RE: Falcon 40 (Exceed heli) Forum
Tower Hobbies
Logged in as Guest
Users viewing this topic: auctioneeral
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Falcon 40 (Exceed heli) Forum
Page: <<   < prev  229 230 [231] 232 233 234 235 236 237 238   next >   >>
Login
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 7:21:11 PM
Great_life
Status: offline
HeloJerry, it's not too late. You can buy another Falcon that way you have 2 to fly and 1/2 for spare. If something goes wrong you can swap the component and fix it instantly without buying wrong parts. Also you have 2 for comparison during fine tunnings, adjustments. Finally with 2, you will never have to wait for parts. When I buy a model, my rule is to have a minimum of 2 otherwise I just wait until I have enough money or buy something cheaper. I am not electronically inclined but over the years having at least 2 of everything really helped me learned a lot. My 2 cent rule, 2 kids, 2 brothers, 2 jobs, 2 of each heli (I am not kidding), 2 wives (am I kidding?), cost me 2 times more, should you 2? Hehe.
< Message edited by Great_life -- 5/9/2008 7:28:02 PM >
(in reply to helojerry)
       Post #: 5751
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 9:12:56 PM
Short Flight
Status: offline
quote:
ORIGINAL: The_Seeker
[A few that others have had success with
TOWER PRO SG-90 Micro Servo
Hi- Tech HS 55
Futaba S3114
I'm using the Tower Pro's which are almost a direct replacement. You'll still need to trim back the little tab on the top of the frame to accomodate where the wires come out, and you'll have to shave 1/16" off of the mounting flange of the servo. Then they will snap right in. At only $7.00 each these are a great deal.
I like the HS-55's too, but these will have to be taped or strapped in with a zip tie. Also twice as expensive as the Tower Pros.
Haven't tried the Futaba.
Chris
< Message edited by Short Flight -- 5/9/2008 9:24:31 PM >
(in reply to The_Seeker)
       Post #: 5752
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 9:15:29 PM
Short Flight
Status: offline
Anyone know of a replacement canopy that is just a little wider than the stock one? The electronics for my 3-in-1 set-up run the wires out sideways and are a tight fit. Plus my original canopy is pretty much held together with duct tape, so probably time for a new one.
(in reply to Short Flight)
       Post #: 5753
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 9:46:20 PM
Bones27
Status: offline
Short Flight, Duct Tape!!! Gotta love it, ROFLMAO!!! 1002 uses for Duct tape - Canopy repair. I wonder if Delta has thought of that as a cost saving measure so they can afford more jet fuel?
_____________________________
Don''''t let schooling interfere with your education.
Mark Twain
       Post #: 5754
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 10:42:08 PM
Bones27
Status: offline
Broggyr, don't know if you have seen this: http://www.helihobby.com/html/separate_electronics.html . I haven't had a chance to really study it yet, but it talks about initializing the tail motor on a separate component setup. If I understand what the article is saying, this problem can be fixed with revo mix in a programmable radio or by using a mixing board or by using a HH gyro with a non-programmable radio. I might be misunderstanding the article electronics are not my strong suite. Just thought you might be interested.
Mark Twain
(in reply to Bones27)
       Post #: 5755
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 11:01:43 PM
broggyr
Status: offline
Yea, I saw that. That would require me to buy a 'real' heli radio. The one I got was designed for a Walkera CP heli, not sure which one, but the mixes are non-programmable...
irony [ay-ruh-nee, ay-er-nee] adj.:
Like goldy or bronzy, except made of iron
       Post #: 5756
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 11:11:50 PM
Bones27
Status: offline
Broggyr, what about using the mixing board or using a HH gyro with a non-programmable radio? The reason I ask is because I am going to be in the same boat with a non-programmable radio (6 ch E-Sky) when I do my conversion.
< Message edited by Bones27 -- 5/9/2008 11:25:33 PM >
Mark Twain
(in reply to broggyr)
       Post #: 5757
RE: Falcon 40 (Exceed heli) Forum - 5/9/2008 11:32:26 PM
broggyr
Status: offline
I'd like to try a HH gyro, but I just don't have the fundage for it.
       Post #: 5758
RE: Falcon 40 (Exceed heli) Forum - 5/10/2008 1:49:35 AM
Short Flight
Status: offline
quote:
ORIGINAL: Bones27
...1002 uses for Duct tape - Canopy repair. I wonder if Delta has thought of that as a cost saving measure so they can afford more jet fuel?
Hadn't thought about it, but half a roll of duct tape probably cuts a few minutes off my flights.... actually just a few strips lining the inside to keep it in one piece. Too many incidents with the wood stove.
How about Billmay with all of those miles of beach and no bird. What kind of vacation is that?
       Post #: 5759
RE: Falcon 40 (Exceed heli) Forum - 5/10/2008 1:54:30 AM
Bones27
Status: offline
I hate it when the wood stove jumps out and hits my heli!!! Bill may not have his heli but I noticed he found a computer somewhere to check up on us.
Mark Twain
       Post #: 5760
RE: Falcon 40 (Exceed heli) Forum - 5/10/2008 3:06:19 AM
UTM
Status: offline
quote:
Need Servo!! Help!!
I need a replacement servo for the Falcon 40. The gears on my roll servo are partially stripped. The Exceed replacements have been out of stock since I bought my model. Does anyone know where I can get a drop in replacement??
Thanks.
Jerry
Jerry I really like the Hi Tech HS-55's As Life posted you will have to use a tie to keep them in the mounts but the flanges are the right width just not thhick enough. i put mine on with 2 side tape and then zip tie them to the fram and rock solid. I have had several really bad crashes (including one today) and they have not yet stripped. Even if they do there is a gear set available so you can fix them. Good little servo. Faster than the stockers too.
So I got a chance today to try out some FFF in a large field with 2-5 mph winds. This was my first attempt at any FFF. I started with some slow back and forth and figure 8's and then just couldn't help myself. I hit the gas and was doing some large sweeping passes with stall turns. Man is this little bird fast! My heart was pumping and my hands sweating and the smile on my face was so big you'd have to chisle it off I even got brave at the end of he first pack and was pulling a piro at the top of my turns before coming back!! Flew through the first pack with only 1 close call. On a nose down pass I got so close to the ground when i pulled up I actually heard the tail rotor clip some grass Let the motors cool down and chucked in another pack. Got even more controlled passes and fast nose down flight. WhooHoo! was it fun. Did I say how fast the Falcon can be? Well got 3/4 through the pack and then disaster struck. I was coming in hot right in front of me with fast nose down flight and a small gust of wind hit sending the heli further nose down. I pulled back full but gravity won out this time. BAM Hit the ground full speed nose first The pull back full actuall saved a much worse crash as I hit probably 15 degrees instead of the 30 it was coming in at. Not a ton of damage but broke 1 blade, canopy, tail boom, and modified SS tail support. i'll post some pictures. The far back pictures show the new and improved curved tail boom. I can arrange to get all of you one if you wanna try em out
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by UTM -- 5/10/2008 3:19:44 AM >
Rules are made for people who aren''''t willing to make up their own....Chuck Yeager
       Post #: 5761
RE: Falcon 40 (Exceed heli) Forum - 5/10/2008 3:27:27 AM
