RE: Palmer 132" C-130 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Palmer 132" C-130 Build
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Palmer 132" C-130 Build - 1/7/2007 9:14:57 PM
UkerDuker
Status: offline
ALRIGHTY,
Today, my ramp hinge concept has become reality. Using 2 brass tubes (1/8 & 5/32 I think) and a .025 strip of brass, I constructed my hinge. I only caused a small fire in the workshop while soldering with my mini-torch.
Here is the hinge mock up:
Pic 1= shows the basic construction and fit of the hinge. I used a large center tab that will attach to the ramp. The two smaller tabs will be attached to the lower fuselage.
Pic 2= Ramp Closed, no hinge issues
Pic 3= Ramp opens much further than picture depicts, I limited it with a plastic cup to the approx opening distance.
Pic 4= Shot of the ramp looking forward. There will be a minimal gap at the hinge point.
Mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to schwatd)
       Post #: 76
RE: Palmer 132" C-130 Build - 1/8/2007 3:22:03 AM
schwatd
Status: offline
Mike,
I like that ramp hinge alot, nice work on figuring out the geometery of the ramp travel.
_____________________________
Calm Winds & Smooth Landings
__________________________________________
(in reply to UkerDuker)
       Post #: 77
RE: Palmer 132" C-130 Build - 1/8/2007 3:59:44 AM
UkerDuker
Status: offline
Troy,
Its a slick hinge and seems to work out well with its position. I made a similar hinge for the upper ramp. It takes alittle time to line up the tabs, but its strong once soldered.
Mike
Click for fullsize
Click for fullsize
       Post #: 78
RE: Palmer 132" C-130 Build - 1/8/2007 11:07:08 AM
schwatd
Status: offline
Mike,
Are you attaching the hinge with epoxy or fastners?
       Post #: 79
RE: Palmer 132" C-130 Build - 1/8/2007 1:48:23 PM
UkerDuker
Status: offline
Troy,
I will probably use a combination of both. My first thoughts for mounting are to drill multiple holes to allow more surface area when epoxying. Then put a screw through the center to permanently attach the hinge.
The upper ramp hinge will be trimmed to follow the contour.
Mike
       Post #: 80
RE: Palmer 132" C-130 Build - 1/9/2007 3:49:08 AM
mario tavarez14
Status: offline
this is my c130
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mario tavarez14 -- 1/9/2007 3:56:29 AM >
       Post #: 81
RE: Palmer 132" C-130 Build - 1/9/2007 4:27:25 AM
schwatd
Status: offline
Mario,
Very Nice
(in reply to mario tavarez14)
       Post #: 82
RE: Palmer 132" C-130 Build - 1/9/2007 1:47:38 PM
UkerDuker
Status: offline
Mario,
Wow, thats a sharp looking aircraft! I hope mine looks as good when I'm done.
Troy,
Where are the NAV, Strobe, and landing lights on the C-130? I think I know, but I want to make sure.
Mike
       Post #: 83
RE: Palmer 132" C-130 Build - 1/9/2007 2:52:24 PM
drdoom
Status: offline
Mario, that's Sweet...
AMA #70046 Jet Junkie!
       Post #: 84
RE: Palmer 132" C-130 Build - 1/9/2007 4:33:11 PM
schwatd
Status: offline
Mike,
The landing lights are located inside the main gear doors and on a mount near the front of the hard points for the aux fuel pylon. A total of 4 lights. The nav lights,.... there is a clear domed red strobe just behind where the nose gear aft door stops. Ah I'm gonna need to look at a few more things to give you better specifics on location and type.
(in reply to drdoom)
       Post #: 85
RE: Palmer 132" C-130 Build - 1/10/2007 3:09:35 AM
schwatd
Status: offline
Hey Mike and anyone else thinking about the c-130
well Mike don't shoot me but I took apart what I had built and am adding the extension mods from Lockheed. Will try to get up the additional drawing tomorrow.
       Post #: 86
RE: Palmer 132" C-130 Build - 1/10/2007 4:00:46 AM
UkerDuker
Status: offline
Troy,
What mods are you referring to?
Mike
       Post #: 87
RE: Palmer 132" C-130 Build - 1/10/2007 2:19:33 PM
schwatd
Status: offline
I've included the file that explains the mod. Well, I could only upload the pic.
Click for fullsize
       Post #: 88
RE: Palmer 132" C-130 Build - 1/11/2007 4:03:56 AM
UkerDuker
Status: offline
Troy,
What exactly is the mod? It looks like you will be extending the fuselage.
Mike
       Post #: 89
RE: Palmer 132" C-130 Build - 1/11/2007 1:07:23 PM
