RE: Palmer 132" C-130 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Palmer 132" C-130 Build
Page: <<   < prev  49 50 [51] 52 53 54 55 56 57 58   next >   >>
Login
RE: Palmer 132" C-130 Build - 2/8/2009 2:59 PM
rcmiket
Score: 116
Last Login: 5/25/2013
Status: offline
Its not uncommon while a project of this size is under construction to get burned out and walk away for while. I've found myself in the same situation. I'm sure Mike will resurface. Doesn't mean the rest of you cant carry on. Mike
_____________________________
"while inverted down is up and up is expensive!!!"
Hide Signatures
(in reply to Props4ever)
       Post #: 1251
RE: Palmer 132" C-130 Build - 2/18/2009 2:47 AM
mironpopescu1
Score: 100
Last Login: 11/6/2009
Status: offline
here is something new : finally got a good day to fly my C 130 Coast Guard scheme some of you had seen it pictured above. Frank the Oltimer made the trip from Sarassota with two friends to see the event. My 4 cycles OS 70 lifted up that plane in less than 50 feet of run. Needed a bunch of down trim and leveled it was flying like a beautifull white bird. Just GREAT. Landing was very good although that down trim eat some of my up elevator and could not make the landing low and long . But nice landing. Something else to mention : it is little more difficult to make rigth turn may be because of the torq effect. lso I belive that Palmer numbers of stab 2 deg neg, wing 5 deg pos and zeo thrust on engines adds up correctly even if you move the cg between 28 - 30 % . His 4.62 in as per the plan altough approaches 30 % is still conservative. I will fly it next Monday at 32 %. If you have any comments or questions you are welcome. Mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rcmiket)
       Post #: 1252
RE: Palmer 132" C-130 Build - 2/18/2009 3:31 AM
UkerDuker
Score: 100
Last Login: 9/6/2010
Status: offline
Congratulations Mike! Your plane looks great in the air. Thanks for the information.
Hide Signatures
(in reply to mironpopescu1)
       Post #: 1253
RE: Palmer 132" C-130 Build - 2/19/2009 12:19 PM
Props4ever
Score: 106
Last Login: 5/24/2013
Status: offline
Very nice Mike, Congratulations on beautiful maiden flight, cant wait to see more of great flight pictures....
I do believe in KISS (Keep it simple silly), but doesn''t mean my models fall in this category!
CUB BROTHERHOOD# 173
Hide Signatures
(in reply to UkerDuker)
       Post #: 1254
RE: Palmer 132" C-130 Build - 2/20/2009 2:25 AM
oltimer
Score: 100
Last Login: 4/17/2013
Status: offline
I witnessed Mike's first flight and he did a masterful job of flying. His aircraft is beautiful and handled well after a very long wait to get the right weather conditions. We have had a tremendous amount of wind this year. Mike had his engines singing like racing engines and they performed flawlessly! This airplane weighs in a about 38 pounds with fuel and it rolled about 50 feet or so and rose into the air at approximately a 30 degree angle. The flight was uneventful until the landing where Mike did not want to use the flaps as he had not established exactly how much elevator would be required. This make the landing a little exciting as the plane came in very fast and Mike said later that it was dropping like a rock. He said that it took full up elevator to flare and it did come down rather hard but not too hard as it stuck and rolled to a perfect stop. Mike is to be congratulated for his flying skill and successful maiden flight.
I planned to take video of the flight but dumb me wore polorized sun glasses and after the plane left the ground I couldn't see anything in the camera lens.
Hide Signatures
       Post #: 1255
RE: Palmer 132" C-130 Build - 2/20/2009 3:22 AM
Props4ever
Score: 106
Status: offline
Do you guys have any landing pictures, those would be great to see also. I was thinking on the lines of engines that Mike chose for his Hercules,being OSFS 70s wouldn't them be = to OS50 2 strokes if i'm not mistaking and if this is the case then why is there a need for 90 2 stoke engines on these models, wouldn't that be too much power for these models specially if one of them out boards flame out in flight!...
Hide Signatures
(in reply to oltimer)
       Post #: 1256
RE: Palmer 132" C-130 Build - 2/20/2009 3:31 AM
oltimer
Score: 100
Status: offline
My best guess is that no one knew it would fly with 50 size two strokes. If you recall Palmer originally designed this aircraft around 49 MVVS engines of a two stroke nature. Mike is using OSFS 70's and 90 are probably overkill in hind sight! Mike might have some landing pictures he will share.
Frank
Hide Signatures
       Post #: 1257
RE: Palmer 132" C-130 Build - 2/20/2009 7:22 AM
Dad_Roman
Score: 100
Last Login: 5/23/2013
Status: offline
Ok, if I might have a little input here (very little)
IIRC in the last 50 pages, the 90's being spoken of are 4 strokes, not 2 strokes. And they are the "geared" 90 version at that, which basically means a VERY large, slow turning prop, to achieve some scale proportion.
On whether "these" engines would be overkill or not......the C130 is capable of an unlimited verticle climb once a decent airspeed is achieved on takeoff (quoted from an original "test pilot" I used to race with) SO it stands to reason that if your 50 2 strokes will send her straight up, then that would be a scale platform
Seems to me (just guessing here) that this will be close to being achieved with geared 90's spinning huge props.
Mike...Beautiful plane and a beautiful maiden...Kudos my friend!
Frank...Thanks for the pics dude! (and thanks for tryin to get vid)
< Message edited by Dad_Roman -- 2/20/2009 7:25 AM >
AMA# 134406
Hide Signatures
       Post #: 1258
RE: Palmer 132" C-130 Build - 2/21/2009 2:34 AM
mironpopescu1
Score: 100
Status: offline
Thanks Dad and Props4ever. I screwed up a folder containing more picture in which I had a landind picture. I will be flying next Tuesday ( I hope, winds are 15-20 everyday ) and get a bunch of landings Be back Mike
Hide Signatures
(in reply to Dad_Roman)
       Post #: 1259
RE: Palmer 132" C-130 Build - 2/21/2009 4:04 AM
oltimer
Score: 100
Status: offline
Good luck Mike! Maybe the wind gods will grant you gentle winds staight down the runway.
Frank
Hide Signatures
       Post #: 1260
RE: Palmer 132" C-130 Build - 2/21/2009 5:28 AM
UkerDuker
Score: 100
Status: offline
quote:
ORIGINAL: mironpopescu1
Don't be afraid to use those flaps. From the initial reports, it sound like your Herc is a great flier. Roll out the flaps and throttle up, I think you will be surprised how docile the landings become.
I would love to see a flight video soon.
Hide Signatures
       Post #: 1261
RE: Palmer 132" C-130 Build - 2/24/2009 1:34 AM
Props4ever
Score: 106
Status: offline
Check this link out, great close up walk around C-130 pictures...
http://www.midwaysailor.com/photos/hercules.html
Hide Signatures
       Post #: 1262
RE: Palmer 132" C-130 Build - 2/24/2009 2:00 AM
oltimer
Score: 100
Status: offline
Great find!
Thanks, Frank
Hide Signatures
       Post #: 1263
RE: Palmer 132" C-130 Build - 2/24/2009 6:04 PM
Props4ever
Score: 106
Status: offline
No Problem, glad to help fellow C-130 modelers...
Sam
Hide Signatures
       Post #: 1264
RE: Palmer 132" C-130 Build - 2/27/2009 3:12 AM
mironpopescu1
Score: 100
Status: offline
Got a flight yesteray Feb 25. Winds die down later on the day at measured 8-10 and gusts to 12. Major problem was the rotating direction of the wind so that I can lock on the correct landing vector. Fligth was flawles and lasted until my transmitter bell hit the 8 min flight time. Here is attached the Herk picture coming in with 20 plus deg flaps and a much more acceptable decent path and speed. It is indeed worth all the work, money and perspiration. As it is in life, nothing comes free. Tommorow I will have my 7 th in 6 years bladder cancer surgery. I can close my eyes anytime now and imagine this beautifull Herk flying across the blue skies. Finish yours, you will be very happy My best to all Mike
Click for fullsize
Hide Signatures
       Post #: 1265
RE: Palmer 132" C-130 Build - 2/27/2009 3:23 PM
rcmiket
Score: 116
Status: offline
I'll keep you in my thoughts and prayers. Mike
Hide Signatures
       Post #: 1266
RE: Palmer 132" C-130 Build - 2/27/2009 5:58 PM
Props4ever
Score: 106
Status: offline
Best of luck Mike, we are waiting for you to come back soon to our Hercules mania on here, i'll pray for ya fast recovery back.
Hide Signatures
       Post #: 1267
RE: Palmer 132" C-130 Build - 3/18/2009 3:23 AM
schwatd
Score: 105
Last Login: 3/27/2013
Status: offline
Does anyone know how Mike is?
Calm Winds & Smooth Landings
__________________________________________
Hide Signatures
       Post #: 1268
RE: Palmer 132" C-130 Build - 3/18/2009 4:00 AM
oltimer
Score: 100
Status: offline
Props4ever;
I'm in the dark regarding Mike U.'s health. Can you comment?
Frank
Hide Signatures
       Post #: 1269
RE: Palmer 132" C-130 Build - 3/18/2009 4:03 AM
schwatd
Score: 105
Status: offline
Hi Frank,
Actually I hoping you knew since you"re down in his neck of the woods. If you hear something PM us if Mike doesn't care, I don't think open on the formum is to great though unless Mike does it himself. Thanks!
Hide Signatures
       Post #: 1270
RE: Palmer 132" C-130 Build - 3/18/2009 5:40 AM
oltimer
Score: 100
Status: offline
Hi schwatd;
Your absolutely right! Cranial rectitus is prevalent at my age!
Frank
Hide Signatures
(in reply to schwatd)
       Post #: 1271
RE: Palmer 132" C-130 Build - 3/18/2009 6:06 AM
mironpopescu1
Score: 100
Status: offline
Sorry, sorry and sorry again. Four postings finally got my attention and strenght to answer. I am no better than 3 weeks ago, not because of B C but because of post surgery infections. Yes with S at the end because I run into a chain of bacterias, one more stronger than the other. Sitting at the computer its a job by itself. This is all I am going to say. But I am convinced that I can.......are you ready ? ....... my second C 130 and finish it the gunship model with all the guns and their glories. How beautifull will that be to make a low pass and seeing them hanging over their windows. But as a service to you, you may take the following suggestions as you work on your plane.
1The elevator 2 deg negative is wrong. It should be zero. My plane needed 3/8 down elevator to fly leveled and then will land steep when power / speed / lift was reduced. I had to mix throtle with elevator so that at max T I would have the 3/8 down and at idle I was back in neutral. My 106 in Check molded C 130 has also a zero elevator. If you move your elevator to 3/8 down and unite the LE with TE you have the zero. This is the where Mister Herk is comfortable. That is a big mistake in the design.
Well I am sorry again my friends and thanks for putting up with me My best Mike
Hide Signatures
       Post #: 1272
RE: Palmer 132" C-130 Build - 3/18/2009 9:18 PM
schwatd
Score: 105
Status: offline
Fla Mike,
Nice to hear from you!!!! A positive attitude is the BEST medicine!! Once I finish one herk I would like to have a second herk of the Fat Albert variety. I think that is the derangement for even thinking about four engine RC's !!! lol!!!
We've started cleaning the garage out and getting the new shop in order. I hope to get back to building sometime this spring. With everyones posts and help I'm going to try and make some big ground gainers on all of you and get this bird together. Till next time laddies!!
Troy
Hide Signatures
       Post #: 1273
RE: Palmer 132" C-130 Build - 3/21/2009 4:29 AM
Props4ever
Score: 106
Status: offline
Hey Mike ,
Great to hear back from you, honestly i had been thinking about you lately and i was going to send ya a PM to see how you were doing. I haven't been following on here much lately as i have been dealing with my father's medical issues also and whatever time i get during a day i hang out in Jets section with regards to my Avro Arrow restoration. Hey i'll second that positive attitude is the key of goodness, you will come through the difficulties if you looked up and kept thinking positively my friend. There is so much pain he can give us, as he knows how much we can tolerate....
Now i know once i get my C 130 i have major surgery to do if it's stab is mounted on negative incidence as on plans, , ,well great to hear from ya and hope to see you flying your Herky bird real soon...
Cheers,
Sam
Hide Signatures
       Post #: 1274
RE: Palmer 132" C-130 Build - 4/22/2009 10:43 PM
rogerswin
Score: 100
Last Login: 5/22/2011
Status: offline
I want to thank UkerDuker for starting this thread, and all the others who contributed their info and pictures for building this Palmer 132" C-130. I started building mine about four weeks ago and have read every post here, plus downloading most of the construction pictures. So far I have not run into any major problems because you guys informed me about them before they came about. My version is the LC-130 with skis and wheels, along with the Arctic paint scheme.
It wouldn't make much sense for me to start posting pictures at this time (many good pictures of the construction are already here). I'll post some pictures when it nears completion.
The only modification I made so far was that I built the windshield mullions out of plastic 3/32" angles instead of balsa wood as called for on the plans. The skis are made out of solid basa blocks. Also, I will be powering it with four AXI 5330/18 electric motors and 13" four bladed props.
Roger
Roger Kurtz
WA6MZX
Hide Signatures
       Post #: 1275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.875RCU1
