helojerry
AZ, USA Status: offline
There's no way I could see flying in my living room. There is much to much stuff to hit piano, coffee table. glass bookcase doors, family photos -. Nope! Mine's not nearly 17'x17' either. I could go back to the garage, but I never was able to get a hover until I got it outdoors. Too afraid of hitting those hard walls. Even outside in still air, my Falcon seems to have a mind of its' own sometimes. I can have a very still hover for a bit and then it decides to move all over the yard. I can get it back under control, but it takes alot more space that I have in a garage. Sometimes I think a light puff of wind is to blame, but I can't be sure. It's just like a marble on glass. When it starts moving, it takes a bit to get it stopped. I think the FP plays into it some too because I have to work the throttle all of the time and when throttle changes, that makes the chopper want to move. I broke my 4th center core last night. This time, it snapped off completely right at the top of the steel main shaft. Yep! It hit hard. It may have also made contact with the edge of my patio slab, but I don't know. I lost lateral control completely. Well, I've been flying with a partially stripped roll servo , so no surprise. It was mostly working OK as long as I stayed away from maximum roll stick, but evidently, either I got out of that zone or something else went wrong. I was pretty lucky. Didn't break anything else that I can tell, but did lose one head bearing someplace in the grass. Oh, well. I'm expecting a shipment today with a replacement servo and 4 center cores. I think I'm going to put a steel shaft thru the center of the two top forks which are already drilled thru and then fill the gap with epoxy as some others are doing. I'm thinking this should make it much stronger where it usually breaks. I counted up all the bucks I've put into my Falcon since I bought it 5 weeks ago. Yikes!!! $290!! Of course, I bought 1 1/2 Falcons to start and I I still have a bunch of spare parts. I'm on my last tail motor though, so I gotta do something about that. Also, $70 of that went toward batteries and LIPO charger. $20 of that $70 was for 2 spare NiMH packs that won't lift me off the ground anymore. Motor is too worn I guess. Should have gone to LIPO right off the bat. There has to be some major difference between my setup because I need 11.1 v to fly and others are doing fine on 7.4 to 8.4 v. And I'm not in Ablq like Dave. I'm wondering if my gear mesh is too tight, but I don't think I can make it any looser and still fly. My tail rotor turns really hard by hand, but that all seem to be due to the cogging resistance of back driving the motor. The tail motor gets pretty hot, so I'm going to add a 2nd heat sink. Later, Jerry
