Mike James
AK, USA Status: offline
Thanks, smchale. Yep... Put a big "bat fin" on the back, and let 'er rip. Bob, In this case, I used fiberglass cloth strips ( "tape" ) around the rear of the fuselage, approximately from the leading edge of the wings to the tail. It really wouldn't have been necessary except that without formers installed, it was a little fragile. With formers installed, whatever you do on the seam is strictly cosmetic, as the internal structure takes the loads. If we were making Pattern-type airplanes, using left/right molds, I'd use tape to join the pieces, because the skin itself takes more load. On this airplane, the seam is hidden at the bottom part of the fuselage's curves, where the bottom of the tailerons, wing, and the nose's chine go. I vacuum bagged one wing (2 halves) last night, and will be doing the other one today, along with some tail parts. In the next few days, you'll see the engine, retracts, etc., installed, and it will look like a plane. I'm excited.
_____________________________
Mike James RC Design and Building - www.nextcraft.com
