stalledout
Hello, I have been flying a Falcon 40 for a few months and I think the main motor is about to gone bad. Last night, on a newly charged battery pack, the main rotor would only turn a a low rpm while the tail rotor would spin the heli all the way around while it was sitting on the carpet. As I said, I have been flying/crashing for about two month and these are the original motors. The original/stock battery pack read 9.3v on a digital multimeter. Also, fow a while now, often on the first flight of the day, at first the heli would not even get off the ground, but then after things 'warmed up', it would have enough power to lift off. Is this a sympton of a bad motor or battery pack? Anyway, my real question is: When buying a new main motor, what pinion do I need? I think a 10t, but want to make sure. Also, I know about the Mabuchi motor from Tower Hobies, but they are out of stock right now. Does someplace else sell them? I would get both a main and tail motor. If not, my LHS sells two different motors that I think will work, one is an E-Flite, are then any good? I am running a totally stock heli (except for servos (HS-55's)) with the 7 cell nimh pack. I may look into doing the GWS tail rotor mod though. I think the Faclcon 40 is great for the price and Michael at USHobbySupply has great service, he just does not have a motor upgrade that I can tell. Stalledout
