » Hungarian
Don''t be divided from the truth by what you would like to believe.
Hide Signatures
       Post #: 2104
RE: KMP F-7F Tigercat - 1/31/2013 5:42 AM
ramboman
Score: 100
Status: offline
My first choice for my Mossie was a pair of Scorpion 5525/225 turning 18*12*3 props with CC ICE2 80 and two 12s2p a123.
That's 3.5kg for both packs, too high... In Belgium, we have a lot of administrative paper to fill for any plane heavier than 12kg all included.
The alternative was to change for LiPos (I don't like LiPos) or to find a motor with enough power and less a123 cells.
That's the reason for the Hacker. It turns under 7s2p a123 i.e. 1kg per pack, 2kg total instead of 3.5kg...
I am open to any alternative because the Hacker is very expensive...
Hide Signatures
(in reply to Dangaras)
       Post #: 2105
RE: KMP F-7F Tigercat - 1/31/2013 10:03 AM
Ron McGrath
Score: 100
Status: offline
For a non-Electric plane does the 12kg include fuel?
RON McGRATH
Hide Signatures
       Post #: 2106
RE: KMP F-7F Tigercat - 1/31/2013 10:43 AM
ramboman
Score: 100
Status: offline
No !
That's unfair ;(
Hide Signatures
       Post #: 2107
RE: KMP F-7F Tigercat - 1/31/2013 5:20 PM
airraptor
Score: 131
Last Login: 6/19/2013
Status: offline
got with a GAS engine.. Problem solved...
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 2108
RE: KMP F-7F Tigercat - 2/12/2013 3:21 AM
brokenrudder55
Score: 100
Last Login: 5/8/2013
Status: offline
    Hey guys  just got my esm tigercat today shinny coat .Going to put a pair of zenoah 26's on it. also got a cockpit for front and rear.
Hide Signatures
(in reply to airraptor)
       Post #: 2109
RE: KMP F-7F Tigercat - 2/12/2013 2:20 PM
Dangaras
Score: 255
Status: offline
Where did you get the cockpits from?
Hide Signatures
(in reply to brokenrudder55)
       Post #: 2110
RE: KMP F-7F Tigercat - 2/12/2013 4:04 PM
flytaildragger
Score: 112
Status: offline
http://www.magnumrc.com/ESMF7F-TigercatCockpit_p_60.html
I used these, they are great!
flytaildragger;
The skill is in the rudder!
Hide Signatures
       Post #: 2111
RE: KMP F-7F Tigercat - 2/12/2013 4:14 PM
Dangaras
Score: 255
Status: offline
Ah  yes, the Dynamic Balsa cockpit...
Thanx
Hide Signatures
(in reply to flytaildragger)
       Post #: 2112
RE: KMP F-7F Tigercat - 2/12/2013 9:58 PM
brokenrudder55
Score: 100
Status: offline
       Dangara,    igot the cockpit kit from dbalsa.com
Hide Signatures
       Post #: 2113
RE: KMP F-7F Tigercat - 2/13/2013 3:35 PM
Eddie P
Score: 120
Status: offline
Wow the DB cockpit at $99 seems a little steep for a single cockpit only, but it does look great and for sure value is in the eye of the beholder. As a turbine jet guy myself I've spent hundreds at a time on cockpits, and I am guilty as charged... but the most gratifying ones for me were cheap custom ones I built myself. I have made many cockpits from plastic styrene sheet and Testors paints, usually the whole thing costs about $10 to build using plastic, model cement, and a color printer using photoshop to print out instruments panels. An alternative is to buy the Top Flite 1/7 Corsair cockpit kit and stretch the kit into two cockpits with spare styrene sheets for less than $30, or just buy two (for $52 for both) and use parts from the second and a few bits if plastic to make the second "pit" more purpose looking if one is trying to save weight and money. I've used the Top Flite kits in high dollar jets that were not completely scale but gave the illusion of scale for a good weight and price. Plus many specific cockpits sold out there are not really scale to begin with, they are sorta scale and the sins of using another cockpit that is very close is no farther away from scale at times. Just a few ideas. (pictures below are not mine, but they are of the cheap TF Corsair cockpit that could be customized for an F-7F)
Oh, edit - to save some money and time, you can buy a pre painted ARF cockpit for the Gold Edition Corsair .61 ARF for less than $18 if customization of the "kit" is not important. You'd need a few bits of balsa to frame it under the plastic parts in but it would be simple and easy.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBAND&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZ04&P=7
not sure what the difference is between the cockpit kits but same price
Click for fullsize
Click for fullsize
Click for fullsize
Eddie P - NOT sponsored - I pay the bills of hobby manufacturers with my purchases - Free to evaluate products honestly
Hide Signatures
       Post #: 2114
RE: KMP F-7F Tigercat - 2/13/2013 5:53 PM
flytaildragger
Score: 112
Status: offline
You get both cockpits, not just one. Front and Rear... I bought one and put it together. The DB also comes with a step by step assembly DVD so you don't hack up your deck in experimentation. There isn't much room on that ESM F7F to experiment.
flytaildragger;
Hide Signatures
(in reply to Eddie P)
       Post #: 2115
RE: KMP F-7F Tigercat - 5/6/2013 8:51 PM
CRJDriver
Score: 100
Status: offline
Just keeping this thread alive!  I got my hands on an original, barely started composite KMP kit.  Power is the new OS 22 GT gassers.  It was a bit of work to get them to fit but they are completely concealed within the cowls.  I plan on starting with the 3 blade master airscrew 14x9s as they have proven to be highly effective in powering my first, and still flying, Tigercat.  Here are a few pix.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2116
RE: KMP F-7F Tigercat - 5/6/2013 8:54 PM
CRJDriver
Score: 100
Status: offline
Some more....  Now, what to do with 2 fully functional Tigercats?
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to CRJDriver)
       Post #: 2117
RE: KMP F-7F Tigercat - 5/7/2013 2:27 AM
F82FAN
Score: 100
Status: offline
Fly early - and often!!!
Should have mine back in the air after a re-engine job soon too.
Enjoy!!!!!
HANGAR.... YOU KEEP PLANES IN THE HANGAR!!!!
Hide Signatures
       Post #: 2118
RE: KMP F-7F Tigercat - 5/27/2013 7:31 AM
CHARLES WINTER
Score: 105
Status: offline
Hi Tigercat Guys. Had a Great weekend at Castle Airport located at Atwater Cal. It was the IMAA Mini-Fest. Great flying location with thousands of feet of concrete in all directions. My Tigercat was one of the HITS at the show. People are surprised at the speed and smooth running of my Fuji engines. Chuck Winter PS. Having problems sending pictures AGAIN...
Hide Signatures
(in reply to F82FAN)
       Post #: 2119
RE: KMP F-7F Tigercat - 5/31/2013 6:44 AM
CHARLES WINTER
Score: 105
Status: offline
Hi Tigercat Guys - Still can't download pictures Really SUCKS Chuck Winter
Hide Signatures
(in reply to CHARLES WINTER)
       Post #: 2120
RE: KMP F-7F Tigercat - 5/31/2013 4:33 PM
flytaildragger
Score: 112
Status: offline
Hi Chuck, Microsoft Office is a good program on one's computer to downsize the size of the pixels in your photos. Thereby making them downloadable. I do this all the time. I have a digital camera that takes pics that are in megabytes. After I downsize the picture and save it as such, it makes them about 3-400 kilobytes which the program in RC Universe can handle. I know it's frustrating to get some great footage, and can't share it.....
flytaildragger;
Hide Signatures
       Post #: 2121
RE: KMP F-7F Tigercat - 5/31/2013 4:41 PM
flytaildragger
Score: 112
Status: offline
My bird is laid up for a while. I have decided to switch from 72 Mghrz to 2.4 with it. What I am afraid of is the 13 fast high torque digital servos going through the receiver. Owning a KMP full composite, I certainly do not want to lose it with a stupid brown out. I am saving the money to install a power distribution board that funnels all that amperage through the board and not the receiver. It seems to be a logical solution. Especially when a friend of mine used high end HD servos in his Yak and it browned out!!! Luckily it was on the bench. Those HD's seem to draw a lot of amperage.
flytaildragger;
Hide Signatures
       Post #: 2122
RE: KMP F-7F Tigercat - 6/1/2013 7:30 AM
CHARLES WINTER
Score: 105
Status: offline
Hi Flytail. I have been downloading many many pictures on this thread for over 3 years with no problems. Just recently having trouble and I think it's RCU. I'll try a download on this message. Chuck PS Just realized I changed cameras and don't have it set up correctly. DUMB Chuck...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2123
RE: KMP F-7F Tigercat - 6/6/2013 3:11 PM
AeroGasRC
Score: 100
Status: offline
All you guys have to see this site, if you like Scale details check this: http://www.iflytailies.com/
Doug Styles
http://www.aerogasrc.com/
< Message edited by AeroGasRC -- 6/7/2013 2:07 AM >
Hide Signatures
       Post #: 2124
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.111RCU1
