RE: Falcon 40 (Exceed heli) Forum
Tower Hobbies
Logged in as Guest
Users viewing this topic: Navy_1, USHobbySupply, karlik
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Falcon 40 (Exceed heli) Forum
Page: <<   < prev  236 237 [238] 239 240 241 242 243 244 245   next >   >>
Login
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 9:49:13 PM
Bones27
Status: offline
Broggyr, I got my 6ch E Sky TX/RX and Telebee HH gyro today, should get my Dean's connectors on Firday and then I will have all the bits and peices to start my separate components conversion on the Falcon this weekend. I'll keep you posted.
< Message edited by Bones27 -- 5/21/2008 10:01:40 PM >
_____________________________
Don''''t let schooling interfere with your education.
Mark Twain
(in reply to UTM)
       Post #: 5926
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 10:02:13 PM
UTM
Status: offline
quote:
disagree. For me, being a brand new heli pilot, following Radd's gave me the confidence in myself and my bird so that I knew what it was going to do when I finally did break the bonds of gravity. It was second nature for me to correct the nose when I was hovering tail-in.
Radd's helps you build up your finger to stick memory. Hovering a heli requires control of all four stick directions (holding the tail, holding the height, holding the position). Getting familiar with each stick input at a time was a great thing for me (especially on the ground!)
And besides, it's only 10 batteries. I think 100-150 minutes of ground time is well worth it! But, as always, YMMV
I'm with Dave on this one. IMHO Radds helped me out immensly. I am sure I would have had many more crashes in the begining without it. I have to admit not following it to the tee and jumped the gun on getting it airborn but I did work up through pack 7 before that. Helped me to get a feel for what the inputs would do before I was up. It's a really nice teaching tool for the heli rookie. I would highly reccomend at least following some of it to begin with. To each his own however.
Rules are made for people who aren''''t willing to make up their own....Chuck Yeager
(in reply to Bones27)
       Post #: 5927
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 10:06:49 PM
UTM
Status: offline
quote:
ORIGINAL: Bones27
Sounds like fun. Let us know how it goes. Good luck!
I changed out the pinion on the HBK2 motor last night back to the stock 9t and it's a much better fit for my heli at least. If you haven't changed to the 10t I would reccomend staying with the 9t. The HS just comes up so early it's really tough to get the tail to keep up. The motor definately has enough torque to handle a 10t the tail is the problem. I think that a high authroity tail motor such as DD or maybe your century can keep up. The CPP tail motor I use just dosen't have enough a@@.
Have a fine evening all!
       Post #: 5928
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 10:54:30 PM
broggyr
Status: offline
quote:
ORIGINAL: Bones27
I can't wait to see how it turns out. I am waiting for the obligatory photos If I can answer any questions for you on this, I'll do my best
I am really anxious to hear how the HH gyro works, as my gyro is a rate gyro...
< Message edited by broggyr -- 5/21/2008 10:55:12 PM >
irony [ay-ruh-nee, ay-er-nee] adj.:
Like goldy or bronzy, except made of iron
       Post #: 5929
RE: Falcon 40 (Exceed heli) Forum - 5/21/2008 11:24:23 PM
helojerry
Status: online
quote:
ORIGINAL: dknovick
PM me your email if you'd like me to send you the datasheets.
Thanks for the offer, but I was able to find them on the web.
quote:
Output to the motors is a 2.05kHz (488us) PWM signal (kinda high!), varies from 0-100% duty cycle
The piezo gyro outputs a deltaV based on the rate of rotation. The op-amp brings the signal up to 1.6V steady state, twisting the board causes the voltage to either rise above or fall below the 1.6V mark.
This is the proportional control law that you predicted.
quote:
Initial take on, "What does this pot do?" Not much! Setting the throttle to 1/2, and setting the pot to 0.5V, I got a 174us pulse (~35.6% duty cycle). Keeping the throttle at the same place, and setting the pot to 3.3V, I got a pulse of 182us (~37.3% duty cycle). So it doesn't change things by much, and it seems to increase the duty cycle as you lower the voltage from the pot.
-Dave
This again seems consistent with the proportional control law. I would expect the pot to adjust the feedback gain of the rate gyro, not the steadystate operating speed of the tail motor. That is controlled by the trim tab. We should expect to see a larger or smaller change in tail speed for a given rotational rate as the pot is adjusted. Right?
Jerry
(in reply to dknovick)
       Post #: 5930
RE: Falcon 40 (Exceed heli) Forum - 5/22/2008 12:41:36 AM
dknovick
Status: offline
quote:
ORIGINAL: helojerry
figured you would, but just in case..
I was surprised by the 2k Hz frequency, a DC motor (with it's inertia) can't respond to those kind of changes!
The HoneyBee FP has two pots. One to adjust the steady state and one to adjust the gain in the rate gyro. Ours (on the F40) just seems to adjust the stead state. So for my case I can adjust the pot, and move the trim lever back closer to center (currently, almost to the far right). The equivalent of adjusting the length of the ball links for the swash plate, so you can recenter the trims.
I did also check to rate gyro gain, and I couldn't see a difference when I was shaking the board (but it was hard to see). One easy way to see is to adjust the pot to it's extremes. If you need to adjust the trim tab to hold a heading, then the pot is adjusting the steady state. If the tail wags (or is slow to respond), then the pot is adjusting the rate gyro gain.
What goes up, most come down. How hard depends on you!
(in reply to helojerry)
       Post #: 5931
RE: Falcon 40 (Exceed heli) Forum - 5/22/2008 1:41:03 AM
helojerry
Status: online
quote:
ORIGINAL: dknovick
Evidently, it does respond! to the average!! It is still low enough freq that I hear a squeal as I apply the throttle from zero. On model trains, that sound is objectionable so I think they use even higher frequencies.
This is inconsistent with your measurements, but consistent with the way the system seems to respond. I don't know how to reconcile that. From the scope measurement, the duty cycle barely changed with a full turn of the pot. This would indicate that it affects rate gain, not trim.
Agreed. The F40 manual I have says nothing about this.
A straight proportional gain on the rate feedback is only going respond to a yaw rate. When the yaw rate goes to zero, then you have no contribution from the gyro. It will not take out a DC error. The gyro may be fighting the yaw rate, but the gain is too low to stop it. If the gain is too high, then you get the tail wag. So it is going to be a compromise between having oscillations or having a steady state yaw rate. At a particular head speed, you should be able to adjust the trim tab to stop the motion, but if you change the throttle, then that requires a new trim setting. Now if it is really smart, then the controller could add in some yaw thrust for an increase in main throttle, but I'm kind of doubting that from what I'm reading. Also, we have different battery voltages, different motors, different pinions, even different tail boom lengths!! Lots of variables there!! If the controller was going to try to compensate for main throttle, it would have to work off commanded throttle position. It doesn't know you are using an 11.1 v battery!!(BTW, I assume that the MOSFET drives full battery voltage to the motor, not a regulated voltage.)
One other factor to consider is that the controller could read the pot setting one time during power up. But I think that is inconsistent with one of your early posts that says the tail motor speed changes in real time as you vary the pot setting. Again, this seems to contradict the Oscope data.
I seem to be getting just a bit of tail wag during hover with throttle steady. I have not adjusted the pot yet. I'm still working on more basic stuff like motors and batteries!
Later,
Jerry
       Post #: 5932
RE: Falcon 40 (Exceed heli) Forum - 5/22/2008 1:49:04 AM
Navy_1
Status: online
quote:
ORIGINAL: broggyr
Yay Ron Jr! There is no going back now...
I have broken every thing els i just happy it was blades. at it to my list lets see
A 4 in 1, rotor head, rotoe core, main blades, lost the thing off the tail, whats next its like playing the lottery but you nevery win, just like the real lottery you never wim lol off to break more parts
< Message edited by Navy_1 -- 5/22/2008 1:50:12 AM >
(in reply to broggyr)
       Post #: 5933
RE: Falcon 40 (Exceed heli) Forum - 5/22/2008 1:54:18 AM
govols1794
Status: offline
hey guys i finally got the nerve up and dumped some money into this thing, and now ive got a problem it wont even lift off the ground. ive got a century main and a gws dd tail, superskids and metal flybar (care of my last order from Michael thanks) but im also running the stick battery do you think ive just got a weight problem or is their something else that might possibly be wrong
(in reply to Navy_1)
       Post #: 5934
RE: Falcon 40 (Exceed heli) Forum - 5/22/2008 2:48:44 AM
USHobbySupply
Status: online
The stock
