broggyr
CT, USA Status: offline
quote:
ORIGINAL: gilros82 just a quick question , if i take off the main blades and spin it up to full rpm and it doesn't vibrate does that mean that i have a dodgy set of blades You may just need to balance them. The easiest way (for me at least) is to take the blade/rotor head assembly and balance it between 2 beer cans (rest the ball links on the lips of the cans) and you might see one blade dip lower than the other. If so, take a small piece of pinstripe tape (the amount will vary depending on how much the blades are out of balance) and apply it to the end of the rotor, about 0.5 to 1" from the tip. Check the balance again. Keep varying the amount of tape or where it is applied to get the blades so they will balance level. Reinstall them and try a flight. There are a few more in-detail methods of blade balancing discussed earlier I believe Also, be sure the amount of pitch (angle) is the same for both blades.
_____________________________
irony [ay-ruh-nee, ay-er-nee] adj.: Like goldy or bronzy, except made of iron
