RE: Falcon 40 (Exceed heli) Forum
Tower Hobbies
Logged in as Guest
Users viewing this topic: jeeper1977
  Printable Version
Walkera 53#8!! 5G6-1, 4#3B and Nine Eagles - RTF
Seller:  travis@rchelizone.com
Details:   $180.00   |  9/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Falcon 40 (Exceed heli) Forum
Page: <<   < prev  235 236 [237] 238 239 240 241 242 243 244   next >   >>
Login
RE: Falcon 40 (Exceed heli) Forum - 5/20/2008 11:54:07 PM
dps782
Status: offline
Thank you, this place is goldmine of information.
(in reply to UTM)
       Post #: 5901
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:17:25 AM
Bones27
Status: offline
Dps, I'm assuming you are talking about the $20 dollar sim that comes with a TX. The TX that comes with the Falcon has a serial port cable which comes with the Falcon that you can hook to the computer and download FMS simulator for free which is the exact same thing as the sim you ordered. I'm not telling you this to make you feel bad but you might be able to get a refund on the sim if you don't open it. If you do decide to use the Sim you ordered or go the other way both can be a pain to get working on the computer. You will need to download a program called PPjoy it is also freeware and is what allows the TX to talk with the computer. It can be a pain to get setup but it does work good for learning your tail in, side in and nose in orientations but not much else. If you have trouble with the settings just let me know as I have them written down. If your running Vista I have heard of people not being able to get it to work, I can't help with Vista as I am still running XP.
_____________________________
Don''''t let schooling interfere with your education.
Mark Twain
(in reply to dps782)
       Post #: 5902
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:29:07 AM
dps782
Status: offline
snooptalian, thank you for the RaidenTech shipping tips and codes. I used the "free shipping" code while ordering yesterday (19th) and have recieved a tracking number in an email that my Falcon 40 is scheduled for delivery tomorrow (22th),, Not bad!!
(in reply to snooptalian)
       Post #: 5903
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:37:06 AM
dps782
Status: offline
Bones do you think I will be able to learn without a sim? I really wasn't going to get it but did at the last minute when ordering.
(in reply to Bones27)
       Post #: 5904
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:42:18 AM
dknovick
Status: offline
quote:
ORIGINAL: Bones27
Pinions are a piece of cake to change if you have the correct tool. I change mine back and forth between 9t, 10t and 11t all the time. I do this in an attempt to make the brushed motor I am using at the time as efficient as possible.
Is this with the STOCK motor? It looks like a press/interference fit between the pinion and the motor shaft. 'Cause if I can, I'll change it to play with more parameters.
What goes up, most come down. How hard depends on you!
       Post #: 5905
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:44:22 AM
dknovick
Status: offline
quote:
ORIGINAL: dps782
Yep. I haven't used a sim yet, and am able to tail-in, side-in, and almost nose-in hover.
       Post #: 5906
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:44:59 AM
Bones27
Status: offline
Dps, sure you can learn without a sim people do it all the time. The good thing about the sim is when you crash the heli and you will you just hit reset button and start over, no digging into the wallet for parts, waiting for parts and down time which sucks.
Mark Twain
       Post #: 5907
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 12:52:03 AM
Bones27
Status: offline
Dk, yes the puller works with any motor with a press fit pinion shaft. It even accomodates different size shafts and pinions so it is a tool that can be used in other places than just the Falcon. USHobbySupply sells it for $12.99 which is where I got mine and it is a quality tool that will last a long time. I highly recommend it. The tool will pull the pinion, to press the pinion back on I just open up my vise and place the pinion and motor in the jaws and slowly tighten the vice. It presses the pinion on very nicely.
Mark Twain
       Post #: 5908
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 1:22:19 AM
UTM
Status: online
DPS - You can absolutly learn without the sim. I have never had one and only ever use them when I happen to be in my LHS where they have G4 and realflight set up. I am about the same level as Dave in that I can tail-in and both side in. Haven't got to nose in yet but am working that way. I have also started taking it outside for some forward flight. the falcon will break but it is extreamly durable little heli. In minor crashes you can mostly straighten the blades and go again.
Dave a pinion puller is great. I picked up one at my LHS. It's GWS brand. Its very compact, a sinch to set up, has 3 different size shafts for diffferent dia motors and pulls pinions like a dream. It was also 12.99. I press new pinions with my bench vice just like bones. I have a 9, 10 and 11t to experiment with. Pick one up you won't be sorry
Rules are made for people who aren''''t willing to make up their own....Chuck Yeager
       Post #: 5909
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 3:59:31 AM
dknovick
Status: offline
quote:
ORIGINAL: helojerry
Oh, cool! I love datasheets
Let's see:
Motor diode: 1N5819
8 bit microcontroller: EM78P458 (OTP so you can't read it)
original MOSFET: FDS4410 N-channel
my replacement MOSFET: FDS8812NZ N-channel
5V regulator: LD1117&xx LDO
Op amp: LM324
PM me your email if you'd like me to send you the datasheets.
Output to the motors is a 2.05kHz (488us) PWM signal (kinda high!), varies from 0-100% duty cycle
The piezo gyro outputs a deltaV based on the rate of rotation. The op-amp brings the signal up to 1.6V steady state, twisting the board causes the voltage to either rise above or fall below the 1.6V mark.
Initial take on, "What does this pot do?" Not much! Setting the throttle to 1/2, and setting the pot to 0.5V, I got a 174us pulse (~35.6% duty cycle). Keeping the throttle at the same place, and setting the pot to 3.3V, I got a pulse of 182us (~37.3% duty cycle). So it doesn't change things by much, and it seems to increase the duty cycle as you lower the voltage from the pot.
And one more thing, here a postmortem picture of my tail motor, you can see the missing five fingers (well, actually you can't!) and how, on the other arm, the fingers are almost warn off.
-Dave
Click to see fullsize image.
Click for fullsize
< Message edited by dknovick -- 5/22/2008 6:10:11 PM >
(in reply to helojerry)
       Post #: 5910
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 4:02:50 AM
