DOminator 1500
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Scale Racing >> DOminator 1500 Page: [1] 2   next >   >>
Login
DOminator 1500 - 10/2/2006 1:16:09 AM
glowplug50
Status: offline
What kind of participation in this class is being experienced? Are there enough competitors to make this a worth while investment?
If so, what is the prefered engine, the Tigre or the Moki. Also, what are typical top speeds with this airframe?
       Post #: 1
RE: DOminator 1500 - 10/2/2006 9:27:09 PM
DMyer
Status: offline
On the same subject.... if all the dimensions of a Lanier 1500 dominator are followed.... are airfoils. moments etc allowed to be modified?
(in reply to glowplug50)
       Post #: 2
RE: DOminator 1500 - 10/2/2006 10:14:47 PM
glowplug50
Status: offline
I don't beleive so as is this is supposed to ne a one design competition. I could be wrong.
(in reply to DMyer)
       Post #: 3
RE: DOminator 1500 - 10/3/2006 2:46:47 AM
glowplug50
Status: offline
Not to be impatient but is anyone racing these planes?
       Post #: 4
RE: DOminator 1500 - 10/3/2006 3:30:26 AM
Lifes a Drag
Status: offline
They will be racing at Parker Arizona this month.
http://www.usrainfo.org/2006Blue%20Waterflyer.pdf
http://www.usrainfo.org/AZentry.pdf
       Post #: 5
RE: DOminator 1500 - 10/4/2006 2:28:34 PM
Captain Easy
Status: offline
Pilots at the usra races use the moki 2.10
the dom plane specs are in usra rule
kit is prefered but scratch building is ok built to specs
(in reply to Lifes a Drag)
       Post #: 6
RE: DOminator 1500 - 10/4/2006 3:03:25 PM
DMyer
Status: offline
My reading of the specs are basically minimum measurements at various locations plus exposed control horns.... there is nothing that specifies airfoils... pinching the fuse sides in after wing etc or many other minor mods that add up to a slicker airframe similar to what is done in 428 racing. Always wanted to build one of these for fun... or even to race if there ever was a convienent opportunity on the east coast.
(in reply to Captain Easy)
       Post #: 7
RE: DOminator 1500 - 10/4/2006 3:34:46 PM
Captain Easy
Status: offline
DMyer
All those things you suggested to do have been done
Skin hinges and wipers are definitely not allowed
mike
(in reply to DMyer)
       Post #: 8
RE: DOminator 1500 - 10/4/2006 6:38:56 PM
DMyer
Status: offline
Then it should be put into the rules exactly what is/or is not allowed otherwise if I built a homegrown Dominator sporting a 66-012 airfoil fiberglassed/painted wing with skinned sealed hinges and showed up at a race I would expect to fly as nothing in the rules states I can't do that. It may be obvious to you and the others flying this provisional class that it is not the intent to permit these types of mods to the one-design - but unless you put the cap on the genie he will get out.... as an example Quickie 500 is a long long way from the original intent Spickler 500 and a K&B in cost, complexity amd number of pilots participating. JMO. And I still have always wanted to build one of these.
       Post #: 9
RE: DOminator 1500 - 10/4/2006 8:52:08 PM
DHG
Status: offline
"Simple rules" complicate your life. Complete, well-thought-out rules simplify your life.
Every. Single. Time.
(in reply to DMyer)
       Post #: 10
RE: DOminator 1500 - 10/5/2006 1:37:05 AM
glowplug50
Status: offline
Speeds????????
(in reply to DHG)
       Post #: 11
RE: DOminator 1500 - 10/5/2006 1:56:33 PM
Captain Easy
Status: offline
glowplug50
dominator speeds are in the 130 mph range
times for the 6 laps 125 seconds for fast time
       Post #: 12
RE: DOminator 1500 - 10/6/2006 12:31:42 PM
glowplug50
Status: offline
Thankyou for the response. Getting info on this plane is like pulling teeth.
       Post #: 13
RE: DOminator 1500 - 10/6/2006 2:01:36 PM
HighPlains
Status: offline
What prop and RPM are the Moki's turning?
_____________________________
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
       Post #: 14
RE: DOminator 1500 - 10/6/2006 2:34:27 PM
Captain Easy
Status: offline
HighPlains:
APC 17x12 is supplied by the race cd
RPM's around 8500
(in reply to HighPlains)
       Post #: 15
RE: DOminator 1500 - 10/10/2006 3:16:44 AM
glowplug50
Status: offline
Does anyone know who if any one is selling the Moki 210.
       Post #: 16
RE: DOminator 1500 - 10/11/2006 8:26:41 PM
Wreckless Racing
Status: offline
the Moki 2.10 is still being sold...im not sure on the site...try surfing around but i do know for a fact that Moki is still in production.
Cole
Mugen MBX5-T- O.S. Speed
RC8- O.S. V-spec
       Post #: 17
RE: DOminator 1500 - 10/11/2006 10:28:51 PM
