UkerDuker
TN, USA Status: offline
This is the start of my next project, a Palmer plans 132" C-130. The fuselage frames up relatively quick with only a few headaches. As I have found, then plans are acurate only to a point. For anyone building this, plan about three steps ahead to make sure all the subsequent parts will fit. I found out the hard way as I posted a couple days ago. Lucky for me, it was an easy fix. *****As a reminder, use 1/4x3/8 on the lower fuse box frame, not the 1/4x1/2 the plans call for.***** Also, at first glance, the PCK package is really nice. As I begin building, it's lacking several parts or they are not the correct size(balsa). For instance, I dont have enough 1/32 sheeting for the fuselage formers 14&15. The diagonal braces included were 1/8x1/4 instead of the 1/4x1/4 the plans call for. I'm sure there will be more, but it definately looks like a difficult plan to cut all the pieces. As with my Hawkeye build I will document most of my progress. My Hawkeye is currently done and awaiting prime and paint. I will probably wait until it warms up in the spring to paint it. More to follow... Mike
