RE: Falcon 40 (Exceed heli) Forum    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Falcon 40 (Exceed heli) Forum
Page: <<   < prev  375 376 [377] 378 379 380 381 382 383 384   next >   >>
Login
RE: Falcon 40 (Exceed heli) Forum - 11/12/2010 6:07 AM
maxmax77
Score: 105
Last Login: 9/18/2012
Status: offline
mack; no prob! I found they were much more durable.
Jim, sweet man! I love it, can't wait to see the whole thing! I'm in the process of painting my art-tech Corsair, see my post on the struggling with single rotor basics v2 thread, page 215
_____________________________
Never stand in a shadow that''''s getting bigger.
Hide Signatures
(in reply to mack53)
       Post #: 9401
RE: Falcon 40 (Exceed heli) Forum - 11/13/2010 12:44 AM
mack53
Score: 100
Last Login: 2/16/2011
Status: offline
Okay I got the new rotor head (V2) that has the pin that goes thru it and the shaft. Is there a easy way to push it thru? The metal pin is a soft metal and likes to bend if you use to much pressure. I lined up the holes with a straight pin and have gotten it to go thru to where it barely starts coming out the other side but like I said its a very soft metal and it loves to bend. Any advice???????????????
mack53
Hide Signatures
       Post #: 9402
RE: Falcon 40 (Exceed heli) Forum - 11/13/2010 1:11 AM
Disney1
Score: 100
Last Login: 5/28/2012
Status: offline
I use a sewing machine needle, it self aligns. Just cut off teh two ends that are left sticking out.
I get them at Wal-Mart, can also be gotten at most anyplace.
Ron Sr
EDIT
The size I use is #80
The only stupid question is the one you forgot to ask.
If it''''s not broke don''''t fix it!
Hide Signatures
       Post #: 9403
RE: Falcon 40 (Exceed heli) Forum - 11/13/2010 3:56 AM
o6298
Score: 105
Last Login: 1/2/2013
Status: offline
I just twist the pin in with small pliers starting as close to the rotor head and keep working it in that way.
The needle idea is excellent. I'll have to give that a go.
quote:
ORIGINAL: Disney1
Ron Sr
EDIT
-Chris
"If birds can glide for long periods of time, then… why can’t I." Orville Wright
Hide Signatures
(in reply to Disney1)
       Post #: 9404
RE: Falcon 40 (Exceed heli) Forum - 11/13/2010 5:20 AM
Disney1
Score: 100
Status: offline
The best part is that being a Machine needle you have teh square shank to better grip with the pliers., and you can buy replacements.
Hide Signatures
(in reply to o6298)
       Post #: 9405
RE: Falcon 40 (Exceed heli) Forum - 11/13/2010 3:12 PM
maxmax77
Score: 105
Status: offline
+1 on what Disney said, I too use needles for it
Hide Signatures
       Post #: 9406
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 4:37 AM
imacamper
Score: 100
Last Login: 11/16/2011
Status: offline
quote:
ORIGINAL: mack53
Also thanks for the advice about the main blades. The HoneyBee ones work great, in fact they are tougher the stock Falcon ones and seems to have more lift in them...
I have the v2 with the smaller holes for mounting the blades.  Do these HoneyBee blades have the smaller holes?  I have successfully used v1 blades along with the inserts that come with the v2 blades but I'm sure the day will come where either I lose an insert or it will get damaged.
But for what it's worth, the v1 blades do not seem to split as easily as the v2 blades.
Also, came across these today:
http://www.helipal.com/airy-harden-blade-ii-ax-09.html
Any thoughts?
Cheers,
Drew
< Message edited by imacamper -- 11/17/2010 3:49 AM >
Hide Signatures
       Post #: 9407
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 4:54 AM
imacamper
Score: 100
Status: offline
I'm new to the hobby.  After doing my reading, I settled on the Exceed Falcon 40 v2 for a trainer. It may not have been the best choice but between Radd's Flight School, HeliSimRC, and flying my own bird, I'm starting to have some limited success and haven't broken too many things.   But I still find my bird fairly unstable.  If it was as stable as the one in HeliSim, I'd be flying pretty well by now.
I've balanced the main rotor blades.  I don't seem to have any serious vibration.  I've played with linkage lengths the ensure a level swashplate (as viewed by my eye). I set the flybar paddles level with the rotor head ring (again, by eye).  It's level when holding by the flybar perpendicular to the body.  I"ve even increased the sensitivity of the gyro to full (and there's no tail wag heh, it takes 70% right trim to keep the tail from constantly swinging to the left)  So I think I've done everything there is as far as set up goes.
So, is it just me?  Are these things just that unstable? Or are there some upgrades I can do to get a bit more stability?  In other words, not change movements so much when I'm not giving any stick input.  For example, I saw a YouTube video where a guy was touting the benefits of EZ SuperBlades and how his copter was hovering in place with no stick movement.  I've also read about direct drive tail rotor mods and that they give better tail control.  Is any of this applicable to or available for the Exceed Falcon 40 v2?  I'm somewhat OK with modifying parts to make things work if given the proper instruction.
Are there other things I might do for more stability?  Better servos, links, swashplates, etc.?
Nudges to more reading material are welcome.
Thanks for your help and advice,
Drew
Hide Signatures
(in reply to maxmax77)
       Post #: 9408
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 5:24 AM
maxmax77
Score: 105
Status: offline
hey imacamper; to answer your Qs, first off the honey bee fp blades are exactly the same as the v1 blades just more durable and better quality, so if you need spacers ofr the v1 blades you'll need them for the honey bee blades.
it's pretty expected that the heli will wobble around with it stock like yours. I had SuperBlades EZ and they worked great! Made the heli like almost like a coaxial in flight. You can get a Direct Drive tail motor, I did but overall the stock tail works fine IMO. If you want crisper response once you're getting into forwards fight you should consider switching, stick with the orig for now though unless it's really bugging you!
if I missed a Q point it out
-Max
Hide Signatures
(in reply to imacamper)
       Post #: 9409
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 5:37 AM
imacamper
Score: 100
Status: offline
Hi maxmax,
Thanks for your reply.  OK, I'll just order v2 blades when I need more spacers.  I have 4 sets of v1 blades now.  Once I wreck all those, I'll try the HoneyBee.
I'm actually trying to hover and control it a hit higher than I have been.  However it got away from me yesterday and my flight ended with a fairly spectacular crash against the rain gutter of the house.   Although I have training gear, one of the landing skids hit the corner of the gutter.  It bent in the middle and broke the front plastic leg.
I've heard so much about SuperSkids.  Are they worth the money and will they fit on the v2?
Drew
Hide Signatures
       Post #: 9410
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 5:41 AM
imacamper
Score: 100
Status: offline
Tail rotor blades for $1.50 and free shipping:
http://www.dealextreme.com/details.dx/sku.12827
Cheers,
Drew
Hide Signatures
       Post #: 9411
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 11:45 PM
maxmax77
Score: 105
Status: offline
hey imacamper, s imply put, yes superskids are definitely worth the money!
Hide Signatures
       Post #: 9412
RE: Falcon 40 (Exceed heli) Forum - 11/15/2010 11:57 PM
imacamper
Score: 100
Status: offline
quote:
ORIGINAL: maxmax77
hey imacamper, simply put, yes superskids are definitely worth the money!
OK, I think the SuperSkids 200 are what would fit the v2. Is that correct?  And do I need some adapter plate or not?  I'm confused.
Drew
Hide Signatures
       Post #: 9413
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 12:09 AM
Disney1
Score: 100
Status: offline
You do not need an adaptor to use teh SuperSkids on the V-2 they will fit the frame after you remove the adaptor that comes on the V2 frame.
Ron Sr
Hide Signatures
       Post #: 9414
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 3:45 AM
nascarfaad
Score: 100
Last Login: 11/4/2012
Status: offline
You'll want to get the 300's. I use them on my V1 and love them.
T-Rex 450 Sport, T-28D Trojan BNF, Ultra Micro T-28 Trojan BNF, Falcon 40, Blade mSR BNF, Hobbyzone Champ, DX7
Hide Signatures
       Post #: 9415
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 5:42 PM
o6298
Score: 105
Status: offline
Imacamper,
A picture is worth 1000 words. So I hope these help answer your question how the superskids attach to the falcon frame.
quote:
ORIGINAL: imacamper
quote:
ORIGINAL: maxmax77
Drew
Click to see the file in new window.Attachment.pdf Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by o6298 -- 11/16/2010 6:08 PM >
-Chris
Hide Signatures
       Post #: 9416
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 5:58 PM
imacamper
Score: 100
Status: offline
quote:
ORIGINAL: o6298
Imacamper,
Thank you so much!  I'm sure that will be very helpful when I get my SuperSkids.  To fly in the meantime, I was able to straighten the actual skid (pretty darn well, I might add I was afraid I'd actually break it while trying to bend it back.).  I then glued the plastic leg back together.  Since all my skids do now is hold my training gear, I'm hoping I'll get a way with this for a while.
Cheers,
Drew
Hide Signatures
(in reply to o6298)
       Post #: 9417
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 6:13 PM
o6298
Score: 105
Status: offline
When the stock skids broke I'd fix them with sewing thread and crasy glue. That made them MUCH stronger. Just a thought.
quote:
ORIGINAL: imacamper
quote:
ORIGINAL: o6298
Imacamper,
Cheers,
Drew
-Chris
Hide Signatures
       Post #: 9418
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 7:09 PM
Disney1
Score: 100
Status: offline
By teh way the only differance in the V1 and V2 frame is the adaptors.
So if you break a frame you can order the V1 frame .
US Hobby Supply has frames on sale Buy One Get One
https://www.ushobbysupply.com/product_info.php?products_id=54
For the V2 fliers most V1 parts will work on the V2.
Ron Sr
Hide Signatures
(in reply to o6298)
       Post #: 9419
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 7:10 PM
Disney1
Score: 100
Status: offline
o6298:
Great pics. You are correct a picture is better.
Hide Signatures
       Post #: 9420
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 7:42 PM
imacamper
Score: 100
Status: offline
quote:
ORIGINAL: Disney1
I know the rotor head and electronics are different.  And apparently the frames are a bit different, I assume because of the landing skids? Other than that, is everything else interchangeable?
Drew
P.S.  I didn't take any pics before my repair but here are some after.  That metal skid had about a 20 -30 degree bend in it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9421
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 7:49 PM
Disney1
Score: 100
Status: offline
You are correct. The head and electrics are different and as the pictures supplied the only difference in the frame is teh screw on adaptor.
That makes it easier to get parts, also the Walkera #4 and 4#1 are the same as the falcon 40v1 These are the older ones not the new style 4 with 2.4G electrics
Ron Sr
Hide Signatures
       Post #: 9422
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 7:57 PM
imacamper
Score: 100
Status: offline
quote:
ORIGINAL: Disney1
Thanks for your reply.  If/when I break my rotor head, can I replace it with a v1 style?  And if I can, what would be the cons of doing so?  The pro I see is the availability of many after market rotor blades for the v1.
Drew
Hide Signatures
       Post #: 9423
RE: Falcon 40 (Exceed heli) Forum - 11/16/2010 8:06 PM
Disney1
Score: 100
Status: offline
Drew replacing teh V2 head with a V1 head is not a bad idea, Newer is not always better. I cannot see a down side. As long as the main rotor shafts are the same diameters it should work fine.
Here we go again back to US Hobby Supply. He has a custom CNC aluminimum rotor core.
Works great. but he only has a couple of them left.
https://www.ushobbysupply.com/product_info.php?products_id=832
If you havent figured it out I get most all of my parts from him.
Excellent customer service and very fast to ship to you.
Ron Sr
Hide Signatures
       Post #: 9424
RE: Falcon 40 (Exceed heli) Forum - 11/17/2010 3:26 AM
maxmax77
Score: 105
Status: offline
+1 on everything disney said, USHobbySupply is excellent!
Hide Signatures
       Post #: 9425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
